"Secure Connections" causes Live TV to not work off LAN (Router: Ubiquiti Edgerouter Lite)
I have been battling this problem for months and finally figured it out. If I disable the “Secure Connections” setting, Live TV now works outside my LAN. If “Secure Connections” is turned on, Live TV will not work outside my LAN on ANY quality setting. Only plays about 5-10 seconds then pauses. Disable the setting, flawless playback!
Does anyone have any solutions on a fix so I can keep “Secure Connections” enabled? Is this a Plex Bug?
My router is an Ubiquiti Edgerouter Lite for reference.
This did not fix my Live TV freezing on my remote Android TV devices, but it did fix this wired lag where my PMS was crawling to a halt and would not load pages. It kept getting worse till it was about unusable. I tried restarting nothing seemed to fix it. Once I turned HTTPS off and back on it started working fine. Maybe this was due to an expired cert.
Are you on Sprint?
No, I am using ATT on my remote devices with PMS on Spectrum.
What bitrate works reliably? None? or Just 1.5Mbps and lower or ???
None, I have tried 0.3Mbps up to original.
Disable ‘secure connections’ in PMS. Save it. Shut down PMS. Start PMS back up.
Try viewing now…
It’s still freezing.
On 0.3 Mbps even? How about Direct Play?
What is your server?
Normal content, TV show, movies, recorded Live TV seems to play fine on my remote device. They are being converted down. I cant do Direct Play, most of them have higher bitrates then my remote devices have the download speed.
If you run a speedtest on your phone what are you pulling down/up?
What are the specs of your Plex Server? CPU, Ram?
Phone can do 40m down 7m up, this is what i am testing with today. The normal connection at the remote site is max 20m down. PMS is in a VM i have giving it 8GB of RAM it has been given 32 cores, Dul AMD Opteron 6272 2.1GHz
What is the up/down on the PMS server?
250m down, 20m up.
Are you able to do multiple transcoded and Direct Play streams on your home network with no issue at all? Say 3-5?
yes, on home network my .mp4 do direct play, my .mkv with subtitles do converting with direct stream. I quite often have two TV’s, one web app, one IOS device running at the same time.
You do have port forwarding set up correctly with the green check?
Are you able to successfully stream 3 or 4 “transcoded” locally at the same time?
Yes i have setup port forwarding on my Ubiquiti EdgeMax X. I started 4 transcoders. I have attached a picture. As a side note i could not play more then two transcoders on the same Chrome instance.
On the same Chrome instance? Can you play 4 different movies, all transcoding, to 4 different devices on same network?
At first i tried to open four web apps on my PC. The first two worked fine but the 3rd would just lag, even with direct play. I am not sure why. so then i played the other two on my two different Android TV’s. Yes i can play four different movies all transcoding on different devices.
