Server settings are unavailable - ubuntu 20.04 - 1.22.1.4271
Server Version#: 1.22.1.4271
Player Version#: 4.53.0
Just updated to 1.22.1.4271 on ubuntu 20.04 today (update is about 1h old) and now I cannot access the server settings. Uninstalled and reinstalled plexmediaserver but it did not fix the problem. Suggestions?
Same exact issue when I updated my Synology NAS just now. Tried stopping/starting the service, restarting, etc. Now the Plex server has gone away completely. This is the Synology version that appears to be broken (released April 1st):
PlexMediaServer-1.22.1.4271-b86a5e175-x86_64_DSM6
More info:
plexmediaserver 1.22.1.4271-b86a5e175 amd64
I can see “Status” but nothing under “Settings” or “Manage”
Same exact problem but on Ubuntu 18.04…
Same problem on Unraid, but I upgraded to v 1.22.2.4274 from the beta channel.
Same here too on Debian stable after upgrade to PlexMediaServer-1.22.2.4274
Same here…20.04, latest upgrade…no server settings…
Downloaded and rolled back to plexmediaserver_1.22.2.4264-b275c4330_amd64.deb from the Plex website and reinstalled. All is working again. Will wait a day or two to update again. Hopefully someone solves it by then.
Same problème on a Synology DSM6 x64 server :frowning:
Same here with UnRaid 6.9.1. Dropping back to 1.22.2.4264-b275c4330 worked.
Same issue. Unraid 6.9.1. Medias and everything Works fine, but no access to settings.
In my docker logs, I got these :
Plex Plug-in [com.plexapp.system]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.thetvdb]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.themoviedb]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.htbackdrops]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.localmedia]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [tv.plex.agents.series]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [tv.plex.agents.music]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.fanarttv]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [org.musicbrainz.agents.music]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.plexthememusic]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.lastfm]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.movieposterdb]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.imdb]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.none]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.opensubtitles]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
/usr/lib/plexmediaserver/Plex Tuner Service: error while loading shared libraries: libcurl.so: cannot open shared object file: No such file or directory
Plex Plug-in [com.plexapp.agents.lyricfind]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
Plex Plug-in [tv.plex.agents.movie]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
/usr/lib/plexmediaserver/Plex Relay: error while loading shared libraries: libcurl.so: cannot open shared object file: No such file or directory
Same issue here on Unraid, running the official Docker package. I can still stream things from my server just fine, I just can’t change any settings.
How exactly do you roll back? I’m pretty new to Unraid.
Same here…
Same here on Synology DSM 6.2.3 with PMS 1.22.1.4271
TO ALL:
Please hold up.
Just now got online. Investigating
I tried to apply 1.22.1.4271 to my Synology NAS and the install would never complete even after 10 minutes. I’m currently running 1.22.1.4228. I guess it’s a good thing the update never completed from the sounds of it. Hopefully they get everything sorted out.
It’s already up to Build 4274.
PLEASE hold up. Let me investigate
Same problem occurs in Ubuntu 18.04 with plex running on docker in the plexinc / pms-docker image
I’m not worried…Chuck is on the case. He will apply his magical powers to make it all better!
(chanting)
Chuck, Chuck, Chuck, Chuck, Chuck…
(Seriously, we all knew better than to do an April 1st install, so nobody but ourselves to blame!)
Hello,
Same here on Synology Docker Linuxserver image.
Roll back to a previous functionnal build : 1.22.1.4228.
