I am hoping to get some advice on how to basically replicate my PMS to another server and maintain the metadata, watched status, etc.
I have a PMS set up on a DS415+ with the latest update. I was recently given a second DS415+ so I am setting it up as a backup to my first. I will be changing both to a RAID 0 to utilise all the space and read/write speeds and will just rely on the backup NAS if something should go wrong with a drive. I have about 10 family members that access my PMS so I am going to set up a second PMS on the backup NAS and just split the users in half to split the load on the two NASes. Also bandwidth hasn’t been a problem yet, my speeds are about 100/40. I have already used Synology Drive Sync to move all of the libraries over to the new NAS so it is ready to go.
I have located this link: https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
Will this achieve what I need it to? Or will it just move my PMS rather than setting up a second? As far as I can tell it should work but might be worth excluding the preferences.xml file from the transfer of files and setting the new PMS settings manually. Is this correct?
I believe I could follow these instructions easily enough apart from this:
For Linux/NAS systems, make sure that the directories and contents are all owned by plex:plex (or whichever user you have running Plex Media Server under).
Is anyone able to explain how exactly I do this? I understand that this is probably a stupid question.
I appreciate any advice here!
