Shield latest beta - TV Series Auto Playback freezes few seconds
I’m on a recent beta, probably have 3 releases older than current beta release, and have still freezing issue quite a bit. Also, while playing and then pausing, if I wait for a bit and then play the video freezes for a few seconds but audio keeps playing. Then video is synced with the audio.
@sixones
Sorry to say but 8.10 doesnt fix anything.
Will provide logs tomorrow
best regards
Ekomax
@sixones
I sent you a private Message with Logs and a Video of the problem with Beta 8.1.0…
Hope this helps.
best regards
Ekomax
@sixones
Did you get the log and video?
Any other way i can help? This Bug makes my family …
Please respond
Best regards
@sixones
Since i get no answer, i wanted to tell yo that i did some more testing. Public Client 8.0.2.17816 is the last version that plays next episode after countdown correct. No problems with that version. With the next public release the freezing problem after countdown start
Hope that helps.
best regards.
Dear @DaveBinM
Could you look into this?
I dont know what else i can do to help
Thx
Best regards
@sixones
@DaveBinM
Any update? Not one word in 22 days?
I kindly ask - will this problem get solved?
Its months now!
Best regards
Ekomax
Newest beta doesnt solve the problem!
Best regards
Agreed. Recent updates are not working well. News constantly buffers does not play, the blurred background is grossly distorted, audio dropouts ,and there is a lag in playback.
I ended up going back to ver 8.8.1… where almost everything is functional.
Using Shield 2017
@sixones
@BigWheel
Would anybody would be so kind and answer?
This is ridiculous!
No feedback, no answer - you got everything you needed!!
We are still looking into it. Sorry I do not have an eta for a fix
@BigWheel
Thanks for responding.
Is beeing worked on?
Yes, among other bugs as well.
@BigWheel
Thanks again.
hope the end is near
Hi @Ekomax,
I can confirm that this issue also appears in the normal Plex Android app (8.11.0.22186 a1b8a7fb)
