Shield TV PMS Recordings Ending Prematurely
Server Version#:v1.20.5.3600-47c0d9038 - NVIDIA SHIELD Android TV mdarcy - build: android-aarch64
Nvidia Shield TV Pro 2019
Lately I’ve been getting a lot of recordings that start OK, then get cut randomly short. For example, here’s what I got last night:
I have an HDHomerun DUAL (2 tuners) and an HDHomerun CONNECT (2 tuners). I have transcoding enabled for all tuners. I’m recording to a 480GB USB SSD connected to the Shield TV Pro as Adopted Storage (409GB free). I have shows scanned for intros & commercials (nondestructive, marked for skip).
Probably of note: I watched a show on Netflix from around 8:45pm to 9:30pm, which is the timeframe when all of my recordings appear to have failed. Also, in the Shield’s settings, I have AI Upscaling turned on for streaming content.
Is this just the transcoder just getting overloaded? Logs are attached for the timeframe in question. The recordings just keep failing with no obvious warning in Plex, until I go to look at the saved recordings and see that they aren’t the full hour that they’re supposed to be.
Here are the PMS transcoder settings, which I believe are untouched from the defaults:
(File removed)
