Shows not starting, forcing restart of PMS
server-windows
#1
I have been having an issue over the past week with devices failing to be able to start a show. This is happening both within my home and remotely. For example, if i open Plex on my Fire TV box within my house on the same wired network, plex opens, shows my content. When i press play on a specific show, a message pops up, "talking to the server", "working" and the icon circles over and over until it times out. This has happened several nights in a row. PMS still appears to be running, can be logged in to, and will sometimes show activity that the device has connected. This error has been seen on fire tv boxes, sticks, iphone 7s, as well as android galaxy s8s.
At this point, the only way to get any device to access content is by restarting Plex Media Server. This has been done through restarting the machine it runs or by forcing PMS to stop through task manager.
My Plex set up has been up and running for a couple years and gets daily use locally and while out of the house. THe PC isn't perfect, but does great 99% of the time. Windows 10, AMD Athlon X4 860k quad core 4.00GHZ, 16 GB Ram, 64 bit, WIndows 10 Insider, Version 1709, OS Build 17046.1000, about 6 TB of content.
I have restarted and have plex streaming a show, but when attempting to get to the Plex Media Server settings on the PC running PMS, i am receiving an error that settings are unavailable.
I am running PMS version 1.10.1.4602. Plex Server crash logs are showing a "Error issuing curl_easy_perform(handle): 28" But no other errors are being logged. I have turned on verbose logging.
If anyone has any ideas on what to look for or where to dig in on the verbose logs, i would appreciate the help.
#2
Need to look at logs
Please make sure debug logging is enabled on the server - settings / Server / General / Show Advanced and check if debug logging is enabled, No need for verbose logging at this stage - so disable it
Restart the server to get fresh logs created
When the problem happens, on say iPhone, collect the server logs and iOS app logs
For server, Settings / Server / Help / Download logs
For iOS App, Settings / Help & Support / Debugging / Share Debug Data / and select Email to email to yourself
Attach zip from the iOS app and the downloaded Plex Media Server logs zip and indicate the time of the error - preferably with a screenshot
If it is happening on Fire TV and not the iPhone app, please see this support article for getting the logs from the app to go with the corresponding server logs
https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
#3
problem just happened again and i have attached the logs. Issue happened right around 9:32 to 9:35 pm). PMS and FireTV Logs are attached.
I greatly appreciate any help that is available.
FYI - i posted in a second place, related to photos not uploading to PMS. camera upload starts, says it is synced up, but doesn’t transfer any pictures. if i completely restart the process, create a new library, etc, it usually will upload a few pictures before saying everything is synced up (while failing to transfer the pictures). I have gained access to the logs with the info you sent for the iphones, so if any any help can be given to analyze that issue once the first one is handled, i would appreciate that too.
#4
what was the issue between 21:32 and 21:35 ?
What I can see is a lot of skipping back on the video
01-21 21:33:02.448  i: [ExoVideoPlayer] Seeking to 1904411ms
01-21 21:33:13.208  i: [ExoVideoPlayer] Seeking to 1903342ms
01-21 21:33:13.522  i: [ExoVideoPlayer] Seeking to 1893342ms
01-21 21:33:13.577  i: [ExoVideoPlayer] Seeking to 1883342ms
01-21 21:33:13.756  i: [ExoVideoPlayer] Seeking to 1873342ms
01-21 21:33:13.956  i: [ExoVideoPlayer] Seeking to 1863342ms
01-21 21:33:14.117  i: [ExoVideoPlayer] Seeking to 1853342ms
01-21 21:33:14.334  i: [ExoVideoPlayer] Seeking to 1843342ms
01-21 21:33:14.580  i: [ExoVideoPlayer] Seeking to 1833342ms
01-21 21:33:14.811  i: [ExoVideoPlayer] Seeking to 1823342ms
01-21 21:33:15.003  i: [ExoVideoPlayer] Seeking to 1813342ms
01-21 21:33:15.175  i: [ExoVideoPlayer] Seeking to 1803342ms
01-21 21:33:15.736  i: [ExoVideoPlayer] Seeking to 1793397ms
01-21 21:33:15.938  i: [ExoVideoPlayer] Seeking to 1783397ms
01-21 21:33:16.108  i: [ExoVideoPlayer] Seeking to 1773397ms
01-21 21:33:16.318  i: [ExoVideoPlayer] Seeking to 1763397ms
01-21 21:33:16.532  i: [ExoVideoPlayer] Seeking to 1753397ms
01-21 21:33:16.742  i: [ExoVideoPlayer] Seeking to 1743397ms
01-21 21:33:18.039  i: [ExoVideoPlayer] Seeking to 1734220ms
01-21 21:33:18.265  i: [ExoVideoPlayer] Seeking to 1724220ms
01-21 21:33:18.510  i: [ExoVideoPlayer] Seeking to 1714220ms
01-21 21:33:18.726  i: [ExoVideoPlayer] Seeking to 1704220ms
01-21 21:33:18.893  i: [ExoVideoPlayer] Seeking to 1694220ms
01-21 21:33:19.116  i: [ExoVideoPlayer] Seeking to 1684220ms
01-21 21:33:19.519  i: [ExoVideoPlayer] Seeking to 1674220ms
01-21 21:33:19.728  i: [ExoVideoPlayer] Seeking to 1664220ms
01-21 21:33:19.942  i: [ExoVideoPlayer] Seeking to 1654220ms
01-21 21:33:20.201  i: [ExoVideoPlayer] Seeking to 1644220ms
01-21 21:33:20.411  i: [ExoVideoPlayer] Seeking to 1634220ms
01-21 21:33:20.621  i: [ExoVideoPlayer] Seeking to 1624220ms
01-21 21:33:20.786  i: [ExoVideoPlayer] Seeking to 1614220ms
01-21 21:33:21.072  i: [ExoVideoPlayer] Seeking to 1604220ms
01-21 21:33:33.501  i: [ExoVideoPlayer] Seeking to 1606196ms
01-21 21:33:33.715  i: [ExoVideoPlayer] Seeking to 1596196ms
01-21 21:33:33.934  i: [ExoVideoPlayer] Seeking to 1586196ms
01-21 21:33:34.137  i: [ExoVideoPlayer] Seeking to 1576196ms
01-21 21:33:34.490  i: [ExoVideoPlayer] Seeking to 1566196ms
01-21 21:33:34.665  i: [ExoVideoPlayer] Seeking to 1556196ms
01-21 21:33:34.916  i: [ExoVideoPlayer] Seeking to 1546196ms
01-21 21:33:35.090  i: [ExoVideoPlayer] Seeking to 1536196ms
01-21 21:33:35.298  i: [ExoVideoPlayer] Seeking to 1526196ms
01-21 21:33:35.473  i: [ExoVideoPlayer] Seeking to 1516196ms
01-21 21:33:35.680  i: [ExoVideoPlayer] Seeking to 1506196ms
01-21 21:33:35.891  i: [ExoVideoPlayer] Seeking to 1496196ms
01-21 21:33:36.123  i: [ExoVideoPlayer] Seeking to 1486196ms
01-21 21:33:36.336  i: [ExoVideoPlayer] Seeking to 1476196ms
01-21 21:33:36.556  i: [ExoVideoPlayer] Seeking to 1466196ms
01-21 21:33:38.698  i: [ExoVideoPlayer] Seeking to 1457815ms
01-21 21:33:38.939  i: [ExoVideoPlayer] Seeking to 1447815ms
01-21 21:33:39.125  i: [ExoVideoPlayer] Seeking to 1437833ms
01-21 21:33:39.400  i: [ExoVideoPlayer] Seeking to 1427833ms
01-21 21:33:39.774  i: [ExoVideoPlayer] Seeking to 1417833ms
01-21 21:33:39.984  i: [ExoVideoPlayer] Seeking to 1407833ms
01-21 21:33:40.818  i: [ExoVideoPlayer] Seeking to 1397944ms
01-21 21:33:41.070  i: [ExoVideoPlayer] Seeking to 1387944ms
01-21 21:33:41.319  i: [ExoVideoPlayer] Seeking to 1377944ms
01-21 21:33:41.529  i: [ExoVideoPlayer] Seeking to 1367944ms
01-21 21:33:41.783  i: [ExoVideoPlayer] Seeking to 1357944ms
01-21 21:33:42.033  i: [ExoVideoPlayer] Seeking to 1347944ms
01-21 21:33:43.036  i: [ExoVideoPlayer] Seeking to 1338386ms
01-21 21:33:43.239  i: [ExoVideoPlayer] Seeking to 1328386ms
01-21 21:33:43.481  i: [ExoVideoPlayer] Seeking to 1318386ms
01-21 21:33:43.731  i: [ExoVideoPlayer] Seeking to 1308386ms
01-21 21:33:43.983  i: [ExoVideoPlayer] Seeking to 1298386ms
01-21 21:33:45.381  i: [ExoVideoPlayer] Seeking to 1289311ms
01-21 21:33:45.590  i: [ExoVideoPlayer] Seeking to 1279311ms
01-21 21:33:45.741  i: [ExoVideoPlayer] Seeking to 1269311ms
01-21 21:33:45.926  i: [ExoVideoPlayer] Seeking to 1259311ms
01-21 21:33:46.300  i: [ExoVideoPlayer] Seeking to 1249311ms
01-21 21:33:46.466  i: [ExoVideoPlayer] Seeking to 1239311ms
01-21 21:33:46.641  i: [ExoVideoPlayer] Seeking to 1229311ms
01-21 21:33:50.997  i: [ExoVideoPlayer] Seeking to 1223260ms
01-21 21:33:51.256  i: [ExoVideoPlayer] Seeking to 1213286ms
01-21 21:33:51.425  i: [ExoVideoPlayer] Seeking to 1203286ms
01-21 21:33:51.598  i: [ExoVideoPlayer] Seeking to 1193286ms
01-21 21:33:51.869  i: [ExoVideoPlayer] Seeking to 1183286ms
01-21 21:33:52.044  i: [ExoVideoPlayer] Seeking to 1173286ms
01-21 21:33:52.195  i: [ExoVideoPlayer] Seeking to 1163286ms
01-21 21:33:52.414  i: [ExoVideoPlayer] Seeking to 1153286ms
01-21 21:33:52.586  i: [ExoVideoPlayer] Seeking to 1143286ms
01-21 21:33:52.817  i: [ExoVideoPlayer] Seeking to 1133286ms
01-21 21:33:53.022  i: [ExoVideoPlayer] Seeking to 1123286ms
01-21 21:33:53.210  i: [ExoVideoPlayer] Seeking to 1113286ms
01-21 21:33:53.429  i: [ExoVideoPlayer] Seeking to 1103286ms
01-21 21:33:53.603  i: [ExoVideoPlayer] Seeking to 1093286ms
01-21 21:33:53.822  i: [ExoVideoPlayer] Seeking to 1083286ms
01-21 21:33:54.043  i: [ExoVideoPlayer] Seeking to 1073286ms
01-21 21:33:54.293  i: [ExoVideoPlayer] Seeking to 1063286ms
01-21 21:33:54.443  i: [ExoVideoPlayer] Seeking to 1053286ms
01-21 21:33:54.628  i: [ExoVideoPlayer] Seeking to 1043286ms
01-21 21:33:54.865  i: [ExoVideoPlayer] Seeking to 1033286ms
01-21 21:33:55.082  i: [ExoVideoPlayer] Seeking to 1023286ms
01-21 21:33:55.301  i: [ExoVideoPlayer] Seeking to 1013286ms
01-21 21:33:55.520  i: [ExoVideoPlayer] Seeking to 1003286ms
01-21 21:33:55.697  i: [ExoVideoPlayer] Seeking to 993286ms
01-21 21:33:55.963  i: [ExoVideoPlayer] Seeking to 983303ms
01-21 21:33:56.142  i: [ExoVideoPlayer] Seeking to 973303ms
01-21 21:33:56.303  i: [ExoVideoPlayer] Seeking to 963303ms
01-21 21:33:56.530  i: [ExoVideoPlayer] Seeking to 953303ms
01-21 21:33:56.751  i: [ExoVideoPlayer] Seeking to 943303ms
01-21 21:33:57.006  i: [ExoVideoPlayer] Seeking to 933303ms
01-21 21:33:57.233  i: [ExoVideoPlayer] Seeking to 923303ms
01-21 21:33:57.395  i: [ExoVideoPlayer] Seeking to 913303ms
01-21 21:33:57.656  i: [ExoVideoPlayer] Seeking to 903303ms
01-21 21:33:57.811  i: [ExoVideoPlayer] Seeking to 893303ms
and with regardless to playback state - this shows no errors and playback reaching the timeline seconds specified
Jan 21, 2018 21:33:08.485 [16500] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state playing, progress of 1904411/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Jan 21, 2018 21:33:16.589 [2640] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state playing, progress of 1912507/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Jan 21, 2018 21:33:23.346 [16500] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state buffering, progress of 1694220/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Jan 21, 2018 21:33:26.573 [9996] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state playing, progress of 1604980/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Jan 21, 2018 21:33:36.583 [16500] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state playing, progress of 1614977/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Jan 21, 2018 21:33:46.596 [2640] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state playing, progress of 1347944/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Jan 21, 2018 21:33:56.582 [3384] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state playing, progress of 1163286/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Jan 21, 2018 21:34:06.576 [3384] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state playing, progress of 897391/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Jan 21, 2018 21:34:16.567 [9648] DEBUG - Client [68ac422f37f83238-com-plexapp-android] reporting timeline state playing, progress of 907387/3720557ms for guid=com.plexapp.agents.thetvdb://305288/2/9?lang=en, ratingKey=776113 url=, key=/library/metadata/776113, containerKey=/playQueues/1910, metadataId=776113
Last being playback at position 907.387 seconds (ie 15 minutes 7 seconds)
#5
The skipping of the video was as expected. But it was only able to occur after i restarted plex media server.
The issue i have is i will be on a client, such as the fire tv client i provided the logs for last night. i was able to browse content, select a tv show, and when i clicked play, instead of going in to the show, a pop up shows up “Talking to server” “working”. When this pop up shows up, my plex media server is 100% non-responsive. on the PC that runs the PMS, i cannot log in to the PMS. the login page will try to connect, but nothing will load. i have to either restart the PC, or going through Task Manager, kill the plex media server process and then restart it. Connections are immediately restored and playback is perfect (as in the example above). when it is working correctly, once i hit play, instead of seeing the “talking to server” message, the show loads very quickly with the control bar visible under the name of the show. when the issue occurred last night, i turned on logging on the fire tv client, recreated the issue, then restarted PMS and captured the logs.
On the fire tv logs, this is the only indication of the error (right at the beginning):
01-18 22:21:05.118 i: [Live] Timeline response didn’t contain information about the capture buffer
01-18 22:21:15.085 i: Fetching [method:GET] http://192.168.2.10:32400/:/timeline?bandwidth=3529&bufferedTime=69&containerKey=%2FplayQueues%2F1894&duration=3387397&guid=com.plexapp.agents.thetvdb%3A%2F%2F279536%2F2%2F1%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F774160&machineIdentifier=b2075f170186e80b943e1d5fc481903b57661508&playQueueItemID=41867&ratingKey=774160&state=playing&time=3317611&X-Plex-Client-Identifier=68ac422f37f83238-com-plexapp-android&X-Plex-Token=...K5uW
01-18 22:21:15.107 i: [Live] Timeline response didn’t contain information about the capture buffer
01-18 22:21:25.072 i: Fetching [method:GET] http://192.168.2.10:32400/:/timeline?bandwidth=3529&bufferedTime=59&containerKey=%2FplayQueues%2F1894&duration=3387397&guid=com.plexapp.agents.thetvdb%3A%2F%2F279536%2F2%2F1%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F774160&machineIdentifier=b2075f170186e80b943e1d5fc481903b57661508&playQueueItemID=41867&ratingKey=774160&state=playing&time=3327606&X-Plex-Client-Identifier=68ac422f37f83238-com-plexapp-android&X-Plex-Token=...K5uW
01-18 22:21:25.105 i: [Live] Timeline response didn’t contain information about the capture buffer
01-18 22:21:31.697 i: [UserAction] Navigate back.
01-18 22:21:31.711 i: [TranscodeSession] Stopping…
the information after this point was after PMS was restarted.
#6
You mentioned that the issue arose between 21:32 and 21:35 and my feeeback was for that period. You did not say which date and I assumed latest - being 21 Jan
I need matching logs for the period of time you want me to look at. I understand from your response that the issue was 18th January 22:21 and not 21st January
I will check this evening, as I am way from my pc now, if the server logs provided do go back to the 18th January
#7
i apologize for any confusion - in my rush to respond, i copied from the beginning of the firetv log (which i assumed started logging after i turned logging on yesterday after the issue appeared). i didn’t recognize the information i copied was from the 18th, instead of the 21st. the issue occurred again yesterday, 1/21, around the same time period (21:32 to 21:35).
So, the two logs that i uploaded were for the same period of time. in the firetv logs, search for: “01-21 21:23:14.485” this is the first part of yesterday’s incident. My wife opened up the app at that time. the actions taken at that time were to go to a show, try to start it. When it failed to start, she notified me. I turned on logging:
01-21 21:24:44.521 i: [Amazon] Enabling verbose logging
This appears to be the actual error that is logged:
01-21 21:26:31.991 i: Time out fetching http://192.168.2.10:32400/playQueues?repeat=0&includeChapters=1&shuffle=0&key=%2Flibrary%2Fmetadata%2F776113&type=video&uri=library%3A%2F%2Fb6a3441b-32b2-4331-aab9-944ecbede560%2Fitem%2F%2Flibrary%2Fmetadata%2F776103&continuous=0&X-Plex-Token=...K5uW.
01-21 21:26:31.992 e: [PlayQueueAPIHelperBase] Unable to create play queue
01-21 21:26:32.024 i: Showing toast: Unable to play media
01-21 21:31:39.299 i: [FocusService] App focus lost.
01-21 21:32:22.022 e: [ServerWebSocket] Websocket error
01-21 21:32:22.043 e: An exception occurred: java.net.SocketException: recvfrom failed: ECONNRESET (Connection reset by peer)
01-21 21:32:22.061 e: Stacktrace: java.net.SocketException: recvfrom failed: ECONNRESET (Connection reset by peer)
at libcore.io.IoBridge.maybeThrowAfterRecvfrom(IoBridge.java:592)
at libcore.io.IoBridge.recvfrom(IoBridge.java:556)
at java.net.PlainSocketImpl.read(PlainSocketImpl.java:485)
at java.net.PlainSocketImpl.access$000(PlainSocketImpl.java:37)
at java.net.PlainSocketImpl$PlainSocketInputStream.read(PlainSocketImpl.java:237)
at okio.n$2.a(SourceFile:139)
at okio.a$2.a(SourceFile:211)
at okio.p.b(SourceFile:71)
at okio.p.a(SourceFile:64)
at okio.p.i(SourceFile:77)
at com.squareup.okhttp.internal.c.c.b(SourceFile:110)
at com.squareup.okhttp.internal.c.c.a(SourceFile:99)
at com.squareup.okhttp.internal.c.a.a(SourceFile:97)
at com.squareup.okhttp.a.b.a(SourceFile:169)
at com.squareup.okhttp.a.b.a(SourceFile:42)
at com.squareup.okhttp.a.b$1.a(SourceFile:100)
at com.squareup.okhttp.k.b(SourceFile:168)
at com.squareup.okhttp.internal.i.run(SourceFile:33)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
at java.lang.Thread.run(Thread.java:818)
Caused by: android.system.ErrnoException: recvfrom failed: ECONNRESET (Connection reset by peer)
at libcore.io.Posix.recvfromBytes(Native Method)
at libcore.io.Posix.recvfrom(Posix.java:186)
at libcore.io.BlockGuardOs.recvfrom(BlockGuardOs.java:250)
at libcore.io.IoBridge.recvfrom(IoBridge.java:553)
… 19 more
01-21 21:32:27.716 e: [ServerWebSocket] Websocket error
01-21 21:32:27.719 e: An exception occurred: java.net.SocketException: recvfrom failed: ECONNRESET (Connection reset by peer)
01-21 21:32:27.729 e: Stacktrace: java.net.SocketException: recvfrom failed: ECONNRESET (Connection reset by peer)
at okio.p.a(SourceFile:306)
at okio.p.a(SourceFile:300)
at okio.p.s(SourceFile:196)
at com.squareup.okhttp.internal.http.g.g(SourceFile:191)
at com.squareup.okhttp.internal.http.r.b(SourceFile:79)
at com.squareup.okhttp.internal.http.o.n(SourceFile:909)
at com.squareup.okhttp.internal.http.o.i(SourceFile:745)
at com.squareup.okhttp.i.a(SourceFile:277)
at com.squareup.okhttp.j.a(SourceFile:234)
at com.squareup.okhttp.i.a(SourceFile:196)
at com.squareup.okhttp.i.a(SourceFile:34)
at com.squareup.okhttp.k.b(SourceFile:162)
… 21 more
Hopefully this info will make it easier to identify the issue on the client and server equivalent. Again, my apologies for pasting the wrong log info earlier.
#8
I am having the exact same issue! The timeout is occurring on the network call to “playQueues” endpoint. Nothing except rebooting the Plex Server process will fix it and allow me to watching video again, very annoying… This only started happening in the last few days I believe.
I noticed the issue also affects Live TV viewing, the “tune” endpoint times out when trying to start a stream. So, I believe whatever is hanging on the server is the common piece between “playQueues” and “tune” endpoints. Perhaps it can’t start the transcoder process properly?
I’m on Windows Server 2012 R2, and the media is located on Stablebit Drive Pool partition. Not sure if either of those is related, as Plex itself I don’t think has updated recently, so I feel like it must be something else that changed… Either that or perhaps something w/ the Plex main servers? Let me know if you find anything out @bwonish , I will do the same.
#9
Another update on this. Along with not being able to start a video, there is also a timeout whenever you try to mark an item as watched/unwatched. So, perhaps the root issue is somehow related to setting progress on media?
Again, a reboot seems to fix, but only for a very short time.
#10
That is good info - thank you
It is a problem that has been seen recently where some requests hang. The problem actually started at 19:44:23 on 21st January. I have already referred it to the development team for investigation
It is the same issue as on this forum topic
#11
The more evidence I have of the issue the better. So please ensure debug logging is enabled. restart the server anyway to get fresh logs and as soon as the issue arises restart and collect the logs and attach here
#12
I’m also seeing this issue. All the descriptions line up perfectly with the symptoms I’m seeing. I’ve enabled debug logging in the hopes I can catch it in the act. It happened to me last night and again tonight. The client in both cases was a Roku not on my local network. A restart of the Plex server was the only thing I could get to fix it.
FYI I’m running PMS 1.10.1.4602 on Debian Linux.
#13
sa2000, - interesting note about the time you said the issue appears to start at (19:44:23 on the 21st). This is most likely the time the Fire TV was woken up (i.e. the TV was turned on, but not set to the FireTV input, which is externally powered). So i am assuming the FireTV woke up, was probably still loaded in Plex. So, this could potentially be tied to the client waking back up, but that is the extent of my ability to guess at causes or connections.
By the way, thank you for the help. its appreciated.
#14
FWIW, this seems to have magically resolved on its own for me. I haven’t really changed anything but where I was seeing this issue daily I haven’t seen it in about a week.
#15
@bwonish
A build of Plex Media Server with extra diagnostics and potential fix will be available shortly which I would like you to use and try to break !
I will send you private message with download link when available
It is a 1.11.2 build
