Hi Simon,
OK, on first load, the app loads and asks for IP address. Once I enter that and click through to what should be the main app, I just get an empty screen with "Loading" and an animated wheel in the bottom-right corner (same as the screenshot someone posted earlier). I left it for several minutes and eventually the screensaver kicks in, moving this blank loading screen around the screen - but it doesn't load.
If you quit the app and go back into it, it doesn't ask for an IP address... just jumps straight to the "Loading" screen.
Yes same here for me. I have no way of getting back to the IP screen to recheck my server IP.
If I click the arrow bottom right and bring up the quick menu, none of the functions work on that menu including settings.
I even tried deleting all the files on the thumb drive and putting on the files new again and I still don't get a prompt with the IP screen anymore, just goes straight to the loading screen again.
Just tested 0.5.0.1 ... on load the app shows the grey large panel on the right, the vertical white line and the black column on the left... and a small "double back arrow" on the bottom-left. But nothing else.
It's not asked me for the IP of my PMS so it may well be stuck using the old settings. Any way to clear that out?
Hi Simon. It´s unbelievable, this new UI :) Finally i can hear full albums - that´s great.
But there are two things i´ve noticed:
1. When i play an album or song, it don´t shows a timeline down on the left corner, like on your (ALBUM-DETAILS) Screenshot. It comes only when i watch a movie or whatever.
2. For myself, the release year of an album would looks better on the left side, directly under the albumname.
By the way, good work and thanks for your effort. ;)
Hello, just for info - ntfs 32gb flash didn't worked, but 4gb fat32 worked well.
Another big question is it possible do support of plex channels on this app or any other way on 42lg620v? Tried in LG default smart share but this one show only movies, this app shows the same. Just wanna launch WatchIS app(plugin) to watch stream movies(on pc its works perfect).
(this is on a 2013 TV - 50PH660V)
Thanks.
I have just released an update which should provide a fix for this error ... also you can now press the 'RED' button to reset settings on the home screen.
P.S. sorry for bad english
Channels aren't high on the priority list right now ... maybe in the future
Thanks .. yeah I removed the timeline bit on the TV as it looked ugly .. am looking at options to provide a similar function in the future ... I agree about the album date will change in future release ...
Strange :) smart share has the same functionality as this program so its will be big difference if you do a channel support(access to online stream theaters*drools*). Waiting the future.
Mmm not sure smart share provides the same functionality as this (I wrote it because it didn't) .. but agree channel support would be nice I just need time to investigate how channels work, and I still have a number of other things to get working first.
Roughly, they both provides access to multimedia files on pc (dlna?), also tried xbmc but it does not support channels too...feels like none of them support channels! So you will be first! ;)
I gotta say WOW, this is just a fantastic plex client. Simon you are doing a superb job on bringing plex to LG TVs.
Just giving it a quick test tells me this will be my only media centre from this point on.
Time to put away all my little boxes
Looking forward to your tweaks and updates. I will let you know of any bugs I find to help test.
So far the only thing I noticed is after a long wait there is no screen saver? Screen dimming would be nice.
Would it also be possible to change the season preview cover art from “poster size” to show the correct wide images? Using the poster art size cuts off the image.
Great update. A few issues I see are TV shows the description is crammed up in the bottom left corner and runs out of space on a some shows. There is a lot of unused screen space that could be put to better use. Movies look great. Haven't tried photos or music.
I thought medialink played some mkv files. At least I remember it doing so. I have mp4 and mkv files for the same movie (mp4 for apple, mkv for TV at a better resolution) and it used to give me a choice as to what file I wanted to play. I would prefer it to play natively supported files streamed and only transcoding files that aren't supported. I can't seem to figure out how profiles are handled on my unraid version of plex.
Sadly I can't test this now that I have the 2013 model. :(
Keep up the good work. Very impressed with progress.
I agree, The episodes info could easily go along the bottom and the full width of the screen.
If the series/season had a lot of "poster/episode art", you would just need to scroll down above the episode info that's along the bottom.
Another maybe easier option would be just make the thumb art window smaller to allow a bigger window with the info like the PC version?
Making it show only four or five covers in each row would allow more room for description.
Little tweaks like this will come I'm sure, I love this client.
I can imagine the amount of time, effort and skill needed to accomplish what you have ...and will.
