[SKIN] Plextra - default skin with extra options
other-skins
#1
https://github.com/BADMS/skin.plextra
PLEASE NOTE I UPDATE THIS LIVE AND AS SUCH SOME THEMING MAY STILL BE WIP BUT EVERYTHING WILL WORK!
  • Hide episode preview unwatched [enable hide plot in original skin]
  • Skip preplay [Or press 'play' button as normal to skip, if using keyboard or lazy will keep as is for now]
  • Fix missing TV season posters that currently don't work on original [PHT bug]
  • Video OSD paused infos
  • Flick Extras on preplay [will speed this up a little I think; clunky as can't check container onload]
  • Auto show Extras on preplay [again clunky as container not filled straight away onload]
  • Keep track of focus better, ie. loss of while waiting for channel content
  • Dim & zoom all panel views
  • Slide down homelists
  • Hide grainy overlay
  • Move right on Movie preplay shows Extras
  • Toggle video OSD press up/down, auto flash show/hide on load
  • Add side info for Libray Posters view
  • Add view toggle button
  • Add debug toggle (for me!)
  • Cycle all views
  • Kiosk Mode (Disable viewmode change on right move)
  • Super Kiosk Mode (disable leftside menus, disable quit/shutdown, disable context menus, etc. [resume only from preplay screen for now!])
  • Fix missing images on homelist 'Watch Later' [Not all are 'clips']
  • Fix missing 'Playlists' bg art on homelist [Composites missing; Use own for now in /Media]
  • Hack in alternative Music Artist image [Can't get from homelists atm]
  • Fix missing images on PlexPlayQueue
  • Global clock option
  • Fix missing Shared Content composite mask
  • Fix top level Shared Content panel view not wide enough
  • Spin username on start self indulgent candy
  • Hide TV spoiler plot in Video OSD [Tricky to get when play on remote pressed skipping preplay!]
  • Blur incorporated. Subtle use seems okay imho [Gas Mark 7]
  • Added Quit & Home buttons to left side menu
  • Ken Burns rules the World [sorry sorry sorry but it's off by default and disabled in background]
  • Added 'Expert' settings for 'Episode Auto Advance' [reason being is fine on local content, remote content watched status slow to update and the moment passes 'in the speed of things' etc!]
  • Added fonts. Sui & Rexlia work well
  • Added 'Playing X' to home menu (no fanout atm)
  • Auto kick back Empty List (expert setting as not tested remotely yet)
  • Transparent Home lists
  • Custom home slideshow
    To do:
  • Fix: Some channels view flips to bigger layout on position 0?
  • Fix: Double unwatched blob on PlexPlayQueue view?
  • Fix: Activated filters mess up viewmode? [PHT Bug fixed in next release!]
  • Dim & zoom homelists
  • Add low list style view
  • Hide season poster spoilers
#2
#3
"Skip preplay" has been in the skin for a long long time. Or is this another version of it? Like it has been removed totally?
#4
Now crack on and give me the screen I get in black remix when I press Pause during playback but in factory skin. :lol:
#5
Im not sure? Where is option to skip preplay? If it is, then i'll remove my remove of it ;)
All I can think is you press play button on item rather than click item? Will test later..
#6
Yep, that is the one I meant. Clicking the play button instead of OK button :)
#7
Well that's redundant then lol! Learn something everyday... especially if fick like me!
#8
  • VideoOSD paused infos
#9
  • Dim & Zoom viewmode posters
  • Hide homelists
#10
  • Move right on Movie Preplay shows Extras
#11
Wow, cool initiative!
You keep surprising us!
Thnx alot!
#12
thanks! jammyb idea, enjoy! ;=]
  • All dim & zooms done
#13
Requests.....
You've got pause info OSD. Can you make a setting for it stay on screen permanent when paused? It only stays on for 5-10 seconds or so
Please can you port over some more view modes and a similar way of changing betwee them? [pushing left]
Looks great so far. Just taking the grain overlay haas transformed it.
With it being factory skin it feels snappy on the pi2. Thanks for this!
#14
Requests.....
Will add option for OSD.
I really want to avoid adding viewmodes, as it will need theming (time I rarely have for everything atm unfortunately). Object was to just tweek what we have slightly. Is there one particular view that will work across all sections adequately for you?
#15
that's more than fair!
I use this for TV view.....
Viewtype - Poster Info
and this one for Movies.....
Viewtype - Low List
please! :lol:
#16
  • Toggle video OSD press up/down, auto show/hide
#17
  • Add side info for Libray Posters view [WIP more to come...]
#18
  • Themed sidepanel
  • Tweek unwatched in list
  • Cycle all views
#19
#20
  • Fix missing 'Playlists' bg art on homelist [Use own for now in /Media]
