Some photos showing "Unable to Load Photo" when viewed in Plex on Roku
roku
#1
Certain photos do not display on the Roku's Plex App (gray screen with "Unable to Load Photo" error message), while others display fine. Seems to be all photos taken with regular point-and-shoot cameras fail, while pictures taken on a smart phone display properly. The same photos do not display a thumbnail, instead showing a gray square.
All photos display properly in Plex web app viewed from browser, and all photos happen to be jpegs.
#2
I have the same problems on a Roku 3. It usually starts happening after several photos have displayed in slide show mode. If I reset the Roku, the photos will display once more. I have ordered a new Roku Premier+. It’ll be interesting to see if it has the same problem with the Plex app.
#3
Same as J&J, rebooted Roku, thumbnail/display issues resolved across all apps (Plex/Photos, Hulu, Netflix, etc.)
#4
Update: Bought Roku Premier+. Problem seems to be gone now.
#5
This is a big problem on the Roku 3. I don’t have other Roku devices to test on, but on the Roku 3 after a number of photos show the not able to load message shows up and then all Roku apps that show images are messed up. You have to reboot.
Is this being fixed?
#6
Rebooting Roku does not rectify the issue.
#7
Just bought a Roku Premier+ and I still have the same issue
#8
guys please help, I have an important family event coming up next week and need some photo slideshows to work. It just hands on “loading” and it is never the same pictures and sometimes it will go 2 minutes without a problem and other times it will go 10 minutes without an issue. My setup is a ReadyNAS running Plex and a Roku Premier +
#9
Those having this issue, please PM me 1 photo that is causing this issue.
#10
There was a big issue on Roku 3’s with photos - failing after a number of photos - this problem came with Roku firmware 7.6 build 4125
The problem appears to have got resolved in Firmware update 7.7.0 build 4094-04 which I got 9 days ago
#11
I have a Roku 3, updating the firmware to 7.7.0 build 4094-04 did not fix the issue for me.
However, my issue may be (somewhat) different, I am also “unable to load photo”. I can see all the photos as thumbnails, but displays the message when I try to view them. This issue isn’t restricted to the Roku and also presents itself on the Windows Plex App and also on the web client.
#12
Thanks - please see request from @“MovieFan.Plex” here and suggest you provide server logs as well at time of error
See https://support.plex.tv/hc/en-us/articles/201643703-Reporting-issues-with-Plex-Media-Server
https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
#13
Thank you very much! Upgrading to 7.7.0 fixed this issue for me. For some reason, my Roku 3 would not automatically pull this latest firmware. I had to manually ask it to update.
#14
I’ve gotten similar failures worded “There are no playable items” when I try to display a JPEG photo or MOV video from iphone. logs enclosed.
#15
Same there are no playable items problem here.
#16
I see in release 5.3.1(?) on May 9, there is this note: Verified my Roku preview channel is 5.3.2, with the issue still
(Photo) Fix playback from Recently Added hub.
Is this supposed to solve this thread’s issue, because it does not seem to have, for me at least. I still get the there are no playable items when trying photos.
#17
I can see the error
May 06, 2018 16:26:37.402 [32360] ERROR - LPE: exception generating query for invalid path 'library://5fa5384f-b9aa-4e2c-9948-8af9d7017535/directory/%2Flibrary%2Fsections%2F6%2Fall%3FsourceType%3D13%2C12%26sort%3DaddedAt%3Adesc': bad lexical cast: source type value could not be interpreted as target
This is fixed in release 5.3.0 which has been submitted to Roku and should be out soon.
See release note https://forums.plex.tv/discussion/comment/1666730/#Comment_1666730
  • (Photo) Fix playback from Recently Added hub.
#18
@sa2000 said:
I can see the error
I noted in my previous comment that my Roku channel is 5.3.2, and I still have this issue? Am I missing something here?
#19
@Cortopassi said:
@sa2000 said:
I can see the error
I don’t believe I have looked at any logs from you. My feedback about the fix was to @thorntonsk
If you have a problem, please enable debug logging on the server and the roku plex app and provide logs from both when the problem arises
See
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
https://support.plex.tv/articles/201377603-roku-logs/
#20
@sa2000 said:
@Cortopassi said:
@sa2000 said:
I can see the error
See
I will try to get logs, but:
–Roku regular release app (not sure what the current version is) does not have this problem.
–Only the preview channel does
