Server Version#: 1.18.0.1944
Player Version#: WEB 4.8.4
Player Version#: PMP 3.104.2
Player Version#: Plex 1.3.1.916-1cb2c34d
I try to always add a trailer for each movie. They are all in MP4 format. But sometimes they get recognized as trailers and sometimes just as another extra of the type “trailer”. I don’t know what’s the problem. My folder structure is: “Movies/Title (Year)/” and inside that folder I have my movie “Title (Year)” and the trailer “Title -trailer”. I am very thorough with this, I like to keep consistency. As you can see in the screenshots I uploaded below, sometimes they appear as extras, sometimes as trailers. This two movies were added at the same time. Refreshing metadata doesn’t work. Analyzing doesn’t work. Removing from the library, doing the plex dance, and adding again doesn’t work.
Oscar Wilde movie: guid="com.plexapp.agents.imdb://tt2404639?lang=es"
Oscar Wilde trailer: guid="file:///F:/Movies/La%20importancia%20de%20llamarse%20Oscar%20Wilde%20%282018%29/La%20importancia%20de%20llamarse%20Oscar%20Wilde%20-trailer.mp4"
Here it is the general part from Mediainfo
Oscar Wilde:
General
Complete name : F:\Movies\Inuyashiki (2018)\Inuyashiki -trailer.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 19.1 MiB
Duration : 1 min 15 s
Overall bit rate : 2 116 kb/s
Movie name : INUYASHIKI (Trailer 2 español)
Performer : Cine Asia
Recorded date : 2019
Writing application : Lavf58.18.104
Comment : https://www.youtube.com/watch?v=AYtnFI8FGKI
Inuyashiki
General
Complete name : F:\Movies\La importancia de llamarse Oscar Wilde (2018)\La importancia de llamarse Oscar Wilde -trailer.mp4
Format : MPEG-4
File size : 21.8 MiB
Duration : 2 min 1 s
Overall bit rate : 1 508 kb/s
Movie name : La importancia de llamarse Oscar Wilde - Trailer español (HD)
Performer : Trailers y Estrenos
Comment : https://www.youtube.com/watch?v=eK3H1u7c2CE
Ok, I think I found the solution. I think that plex needs to first find local assets and then match the movie to whatever agent. If you have it setup the other way, it recognizes the extras correctly but doesn’t match the trailer as a trailer.
I think what happened with my two uploads it’s that probably Inuyashiki got a bad match with the Plex Agent, so it matched, then found the local assets, and then I forced a new match with the local assets already found.
I have to test this further though.
Edit: after placing the agent “Local Media Assets” on top of “Plex Movie”, just refreshing metadata fixed all the problems. Before, refreshing metadata did nothing.
Keep in mind that LMA at the top will give you trouble if your main movie has embedded metadata which contain nonsense or conflict with the file name.
So make sure to either strip them out completely or edit them to perfection.
This one works for most of them (except actors): mp3tag
I’ll take that in account if I encounter any problem, however as this is the only workaround for now until a patch that fixes it, I’ll keep it this way.
