Sometimes only CONVERT ORIGINAL Q, sometimes READ IN ORIGINAL Q available
Hello everyone. I have an embarrassing problem. I run Plex on a Server but the CPU server is powerless, then I can only read the .MKV in original version and not convert them in 1080p.
For a mysterious reason, when I achieve PLEX from my browser (PLEX WEB) (from Ipserver or from Local), there is some movies with option “Play in Original quality” and for other films it’s “Convert to original quality”.
If it’s “Play”, all work perfectly, but if it’s “Convert to Original quality” there is latence…
My question is WHY this difference ?
More strange, If I use PLEX Client software (Mac), thenI have the “Play original quality” and not only “Convert original Quality”;
I hope you could help me then I would be able to get the good files.
THANK YOU.
PLEX WEB
PLEX WEB
The options differ because
  • Plex Media Player often can play the files as they are
  • the Plex web app often cannot do this but needs help from the server. This is called ‘transcoding’ and it takes time and requires a certain amount of processing power.
If you want to avoid transcoding, use Plex Media Player instead of the web app.
Otherwise, you’ll have to convert your files in advance to a format which a web browser can play.
Hi, thank you for your reply. It seems it works with Mac Client, however, on Plex Client Apple TV, even if the option “Read original Quality” is available, I get an error message telling me server is not powerful enough. But I only use Plex with my TV…
Then, which format should I use ? I have only mkv files, some works, some doesn’t…
Post the Plex XML info of one file which is working and one which doesn’t work.
Sorry I tried in local and from ip server to access to “see xml” but I get a white page.
I hope these informations can help,
some example of "NOT WORKING"
Média
Video Resolution 1080p
Durée 1:54:34
Débit 4211 kbps
Width 1920
Height 800
Aspect Ratio 2.35
Container MKV
Video Frame Rate 24p
Audio Profile lc
Video Profile main
Partie
Durée 1:54:34
File La_Vie_Revee_De_Walter_Mitty.MULTi.x265.AAC.mkv
Size 3.37 GB
Audio Profile lc
Container MKV
Video Profile main
Codec HEVC
Débit 4211 kbps
Langue English
Bit Depth 8
Chroma Subsampling 4:2:0
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 23.976 fps
Height 800
Level 4.0
Profile main
Ref Frames 1
Titre HEVC RF20
Width 1920
Display Title 1080p (HEVC Main)
Codec AAC
Chaînes 5.1
Débit 715 kbps
Langue Français
Audio Channel Layout 5.1
Profile lc
Sampling Rate 48000 Hz
Titre Français AAC 5.1 768 Kbps
Display Title Français (AAC 5.1)
Codec AAC
Chaînes 5.1
Débit 739 kbps
Langue English
Profile lc
Titre English AAC 5.1 768 Kbps
Display Title English (AAC 5.1)
Codec SRT
Langue Français
Titre Français SRT
Display Title Français (SRT)
Codec PGS
Débit 26 kbps
Langue Français
Header Compression true
Titre Francais PGS
Display Title Français (PGS)
Codec PGS
Débit 34 kbps
Langue English
Titre English PGS
Display Title English (PGS)
Média
Durée 1:46:56
Débit 15496 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MKV
Video Profile main
Partie
Durée 1:46:56
File FILM.2017.1080p.BluRay.MULTi.VFF.VFQ.x265.HEVC.Dolby.Atmos.7.1.DD.5.1-GuS2SuG.mkv
Size 11.58 GB
Container MKV
Video Profile main
Codec HEVC
Débit 14216 kbps
Bit Depth 8
Color Range tv
Color Space bt709
Color Trc bt709
Height 1080
Level 4.0
Profile main
Ref Frames 1
Width 1920
Codec TRUEHD
Chaînes 7.1
Débit 4131 kbps
Langue English
Audio Channel Layout 7.1
Bit Depth 24
Titre English Dolby Atmos 7.1
Display Title English (TRUEHD 7.1)
Codec AC3
Chaînes 5.1
Débit 640 kbps
Langue Français
Audio Channel Layout 5.1(side)
Titre French (VFQ) Dolby Digital 5.1
Display Title Français (AC3 5.1)
Codec AC3
Chaînes 5.1
Débit 640 kbps
Langue Français
Titre French (VFF) Dolby Digital 5.1
Codec PGS
Débit 22 kbps
Langue English
Titre English
Codec PGS
Débit 28 kbps
Langue English
Titre English (SDH)
Forcé(e) true
Codec SRT
Langue Français
Titre French Forced
Display Title Français (SRT Forcé(e))
Codec SRT
Langue Français
Titre French
Média
Durée 58:40
Débit 10605 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MKV
Video Profile main
Partie
Durée 58:40
FileFILM.S07E1.1080p.MULTi.BluRay.x265-Spy_Lekas.mkv
Size 4.35 GB
Container MKV
Video Profile main
Codec HEVC
Débit 10157 kbps
Langue English
Bit Depth 8
Color Range tv
Height 1080
Level 5.1
Profile main
Ref Frames 1
Titre FILM.S07E1.1080p.MULTi.BluRay.x265-Spy_Lekas
Width 1920
Codec TRUEHD
Chaînes 8
Langue English
Bit Depth 24
Titre TrueHD Atmos, English, 7.1
Codec AC3
Chaînes 6
Débit 448 kbps
Langue Français
Titre AC-3, French, 5.1
Codec PGS
Langue Français
Titre PGS FR
Forcé(e) true
Codec PGS
Langue Français
Titre PGS FR forcés
Display Title Français (PGS Forcé(e))
Codec PGS
Langue English
Titre PGS EN
Codec SRT
Langue Français
Titre SRT FR
Forcé(e) true
Codec SRT
Langue Français
Titre SRT FR forcés
Média
Durée 2:22:49
Débit 7733 kbps
Width 1920
Height 800
Aspect Ratio 2.35
Container MKV
Audio Profile ma
Video Profile main
Partie
Durée 2:22:49
File FILM.2012.MULTI.VFF.Blu-Ray.1080.x265.HEVC.DTS-HDMA-STARLIGHTER.mkv
Size 7.71 GB
Audio Profile ma
Container MKV
Video Profile main
Codec HEVC
Débit 4661 kbps
Bit Depth 8
Color Range tv
Color Space bt709
Color Trc bt709
Height 800
Level 4.0
Profile main
Ref Frames 1
Width 1920
Codec DCA
Chaînes 5.1
Débit 1536 kbps
Langue Français
Bit Depth 16
Profile dts
Titre TrueFrench DTS [1509kbps]
Display Title Français (DTS 5.1)
Codec DCA
Chaînes 7.1
Débit 1536 kbps
Langue English
Bit Depth 16
Profile ma
Titre English DTS-HDMA [unknown/1509kbps VBR Lossless]
Display Title English (DTS-HD MA 7.1)
Forcé(e) true
Codec VOBSUB
Langue Français
Titre French [FORCED]
Display Title Français (VOBSUB Forcé(e))
Codec VOBSUB
Débit 2 kbps
Langue Français
Titre French [COMPLETE]
Display Title Français (VOBSUB)
Média
Durée 2:16:04
Débit 7867 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MKV
Video Profile main
Partie
Durée 2:16:04
File FILM.Truefrench.x265-HEVC.1080p.Bluray.AC3-moon.mkv
Size 7.48 GB
Container MKV
Video Profile main
Codec HEVC
Débit 7227 kbps
Bit Depth 8
Color Range tv
Color Space bt709
Color Trc bt709
Height 1080
Level 4.0
Profile main
Ref Frames 1
Width 1920
Codec AC3
Chaînes 5.1
Débit 640 kbps
Langue Français
Titre VFF
Forcé(e) true
Codec SRT
Langue Français
Titre FR Forcés
Codec SRT
Langue Français
Titre FR Complet
Codec PGS
Débit 11 kbps
Langue Français
Titre FR Complet
SOME EXAMPLE WORKING
Média
Durée 2:13:59
Débit 12823 kbps
Width 1920
Height 800
Aspect Ratio 2.35
Container MKV
Audio Profile dts
Video Profile high
Partie
Durée 2:13:59
File FILM.2018.UNRATED.MULTi.VFF.1080p.BluRay.x264-ANONA.mkv
Size 12.00 GB
Audio Profile dts
Container MKV
Video Profile high
Codec H264
Débit 10519 kbps
Langue English
Bit Depth 8
Chroma Location left
Color Range tv
Color Space bt709
Color Trc bt709
Height 800
Level 4.1
Profile high
Ref Frames 5
Scan Type progressive
Width 1920
Display Title 1080p (H.264)
Codec DCA
Chaînes 5.1
Débit 768 kbps
Langue Français
Bit Depth 24
Profile dts
Codec DCA
Chaînes 5.1
Débit 1536 kbps
Langue English
Bit Depth 24
Profile dts
Display Title English (DTS 5.1)
Codec SRT
Langue Français
Titre Forced
Codec SRT
Langue Français
Titre Full
Codec SRT
Langue English
Titre Full
Display Title English (SRT)
Média
Durée 2:02:40
Débit 11486 kbps
Width 1920
Height 800
Aspect Ratio 2.35
Container MKV
Audio Profile dts
Video Profile high
Partie
Durée 2:02:40
FILM.2013.MULTI.1080p.BluRay.x264-Thursday16th.mkv
Size 9.84 GB
Audio Profile dts
Container MKV
Video Profile high
Codec H264
Débit 8414 kbps
Langue English
Bit Depth 8
Frame Rate 24 fps
Height 800
Level 4.0
Profile high
Ref Frames 5
Width 1920
Codec DCA
Chaînes 5.1
Débit 1536 kbps
Langue Français
Bit Depth 24
Profile dts
Titre FR
Codec DCA
Chaînes 5.1
Débit 1536 kbps
Langue English
Bit Depth 24
Profile dts
Titre EN
Codec SRT
Langue Français
Titre FRF
Codec SRT
Langue Français
Titre FR
Média
Durée 1:20:49
Débit 18349 kbps
Width 1920
Height 1040
Aspect Ratio 1.85
Container MKV
Audio Profile ma
Video Profile high
Partie
Durée 1:20:49
File FILM.2016.FRENCH.1080p.Bluray.DTS.HDMA.x264-MeMyI.mkv
Size 10.36 GB
Audio Profile ma
Container MKV
Video Profile high
Codec H264
Débit 16045 kbps
Langue Français
Bit Depth 8
Height 1040
Level 4.1
Profile high
Ref Frames 4
Titre La.Tortue.Rouge.2016.FRENCH.1080p.Bluray.DTS.HDMA.x264-MeMyI
Width 1920
Codec DCA
Chaînes 5.1
Débit 1536 kbps
Langue Français
Bit Depth 24
Profile ma
Titre DTS Master Audio, French, 5.1
Display Title Français (DTS-HD MA 5.1)
Codec DCA
Chaînes Stéréo
Débit 768 kbps
Langue Français
Audio Channel Layout stereo
Bit Depth 24
Profile ma
Titre DTS Master Audio, French, 2.0 - Audiodescription
Display Title Français (DTS-HD MA Stereo)
Codec PGS
Langue Français
Titre PGS FR malentendant
You must be using the Safari web browser. Use ‘show page source code’ in this case to see the XML.
But your mediainfo above provided enough clues, I think.
All your non-working files are using the HEVC (H.265) video codec
whereas all your working files are using the AVC (H.264) video codec.
Are you using subtitles?
Do the results change if you disable subtitles prior to pressing playback?
THANK YOU dry much for all this help :
NOT WORKING
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="2" librarySectionTitle="Séries TV" librarySectionUUID="80455803-5b9a-480c-8cdf-9930e9461bd4" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1537530240">
<Video ratingKey="486" key="/library/metadata/486" parentRatingKey="485" grandparentRatingKey="484" guid="com.plexapp.agents.thetvdb://121361/7/1?lang=fr" librarySectionTitle="Séries TV" librarySectionID="2" librarySectionKey="/library/sections/2" type="episode" title="Peyredragon" grandparentKey="/library/metadata/484" parentKey="/library/metadata/485" grandparentTitle="Game of Thrones" parentTitle="Saison 7" contentRating="TV-MA" summary="Jon Snow organise la défense du Nord. Cersei tente de rendre la lutte moins inégale. Samwell découvre des informations cruciales. Daenerys rentre chez elle." index="1" parentIndex="7" rating="8.2" viewOffset="220000" lastViewedAt="1539858953" year="2017" thumb="/library/metadata/486/thumb/1539829194" art="/library/metadata/484/art/1539829200" parentThumb="/library/metadata/485/thumb/1539829199" grandparentThumb="/library/metadata/484/thumb/1539829200" grandparentArt="/library/metadata/484/art/1539829200" grandparentTheme="/library/metadata/484/theme/1539829200" duration="3520192" originallyAvailableAt="2017-07-16" addedAt="1539829119" updatedAt="1539829194" chapterSource="media">
<Media videoResolution="1080" id="1353" duration="3520192" bitrate="10605" width="1920" height="1080" aspectRatio="1.78" audioChannels="8" audioCodec="truehd" videoCodec="hevc" container="mkv" videoFrameRate="24p" videoProfile="main">
<Part accessible="1" exists="1" id="1354" key="/library/parts/1354/1539828429/file.mkv" duration="3520192" file="/FILMS/Game.of.Thrones.S07.1080p.MULTi.BluRay.x265.TRUEHD.ATMOS-Spy_Lekas/Game.of.Thrones.S07E1.1080p.MULTi.BluRay.x265-Spy_Lekas.mkv" size="4666254422" container="mkv" videoProfile="main">
<Stream id="2838" streamType="1" default="1" codec="hevc" index="0" bitrate="10157" language="English" languageCode="eng" bitDepth="8" chromaSubsampling="4:2:0" colorRange="tv" frameRate="23.976" height="1080" level="153" profile="main" refFrames="1" title="Game of Thrones.S07E1.1080p.MULTi.BluRay.x265-Spy_Lekas" width="1920" displayTitle="1080p (HEVC Main)"/>
<Stream id="2839" streamType="2" selected="1" default="1" codec="truehd" index="1" channels="8" language="English" languageCode="eng" audioChannelLayout="7.1" bitDepth="24" samplingRate="48000" title="TrueHD Atmos, English, 7.1" displayTitle="English (TRUEHD 7.1)"/>
<Stream id="2840" streamType="2" codec="ac3" index="2" channels="6" bitrate="448" language="Français" languageCode="fre" audioChannelLayout="5.1(side)" samplingRate="48000" title="AC-3, French, 5.1" displayTitle="Français (AC3 5.1)"/>
<Stream id="2841" streamType="3" selected="1" default="1" codec="pgs" index="3" language="Français" languageCode="fre" headerCompression="1" title="PGS FR" displayTitle="Français (PGS)"/>
<Stream id="2842" streamType="3" forced="1" codec="pgs" index="4" language="Français" languageCode="fre" headerCompression="1" title="PGS FR forcés" displayTitle="Français (PGS Forcé(e))"/>
<Stream id="2843" streamType="3" codec="pgs" index="5" language="English" languageCode="eng" headerCompression="1" title="PGS EN" displayTitle="English (PGS)"/>
<Stream id="2844" streamType="3" codec="srt" index="6" language="Français" languageCode="fre" title="SRT FR" displayTitle="Français (SRT)"/>
<Stream id="2845" streamType="3" forced="1" codec="srt" index="7" language="Français" languageCode="fre" title="SRT FR forcés" displayTitle="Français (SRT Forcé(e))"/>
</Part>
</Media>
<Director id="1949" filter="director=1949" tag="Jeremy Podeswa"/>
<Writer id="1948" filter="writer=1948" tag="David Benioff"/>
<Writer id="1947" filter="writer=1947" tag="D.B. Weiss"/>
<Extras size="0"> </Extras>
</Video>
</MediaContainer>
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="1" librarySectionTitle="Films" librarySectionUUID="c4e1077e-6204-4672-b541-73f8f8565afd" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1537530240">
<Video ratingKey="411" key="/library/metadata/411" guid="com.plexapp.agents.imdb://tt1951265?lang=fr" librarySectionTitle="Films" librarySectionID="1" librarySectionKey="/library/sections/1" studio="Lionsgate" type="movie" title="The Hunger Games: Mockingjay - Part 1" titleSort="Hunger Games: Mockingjay - Part 1" originalTitle="The Hunger Games: Mockingjay - Part 1" contentRating="PG-13" summary="Katniss Everdeen s’est réfugiée dans le District 13 après avoir détruit à jamais l’arène et les Jeux. Sous le commandement de la Présidente Coin, chef du district, et suivant les conseils de ses amis en qui elle a toute confiance, Katniss déploie ses ailes pour devenir le symbole de la rébellion. Elle va se battre pour sauver Peeta et libérer le pays tout entier, à qui son courage a redonné espoir." rating="6.7" audienceRating="7.1" viewOffset="106000" lastViewedAt="1539828870" year="2014" tagline="Son courage changera le monde." thumb="/library/metadata/411/thumb/1539818409" art="/library/metadata/411/art/1539818409" duration="7386504" originallyAvailableAt="2014-11-18" addedAt="1539818324" updatedAt="1539818409" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" hasPremiumExtras="1" hasPremiumPrimaryExtra="1" ratingImage="rottentomatoes://image.rating.ripe">
<Media videoResolution="1080" id="1150" duration="7386504" bitrate="10136" width="1920" height="800" aspectRatio="2.35" audioChannels="8" audioCodec="dca-ma" videoCodec="hevc" container="mkv" videoFrameRate="24p" audioProfile="ma" videoProfile="main">
<Part accessible="1" exists="1" id="1151" key="/library/parts/1151/1539817594/file.mkv" duration="7386504" file="/FILMS/Hunger.Games.la.Revolte.part.1.2014.MULTI.VFF.Blu-Ray.1080.x265.HEVC.DTS-HDMA-STARLIGHTER.mkv" size="9358508978" audioProfile="ma" container="mkv" videoProfile="main">
<Stream id="2599" streamType="1" default="1" codec="hevc" index="0" bitrate="7064" bitDepth="8" chromaSubsampling="4:2:0" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.969" height="800" level="120" profile="main" refFrames="1" width="1920" displayTitle="1080p (HEVC Main)"/>
<Stream id="2600" streamType="2" codec="dca" index="1" channels="8" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="7.1" bitDepth="24" profile="ma" samplingRate="48000" title="English DTS-HDMA [unknown/1509kbps VBR Lossless]" displayTitle="English (DTS-HD MA 7.1)"/>
<Stream id="2601" streamType="2" selected="1" codec="dca" index="2" channels="6" bitrate="1536" language="Français" languageCode="fre" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" samplingRate="48000" title="English DTS [1509kbps]" displayTitle="Français (DTS 5.1)"/>
<Stream id="2602" streamType="3" selected="1" default="1" forced="1" codec="vobsub" index="3" bitrate="0" language="Français" languageCode="fre" headerCompression="1" title="French [FORCED]" displayTitle="Français (VOBSUB Forcé(e))"/>
<Stream id="2603" streamType="3" codec="vobsub" index="4" bitrate="3" language="Français" languageCode="fre" headerCompression="1" title="French [COMPLETE]" displayTitle="Français (VOBSUB)"/>
</Part>
</Media>
<Genre id="23" filter="genre=23" tag="Action"/>
<Genre id="132" filter="genre=132" tag="Adventure"/>
<Genre id="133" filter="genre=133" tag="Sci-Fi"/>
<Genre id="25" filter="genre=25" tag="Thriller"/>
<Director id="1308" filter="director=1308" tag="Francis Lawrence"/>
<Writer id="1356" filter="writer=1356" tag="Danny Strong"/>
<Writer id="1357" filter="writer=1357" tag="Peter Craig"/>
<Producer id="1286" filter="producer=1286" tag="Nina Jacobson"/>
<Producer id="1285" filter="producer=1285" tag="Jon Kilik"/>
<Country id="136" filter="country=136" tag="USA"/>
<Role id="1259" filter="actor=1259" tag="Jennifer Lawrence" role="Katniss Everdeen" thumb="http://image.tmdb.org/t/p/original/naZyy9IqAQDaAbr1kYShLdg6aPR.jpg"/>
<Role id="1262" filter="actor=1262" tag="Josh Hutcherson" role="Peeta Mellark" thumb="http://image.tmdb.org/t/p/original/9VpZOzJnmuajtAdBizBhQBnjFrG.jpg"/>
<Role id="1270" filter="actor=1270" tag="Liam Hemsworth" role="Gale Hawthorne" thumb="http://image.tmdb.org/t/p/original/eVeBiqx1vTsd1QCHOr24Cf13wb.jpg"/>
<Role id="1284" filter="actor=1284" tag="Woody Harrelson" role="Haymitch Abernathy" thumb="http://image.tmdb.org/t/p/original/1ecdooAHICUhCZKKEKlFtccEmTU.jpg"/>
<Role id="1250" filter="actor=1250" tag="Donald Sutherland" role="President Snow" thumb="http://image.tmdb.org/t/p/original/tPLVaPjxEscGPKS3ieByloa8Mqj.jpg"/>
<Role id="1337" filter="actor=1337" tag="Philip Seymour Hoffman" role="Plutarch Heavensbee" thumb="http://image.tmdb.org/t/p/original/vEDJukK8CjIsA0DjNFhoT88TvzS.jpg"/>
<Role id="263" filter="actor=263" tag="Julianne Moore" role="President Alma Coin" thumb="http://image.tmdb.org/t/p/original/v2FcWGiiuvl6P7NV0966jNL09uh.jpg"/>
<Role id="1283" filter="actor=1283" tag="Willow Shields" role="Primrose Everdeen" thumb="http://image.tmdb.org/t/p/original/c9Zna579entVQBdx7kTtKJjl9CB.jpg"/>
<Role id="1339" filter="actor=1339" tag="Sam Claflin" role="Finnick Odair" thumb="http://image.tmdb.org/t/p/original/bfP3RHfFEwMhW9RS95c73MepGsj.jpg"/>
<Role id="1252" filter="actor=1252" tag="Elizabeth Banks" role="Effie Trinket" thumb="http://image.tmdb.org/t/p/original/t6sfUzvQkMZu3wh4LMNBFxEmiDy.jpg"/>
<Role id="1186" filter="actor=1186" tag="Mahershala Ali" role="Boggs" thumb="http://image.tmdb.org/t/p/original/waUvfhRSpVe4vk0hGVcsr0dhpK6.jpg"/>
<Role id="1324" filter="actor=1324" tag="Jena Malone" role="Johanna Mason" thumb="http://image.tmdb.org/t/p/original/p4IvynJ0U69WqiaW8V2UydcNVw1.jpg"/>
<Role id="1323" filter="actor=1323" tag="Jeffrey Wright" role="Beetee" thumb="http://image.tmdb.org/t/p/original/wBh9rwK3aRr1hCrSRLxxPHKzGeU.jpg"/>
<Role id="1274" filter="actor=1274" tag="Paula Malcomson" role="Katniss' Mother" thumb="http://image.tmdb.org/t/p/original/mqiiy0HXExPYaIczPxWFRDGqhwA.jpg"/>
<Role id="1279" filter="actor=1279" tag="Stanley Tucci" role="Caesar Flickerman" thumb="http://image.tmdb.org/t/p/original/omGlTJF2IW5r3L3c5y0qkCt3hFr.jpg"/>
<Role id="455" filter="actor=455" tag="Natalie Dormer" role="Cressida" thumb="http://image.tmdb.org/t/p/original/8piDfs6oyRKSvrRv4RfUWEs3I0n.jpg"/>
<Role id="1365" filter="actor=1365" tag="Evan Ross" role="Messalla" thumb="http://image.tmdb.org/t/p/original/2qNAI0zGfnsSbEAuzlbZvcij5VF.jpg"/>
<Role id="1363" filter="actor=1363" tag="Elden Henson" role="Pollux" thumb="http://image.tmdb.org/t/p/original/nX2c32A2ppiw5IC86zUM4JTLpoz.jpg"/>
<Role id="1389" filter="actor=1389" tag="Wes Chatham" role="Castor" thumb="http://image.tmdb.org/t/p/original/vWaxlHbGnJy7dQ0Se7cSUOqi9aR.jpg"/>
<Role id="1384" filter="actor=1384" tag="Sarita Choudhury" role="Egeria" thumb="http://image.tmdb.org/t/p/original/2YNa0h5lCq5lMYyGFLJmSe09ZeW.jpg"/>
<Role id="1341" filter="actor=1341" tag="Stef Dawson" role="Annie Cresta" thumb="http://image.tmdb.org/t/p/original/jHAd1NwUfl5uYfVj6fi9N1TswDD.jpg"/>
<Role id="1381" filter="actor=1381" tag="Patina Miller" role="Commander Paylor" thumb="http://image.tmdb.org/t/p/original/uLGWqDo0r0JdE8JbY7M8tyzG2BH.jpg"/>
<Role id="1382" filter="actor=1382" tag="Robert Knepper" role="Antonius" thumb="http://image.tmdb.org/t/p/original/w40AttR4OPQvjYyTVanq5Rm5iOb.jpg"/>
<Role id="1361" filter="actor=1361" tag="Caitlin Fowler" role="D8 Another Patient" thumb="http://image.tmdb.org/t/p/original/ov9MDO7gUXdjKt7jvwUpRoo0HQn.jpg"/>
<Role id="1367" filter="actor=1367" tag="Jada Taylor" role="D8 Female Patient" thumb="http://image.tmdb.org/t/p/original/k46yfyAyNE9j3q9oVJrlhknX8WY.jpg"/>
<Role id="1380" filter="actor=1380" tag="Nicholas Pryor" role="D8 Male Patient" thumb="http://image.tmdb.org/t/p/original/jqJVM5jEVq2Xqi8G5fO0iiEnd5O.jpg"/>
<Role id="1164" filter="actor=1164" tag="Donna Biscoe" role="D8 Old Woman" thumb="http://image.tmdb.org/t/p/original/a8wTPPXmRDEkLKbYGvM6pqnIfXB.jpg"/>
<Role id="1378" filter="actor=1378" tag="Michael Garza" role="Eddy" thumb="http://image.tmdb.org/t/p/original/iL5Ld4QZSwthdB8aupnjlrcubhk.jpg"/>
<Role id="1318" filter="actor=1318" tag="Erika Bierman" role="Snow's Granddaughter" thumb="http://image.tmdb.org/t/p/original/r5zw8kHfyDTk7zNd5pm2nkKE3CL.jpg"/>
<Role id="1246" filter="actor=1246" tag="Bill Bennett" role="District 13 Engineer" thumb="http://image.tmdb.org/t/p/original/zKF8BvSoapHVLgXyCddFZ0gUQdX.jpg"/>
<Role id="1383" filter="actor=1383" tag="Rus Blackwell" role="D13 Systems Operator" thumb="http://image.tmdb.org/t/p/original/xYMkiZQuoramEeabUPnrtiS19vn.jpg"/>
<Role id="1387" filter="actor=1387" tag="Stevie Ray Dallimore" role="D13 Systems Operator #2" thumb="http://image.tmdb.org/t/p/original/2NG5BmVpxr6mRexZJwU047XzHXb.jpg"/>
<Role id="1360" filter="actor=1360" tag="Breann Couch" role="D13 Systems Operator #3" thumb="http://image.tmdb.org/t/p/original/lkYGZaZirbXggdl374M0CXqaGX2.jpg"/>
<Role id="1370" filter="actor=1370" tag="Jennifer Cocker" role="District 13 Citizen" thumb="http://image.tmdb.org/t/p/original/nSqOpAMjjZEL7OVthdbqAiI8kb4.jpg"/>
<Role id="1377" filter="actor=1377" tag="Marshall Choka" role="District 13 Citizen" thumb="http://image.tmdb.org/t/p/original/55gEVgC7oMtYvCDtppWDftI15LM.jpg"/>
<Role id="1372" filter="actor=1372" tag="Jordan Woods-Robinson" role="Snow's Stylist #1" thumb="http://image.tmdb.org/t/p/original/cVVMHFhoSRZnpxrEp2Rj0dOnjuV.jpg"/>
<Role id="1374" filter="actor=1374" tag="Katie Sawhill" role="Orderly" thumb="http://image.tmdb.org/t/p/original/dkVvVFVx18HquvBE8vEGLxeI9ro.jpg"/>
<Role id="1369" filter="actor=1369" tag="Jenique Bennett" role="Rescue Hovercraft Pilot" thumb="http://image.tmdb.org/t/p/original/rSgBDfOQvA2caeJNvCO5RCLg8WD.jpg"/>
<Role id="1362" filter="actor=1362" tag="Charles Kronmuller" role="Pilot" thumb="http://image.tmdb.org/t/p/original/lfJ2g2gdhtt0rOwwijBfYE5yiYy.jpg"/>
<Role id="1388" filter="actor=1388" tag="Tyler Lee Allen" role="President Snow's Security (uncredited)" thumb="http://image.tmdb.org/t/p/original/qqrVmsqzbJdop0Dns8Xan2j2esd.jpg"/>
<Role id="1373" filter="actor=1373" tag="Jordanne Calvin" role="Stair Runner District 13 (uncredited)" thumb="http://image.tmdb.org/t/p/original/wwhIUuArmutObRwnBspEk0qK13l.jpg"/>
<Role id="1368" filter="actor=1368" tag="Jasmine Ahnie" role="District 8 Hospital Patient (uncredited)" thumb="http://image.tmdb.org/t/p/original/rNJa4EKbhWliEEE1giPceySOtIF.jpg"/>
<Role id="1359" filter="actor=1359" tag="Brayden Patterson" role="District 13 Citizen (uncredited)" thumb="http://image.tmdb.org/t/p/original/cJovT2FBrS2oorUgaIyEiNZS87G.jpg"/>
<Role id="1364" filter="actor=1364" tag="Emma Elle Roberts" role="District 13 (uncredited)" thumb="http://image.tmdb.org/t/p/original/g1Te1r5QIV13jhB8llBPD3Zogob.jpg"/>
<Role id="1358" filter="actor=1358" tag="A.J. Sexton" role="District 13 Citizen (uncredited)" thumb="http://image.tmdb.org/t/p/original/ekIZ6c2jhGKvem2m4C8OHGbH3lD.jpg"/>
<Role id="1340" filter="actor=1340" tag="Sarah Turner Holland" role="District 13 Citizen (uncredited)" thumb="http://image.tmdb.org/t/p/original/z0NfjC9Yw91LFtLcgZOa9XV8Ucs.jpg"/>
<Role id="1376" filter="actor=1376" tag="Lauren Henneberg" role="District 13 Citizen (uncredited)" thumb="http://image.tmdb.org/t/p/original/v4m3X5yPXXU9qmt1YULQo1TqHLO.jpg"/>
<Role id="1379" filter="actor=1379" tag="Molly Evensen" role="District 13 Citizen (uncredited)" thumb="http://image.tmdb.org/t/p/original/8PIVFVSZRyVsgCBRvxucFXAQUqj.jpg"/>
<Role id="1390" filter="actor=1390" tag="William Frasca" role="District 5 Rebel (uncredited)" thumb="http://image.tmdb.org/t/p/original/uklbKBjGhm9FXmHWd6NJ1n6Cv7A.jpg"/>
<Role id="1371" filter="actor=1371" tag="Joe Crosson" role="Peacekeeper (uncredited)" thumb="http://image.tmdb.org/t/p/original/npA2WAe88QClLGtw2LtMWsIL8yA.jpg"/>
<Role id="1366" filter="actor=1366" tag="Gregory Fears" role="Peacekeeper (uncredited)" thumb="http://image.tmdb.org/t/p/original/eYmWGZCgl9AKOJxagGTOQqYTtf6.jpg"/>
<Role id="1375" filter="actor=1375" tag="Kirk Crenshaw" role="Peacekeeper (uncredited)"/>
<Role id="1385" filter="actor=1385" tag="Stephen Mackenzie Brown" role="Beetee's Technician (uncredited)"/>
<Role id="1386" filter="actor=1386" tag="Stephen Vining" role="District 8 Rebel (uncredited)" thumb="http://image.tmdb.org/t/p/original/91vfg0OuwWhtz8LBeVu6PHUnEEF.jpg"/>
<Similar id="1303" filter="similar=1303" tag="The Hunger Games: Catching Fire"/>
<Similar id="1305" filter="similar=1305" tag="The Hunger Games: Mockingjay - Part 2"/>
<Similar id="1352" filter="similar=1352" tag="The Hunger Games"/>
<Similar id="1347" filter="similar=1347" tag="Divergent"/>
<Similar id="1350" filter="similar=1350" tag="Insurgent"/>
<Similar id="1353" filter="similar=1353" tag="The Maze Runner"/>
<Similar id="1396" filter="similar=1396" tag="The Hobbit: The Battle of the Five Armies"/>
<Similar id="1395" filter="similar=1395" tag="Maze Runner: The Scorch Trials"/>
<Similar id="1348" filter="similar=1348" tag="Frozen"/>
<Similar id="1351" filter="similar=1351" tag="Maleficent"/>
<Similar id="846" filter="similar=846" tag="X-Men: Days of Future Past"/>
<Similar id="1292" filter="similar=1292" tag="Harry Potter and the Deathly Hallows: Part 1"/>
<Similar id="1295" filter="similar=1295" tag="Harry Potter and the Half-Blood Prince"/>
<Similar id="1355" filter="similar=1355" tag="The Twilight Saga: New Moon"/>
<Similar id="1293" filter="similar=1293" tag="Harry Potter and the Deathly Hallows: Part 2"/>
<Similar id="1394" filter="similar=1394" tag="Lucy"/>
<Similar id="840" filter="similar=840" tag="The Hobbit: The Desolation of Smaug"/>
<Similar id="1354" filter="similar=1354" tag="The Twilight Saga: Eclipse"/>
<Similar id="1393" filter="similar=1393" tag="Allegiant"/>
<Similar id="1296" filter="similar=1296" tag="Harry Potter and the Order of the Phoenix"/>
</Video>
</MediaContainer>
<Video ratingKey="500" key="/library/metadata/500" guid="com.plexapp.agents.imdb://tt0359950?lang=fr" librarySectionTitle="Films" librarySectionID="1" librarySectionKey="/library/sections/1" studio="New Line Cinema" type="movie" title="The Secret Life of Walter Mitty" titleSort="Secret Life of Walter Mitty" originalTitle="The Secret Life of Walter Mitty" contentRating="PG" summary="Walter Mitty est un homme ordinaire, enfermé dans son quotidien, qui n’ose s’évader qu’à travers des rêves à la fois drôles et extravagants. Mais confronté à une difficulté dans sa vie professionnelle, Walter doit trouver le courage de passer à l'action dans le monde réel. Il embarque alors dans un périple incroyable, pour vivre une aventure bien plus riche que tout ce qu'il aurait pu imaginer jusqu’ici. Et qui devrait changer sa vie à jamais." rating="5.1" audienceRating="7.0" year="2013" tagline="Vivez l'impossible" thumb="/library/metadata/500/thumb/1539857782" art="/library/metadata/500/art/1539857782" duration="6874910" originallyAvailableAt="2013-12-18" addedAt="1539850296" updatedAt="1539857782" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" hasPremiumExtras="1" hasPremiumPrimaryExtra="1" ratingImage="rottentomatoes://image.rating.rotten">
<Media videoResolution="1080" id="1376" duration="6874910" bitrate="4211" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="aac" videoCodec="hevc" container="mkv" videoFrameRate="24p" audioProfile="lc" videoProfile="main">
<Part accessible="1" exists="1" id="1377" key="/library/parts/1377/1539854343/file.mkv" duration="6874910" file="/FILMS/La_Vie_Revee_De_Walter_Mitty.MULTi.x265.AAC.mkv" size="3619134286" audioProfile="lc" container="mkv" videoProfile="main">
<Stream id="2934" streamType="1" default="1" codec="hevc" index="0" bitrate="4211" language="English" languageCode="eng" bitDepth="8" chromaSubsampling="4:2:0" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.976" height="800" level="120" profile="main" refFrames="1" title="HEVC RF20" width="1920" displayTitle="1080p (HEVC Main)"/>
<Stream id="2935" streamType="2" selected="1" default="1" codec="aac" index="1" channels="6" bitrate="715" language="Français" languageCode="fre" audioChannelLayout="5.1" profile="lc" samplingRate="48000" title="Français AAC 5.1 768 Kbps" displayTitle="Français (AAC 5.1)"/>
<Stream id="2936" streamType="2" codec="aac" index="2" channels="6" bitrate="739" language="English" languageCode="eng" audioChannelLayout="5.1" profile="lc" samplingRate="48000" title="English AAC 5.1 768 Kbps" displayTitle="English (AAC 5.1)"/>
<Stream id="2937" streamType="3" codec="srt" index="3" bitrate="0" language="Français" languageCode="fre" title="Français SRT" displayTitle="Français (SRT)"/>
<Stream id="2938" streamType="3" codec="pgs" index="4" bitrate="26" language="Français" languageCode="fre" headerCompression="1" title="Francais PGS" displayTitle="Français (PGS)"/>
<Stream id="2939" streamType="3" codec="pgs" index="5" bitrate="34" language="English" languageCode="eng" headerCompression="1" title="English PGS" displayTitle="English (PGS)"/>
</Part>
</Media>
<Genre id="651" filter="genre=651" tag="Comedy"/>
<Genre id="299" filter="genre=299" tag="Drama"/>
<Genre id="609" filter="genre=609" tag="Fantasy"/>
<Genre id="403" filter="genre=403" tag="Romance"/>
<Director id="2120" filter="director=2120" tag="Ben Stiller"/>
<Writer id="2121" filter="writer=2121" tag="Steve Conrad"/>
<Producer id="2136" filter="producer=2136" tag="Ben Stiller"/>
<Producer id="2137" filter="producer=2137" tag="John Goldwyn"/>
<Producer id="2138" filter="producer=2138" tag="Samuel Goldwyn Jr."/>
<Producer id="2139" filter="producer=2139" tag="Stuart Cornfeld"/>
<Role id="2126" filter="actor=2126" tag="Ben Stiller" role="Walter Mitty" thumb="http://image.tmdb.org/t/p/original/twp3oBAcOIZlwYTxzNgac3YsCPu.jpg"/>
<Role id="2131" filter="actor=2131" tag="Kristen Wiig" role="Cheryl Melhoff" thumb="http://image.tmdb.org/t/p/original/oddvykQHx71hEZlvKinCzB3Vcfh.jpg"/>
<Role id="2132" filter="actor=2132" tag="Patton Oswalt" role="Todd Maher" thumb="http://image.tmdb.org/t/p/original/dq3uNmTB7r8XTtadV3OD3N7LqV6.jpg"/>
<Role id="2134" filter="actor=2134" tag="Shirley MacLaine" role="Edna Mitty" thumb="http://image.tmdb.org/t/p/original/faG5S4EOVaGHNf1CwZryGcHCE4e.jpg"/>
<Role id="2122" filter="actor=2122" tag="Adam Scott" role="Ted Hendricks" thumb="http://image.tmdb.org/t/p/original/6vLiih0N5s7JOYyRgclxbnOMzI9.jpg"/>
<Role id="2130" filter="actor=2130" tag="Kathryn Hahn" role="Odessa Mitty" thumb="http://image.tmdb.org/t/p/original/9sVllAKfEls3SJD3GoPm2JEZoa5.jpg"/>
<Role id="2133" filter="actor=2133" tag="Sean Penn" role="Sean O'Connell" thumb="http://image.tmdb.org/t/p/original/f2uy1zq0qmtLBpsr6N9uQ8FktOr.jpg"/>
<Role id="2135" filter="actor=2135" tag="Terence Bernie Hines" role="Gary Mannheim" thumb="http://image.tmdb.org/t/p/original/uMC8ILPk0h2fN6ZM8N7kHq8Uxym.jpg"/>
<Role id="2128" filter="actor=2128" tag="Gurdeep Singh" role="Cab Driver" thumb="http://image.tmdb.org/t/p/original/dCrHZdnH1vxLuWdyatORaB9ggYc.jpg"/>
<Role id="2124" filter="actor=2124" tag="Alex Anfanger" role="Ted's Toner Box Associate" thumb="http://image.tmdb.org/t/p/original/fgYr1YJKpDBQBMESsdFDfrTC4xv.jpg"/>
<Role id="2127" filter="actor=2127" tag="Gary Wilmes" role="Walter's Dad" thumb="http://image.tmdb.org/t/p/original/3XWPI9tun5m6kyAXukldqFmOGRK.jpg"/>
<Role id="2123" filter="actor=2123" tag="Adrian Martinez" role="Hernando" thumb="http://image.tmdb.org/t/p/original/zDnnzak4BLb5dNc9taqLNprkRvw.jpg"/>
<Role id="2129" filter="actor=2129" tag="Jon Daly" role="Tim Naughton" thumb="http://image.tmdb.org/t/p/original/prpAj1fEUXOF1ydKbuT0I4rzAxm.jpg"/>
<Role id="2125" filter="actor=2125" tag="Asta Paredes" role="Pedestrian" thumb="http://image.tmdb.org/t/p/original/8Yp2mddzqEMaT2fXrLSb9KNwCV1.jpg"/>
<Similar id="482" filter="similar=482" tag="Captain Phillips"/>
<Similar id="909" filter="similar=909" tag="Ender's Game"/>
<Similar id="481" filter="similar=481" tag="American Hustle"/>
<Similar id="2154" filter="similar=2154" tag="The Monuments Men"/>
<Similar id="2156" filter="similar=2156" tag="Transcendence"/>
<Similar id="483" filter="similar=483" tag="Dallas Buyers Club"/>
<Similar id="2144" filter="similar=2144" tag="Anchorman 2: The Legend Continues"/>
<Similar id="2143" filter="similar=2143" tag="A Million Ways to Die in the West"/>
<Similar id="2151" filter="similar=2151" tag="Saving Mr. Banks"/>
<Similar id="2155" filter="similar=2155" tag="The World's End"/>
<Similar id="908" filter="similar=908" tag="Elysium"/>
<Similar id="2157" filter="similar=2157" tag="Yes Man"/>
<Similar id="2145" filter="similar=2145" tag="Chef"/>
<Similar id="2150" filter="similar=2150" tag="Rush"/>
<Similar id="2149" filter="similar=2149" tag="Noah"/>
<Similar id="2147" filter="similar=2147" tag="Kick-Ass 2"/>
<Similar id="2152" filter="similar=2152" tag="Super 8"/>
<Similar id="2153" filter="similar=2153" tag="The Internship"/>
<Similar id="2148" filter="similar=2148" tag="Last Vegas"/>
<Similar id="2146" filter="similar=2146" tag="Don Jon"/>
</Video>
</MediaContainer>
WORKING :
<Video ratingKey="87" key="/library/metadata/87" guid="com.plexapp.agents.imdb://tt4154756?lang=fr" librarySectionTitle="Films" librarySectionID="1" librarySectionKey="/library/sections/1" studio="Marvel Studios" type="movie" title="Avengers: Infinity War" originalTitle="Avengers: Infinity War" contentRating="PG-13" summary="Les Avengers et leurs alliés devront être prêts à tout sacrifier pour neutraliser le redoutable Thanos avant que son attaque éclair ne conduise à la destruction complète de l’univers." rating="8.4" audienceRating="9.1" viewOffset="347000" lastViewedAt="1539859138" year="2018" thumb="/library/metadata/87/thumb/1539853066" art="/library/metadata/87/art/1539853066" duration="8961248" originallyAvailableAt="2018-04-25" addedAt="1539716363" updatedAt="1539853066" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" hasPremiumExtras="1" hasPremiumPrimaryExtra="1" ratingImage="rottentomatoes://image.rating.ripe">
<Media videoResolution="1080" id="240" duration="8961248" bitrate="12464" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="eac3" videoCodec="h264" container="mkv" videoFrameRate="24p" videoProfile="high">
<Part accessible="1" exists="1" id="240" key="/library/parts/240/1539722889/file.mkv" duration="8961248" file="/FILMS/Avengers.Infinity.War.2018.MULTi.VFF.1080p.BluRay.x264-ANONA.mkv" size="13961883304" container="mkv" videoProfile="high">
<Stream id="510" streamType="1" default="1" codec="h264" index="0" bitrate="10416" language="English" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.976" hasScalingMatrix="0" height="800" level="41" profile="high" refFrames="5" scanType="progressive" width="1920" displayTitle="1080p (H.264)"/>
<Stream id="511" streamType="2" selected="1" default="1" codec="eac3" index="1" channels="6" bitrate="512" language="Français" languageCode="fre" audioChannelLayout="5.1(side)" samplingRate="48000" displayTitle="Français (EAC3 5.1)"/>
<Stream id="512" streamType="2" codec="dca" index="2" channels="6" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" samplingRate="48000" displayTitle="English (DTS 5.1)"/>
<Stream id="513" streamType="3" default="1" codec="srt" index="3" language="Français" languageCode="fre" title="Forced" displayTitle="Français (SRT)"/>
<Stream id="514" streamType="3" codec="srt" index="4" language="Français" languageCode="fre" title="Full" displayTitle="Français (SRT)"/>
<Stream id="515" streamType="3" codec="srt" index="5" language="English" languageCode="eng" title="Full" displayTitle="English (SRT)"/>
</Part>
</Media>
<Director id="557" filter="director=557" tag="Joe Russo"/>
<Director id="556" filter="director=556" tag="Anthony Russo"/>
<Writer id="559" filter="writer=559" tag="Stephen McFeely"/>
<Writer id="558" filter="writer=558" tag="Christopher Markus"/>
<Producer id="135" filter="producer=135" tag="Kevin Feige"/>
<Role id="595" filter="actor=595" tag="Robert Downey Jr." role="Tony Stark / Iron Man" thumb="http://image.tmdb.org/t/p/original/1YjdSym1jTG7xjHSI0yGGWEsw5i.jpg"/>
<Role id="438" filter="actor=438" tag="Chris Hemsworth" role="Thor Odinson" thumb="http://image.tmdb.org/t/p/original/lrhth7yK9p3vy6p7AabDUM1THKl.jpg"/>
<Role id="586" filter="actor=586" tag="Mark Ruffalo" role="Bruce Banner / Hulk" thumb="http://image.tmdb.org/t/p/original/isQ747u0MU8U9gdsNlPngjABclH.jpg"/>
<Role id="570" filter="actor=570" tag="Chris Evans" role="Steve Rogers / Captain America" thumb="http://image.tmdb.org/t/p/original/kRlx7PxXkom7Daj8Z2HmcbPQB1o.jpg"/>
<Role id="390" filter="actor=390" tag="Scarlett Johansson" role="Natasha Romanoff / Black Widow" thumb="http://image.tmdb.org/t/p/original/tHMgW7Pg0Fg6HmB8Kh8Ixk6yxZw.jpg"/>
<Role id="574" filter="actor=574" tag="Don Cheadle" role="James 'Rhodey' Rhodes / War Machine" thumb="http://image.tmdb.org/t/p/original/b1EVJWdFn7a75qVYJgwO87W2TJU.jpg"/>
<Role id="564" filter="actor=564" tag="Benedict Cumberbatch" role="Stephen Strange / Doctor Strange" thumb="http://image.tmdb.org/t/p/original/wz3MRiMmoz6b5X3oSzMRC9nLxY1.jpg"/>
<Role id="604" filter="actor=604" tag="Tom Holland" role="Piter Parker / Spider-Man" thumb="http://image.tmdb.org/t/p/original/hMp5y4Nro5pv4Nawyt3Ld9TsKfO.jpg"/>
<Role id="65" filter="actor=65" tag="Chadwick Boseman" role="T'Challa / Black Panther" thumb="http://image.tmdb.org/t/p/original/znyHJBN6r0cONV17R26U31R6VqR.jpg"/>
<Role id="608" filter="actor=608" tag="Zoe Saldana" role="Gamora" thumb="http://image.tmdb.org/t/p/original/ofNrWiA2KDdqiNxFTLp51HcXUlp.jpg"/>
<Role id="582" filter="actor=582" tag="Karen Gillan" role="Nebula" thumb="http://image.tmdb.org/t/p/original/b6rSmkcM3XvSxCb3aLEP8JaG07q.jpg"/>
<Role id="603" filter="actor=603" tag="Tom Hiddleston" role="Loki" thumb="http://image.tmdb.org/t/p/original/qB1lHPFBPIzw6I7EvsciZ5wyUNS.jpg"/>
<Role id="592" filter="actor=592" tag="Paul Bettany" role="Vision" thumb="http://image.tmdb.org/t/p/original/1zmr8C7TCqsoCjDVKJycVp2wWyf.jpg"/>
<Role id="575" filter="actor=575" tag="Elizabeth Olsen" role="Wanda Maximoff / Scarlet Witch" thumb="http://image.tmdb.org/t/p/original/mGyqAs1MwwE4gd490iKxSo193qA.jpg"/>
<Role id="562" filter="actor=562" tag="Anthony Mackie" role="Sam Wilson / Falcon" thumb="http://image.tmdb.org/t/p/original/5VGGJ0Co8SC94iiedWb2o3C36T.jpg"/>
<Role id="112" filter="actor=112" tag="Sebastian Stan" role="Bucky Barnes / Winter Soldier" thumb="http://image.tmdb.org/t/p/original/76Lr7hStv0uunDbCYIXO9pMV8Mb.jpg"/>
<Role id="578" filter="actor=578" tag="Idris Elba" role="Heimdall" thumb="http://image.tmdb.org/t/p/original/fBNfIzrfOqh1KFvQkSxrJoMNYXL.jpg"/>
<Role id="68" filter="actor=68" tag="Danai Gurira" role="Okoye" thumb="http://image.tmdb.org/t/p/original/xgo39kFf6rAynb1i9J1BeLfSXxg.jpg"/>
<Role id="593" filter="actor=593" tag="Peter Dinklage" role="Eitri" thumb="http://image.tmdb.org/t/p/original/xuB7b4GbARu4HN6gq5zMqjGbkwF.jpg"/>
<Role id="565" filter="actor=565" tag="Benedict Wong" role="Wong" thumb="http://image.tmdb.org/t/p/original/iBzJ8s7GqgtRfGH3q0Ep5OKnaGf.jpg"/>
<Role id="594" filter="actor=594" tag="Pom Klementieff" role="Mantis" thumb="http://image.tmdb.org/t/p/original/5L0cO2WvhA02k95OPf1jx0F9PbG.jpg"/>
<Role id="573" filter="actor=573" tag="Dave Bautista" role="Drax the Destroyer" thumb="http://image.tmdb.org/t/p/original/oZDL1VprkUEFhOtG5WcVjudj5ks.jpg"/>
<Role id="606" filter="actor=606" tag="Vin Diesel" role="Groot (voice)" thumb="http://image.tmdb.org/t/p/original/mjRdM6w6Uz1UnrKQ5Kw02qGln2K.jpg"/>
<Role id="568" filter="actor=568" tag="Bradley Cooper" role="Rocket Racoon (voice)" thumb="http://image.tmdb.org/t/p/original/z5LUl9bljJnah3S5rtN7rScrmI8.jpg"/>
<Role id="577" filter="actor=577" tag="Gwyneth Paltrow" role="Virginia 'Pepper' Potts" thumb="http://image.tmdb.org/t/p/original/slPWN0VvYJtNOEuxlFSsXSNQMaF.jpg"/>
<Role id="566" filter="actor=566" tag="Benicio del Toro" role="Taneleer Tivan / The Collector" thumb="http://image.tmdb.org/t/p/original/cbkXDtNDFYHKsyQzqvzxjn7F7rX.jpg"/>
<Role id="581" filter="actor=581" tag="Josh Brolin" role="Thanos" thumb="http://image.tmdb.org/t/p/original/x8KKnvHyPvH16M6waAnY1OeCtA8.jpg"/>
<Role id="571" filter="actor=571" tag="Chris Pratt" role="Peter Quill / Star-Lord" thumb="http://image.tmdb.org/t/p/original/gXKyT1YU5RWWPaE1je3ht58eUZr.jpg"/>
<Role id="599" filter="actor=599" tag="Sean Gunn" role="On-Set Rocket" thumb="http://image.tmdb.org/t/p/original/tiolBlPytndQVGHO9vLnBKWWenq.jpg"/>
<Role id="607" filter="actor=607" tag="William Hurt" role="Thaddeus Ross" thumb="http://image.tmdb.org/t/p/original/mf5GiYZjURQ72CPtY1kBva7mqIK.jpg"/>
<Role id="94" filter="actor=94" tag="Letitia Wright" role="Shuri" thumb="http://image.tmdb.org/t/p/original/kfA5KhyU6OSy4NrMzHCxYU7A0DW.jpg"/>
<Role id="601" filter="actor=601" tag="Terry Notary" role="Cull Obsidian / On-Set Groot" thumb="http://image.tmdb.org/t/p/original/hIwDLupV2EOi6EqpHa1DNjrNRZU.jpg"/>
<Role id="605" filter="actor=605" tag="Tom Vaughan-Lawlor" role="Ebony Maw" thumb="http://image.tmdb.org/t/p/original/taoZXCxhWdzHI0iNb3IVdeMYcXZ.jpg"/>
<Role id="569" filter="actor=569" tag="Carrie ■■■■" role="Proxima Midnight (voice)" thumb="http://image.tmdb.org/t/p/original/aX7kfLrSYWK7s9KvjldO1JYCbPv.jpg"/>
<Role id="589" filter="actor=589" tag="Michael James Shaw" role="Corvus Glaive" thumb="http://image.tmdb.org/t/p/original/sTB75kcNfHkz95SeWPW3nS7dvSu.jpg"/>
<Role id="117" filter="actor=117" tag="Stan Lee" role="Schoolbus Driver" thumb="http://image.tmdb.org/t/p/original/dTr2gJPL7jELKVkcjtoNx80uVKR.jpg"/>
<Role id="130" filter="actor=130" tag="Winston Duke" role="M'Baku" thumb="http://image.tmdb.org/t/p/original/MhBiZbryibwuoEtPL9Ns8pYHC1.jpg"/>
<Role id="78" filter="actor=78" tag="Florence Kasumba" role="Ayo" thumb="http://image.tmdb.org/t/p/original/oLKR9435H3sjeCWWvD0rLGsL5t9.jpg"/>
<Role id="584" filter="actor=584" tag="Kerry Condon" role="Friday (voice)" thumb="http://image.tmdb.org/t/p/original/zporSogvIeQz56ufWWou2mFj15F.jpg"/>
<Role id="590" filter="actor=590" tag="Monique Ganderton" role="On-Set Proxima Midnight" thumb="http://image.tmdb.org/t/p/original/8BNtDzQwv8CWW0jmtcwa2YiJqta.jpg"/>
<Role id="580" filter="actor=580" tag="Jacob Batalon" role="Ned Leeds" thumb="http://image.tmdb.org/t/p/original/ka49JItS3al6FANw02jQ20Jtv7M.jpg"/>
<Role id="602" filter="actor=602" tag="Tiffany Espensen" role="Cindy Moon" thumb="http://image.tmdb.org/t/p/original/nxXUE2I3vsMNy8iha3PCrnO4wTt.jpg"/>
<Role id="579" filter="actor=579" tag="Isabella Amara" role="Sally Avril" thumb="http://image.tmdb.org/t/p/original/yGYPpZzeyzYf14M3xv1LYu7h6A7.jpg"/>
<Role id="576" filter="actor=576" tag="Ethan Dizon" role="Brian 'Tiny' McKeever" thumb="http://image.tmdb.org/t/p/original/2Zqioe3D9Yb4B8dMUcea6Cy6aoQ.jpg"/>
<Role id="563" filter="actor=563" tag="Ariana Greenblatt" role="Young Gamora" thumb="http://image.tmdb.org/t/p/original/rgaU0Uyx0F2fZiWzduQR0SK2Y9X.jpg"/>
<Role id="561" filter="actor=561" tag="Ameenah Kaplan" role="Gamora's Mother" thumb="http://image.tmdb.org/t/p/original/3heAxiYy4ac9icNgwOFfs22bv2.jpg"/>
<Role id="597" filter="actor=597" tag="Ross Marquand" role="Johann Schmidt / Red Skull / Stonekeeper" thumb="http://image.tmdb.org/t/p/original/e40ZfFfP9ccxHTboLQOA1mkBw2k.jpg"/>
<Role id="588" filter="actor=588" tag="Michael Anthony Rogers" role="Secretary Ross' Aide"/>
<Role id="600" filter="actor=600" tag="Stephen McFeely" role="Secretary Ross' Aide" thumb="http://image.tmdb.org/t/p/original/fa8DAGpANcBTTXO4bbNMrCFufmV.jpg"/>
<Role id="560" filter="actor=560" tag="Aaron Lazar" role="Dr. Stephen Strange Double" thumb="http://image.tmdb.org/t/p/original/rBJS2J4wN1n9ooaKOcwqdDNvgW1.jpg"/>
<Role id="596" filter="actor=596" tag="Robert Pralgo" role="Thanos Reader" thumb="http://image.tmdb.org/t/p/original/iDPgSaDVhwIItvqa2Wn79oaUzf8.jpg"/>
<Role id="591" filter="actor=591" tag="Olaniyan Thurmon" role="Teenage Groot Reader" thumb="http://image.tmdb.org/t/p/original/tdn6j7JOEAVQwy3TF2xuyDulflT.jpg"/>
<Role id="567" filter="actor=567" tag="Blair Jasin" role="Street Pedestrian #1" thumb="http://image.tmdb.org/t/p/original/fKghwt3sd8BSlZNJ93RLRl0kSYH.jpg"/>
<Role id="587" filter="actor=587" tag="Matthew Zuk" role="Street Pedestrian #2" thumb="http://image.tmdb.org/t/p/original/gu0Cv1V7x5JwJjbYP8IpbOlbhg0.jpg"/>
<Role id="585" filter="actor=585" tag="Laura Miller" role="Scottish News (STV) Reporter" thumb="http://image.tmdb.org/t/p/original/4Zm3EXy2LMJhtkr6lYsq5XZGtbn.jpg"/>
<Role id="583" filter="actor=583" tag="Kenneth Branagh" role="Asgardian Distress Call (voice) (uncredited)" thumb="http://image.tmdb.org/t/p/original/bmpGjbqvAVNOK3ggiuET2Jl96tZ.jpg"/>
<Role id="598" filter="actor=598" tag="Samuel L. Jackson" role="Nick Fury" thumb="http://image.tmdb.org/t/p/original/AvCReLikjzYEf9XjTQxbv3JWgKT.jpg"/>
<Role id="572" filter="actor=572" tag="Cobie Smulders" role="Maria Hill (uncredited)" thumb="http://image.tmdb.org/t/p/original/qYXbHM3QZwHAOURe0L09Wn4UKsh.jpg"/>
<Similar id="160" filter="similar=160" tag="Deadpool 2"/>
<Similar id="619" filter="similar=619" tag="Black Panther"/>
<Similar id="174" filter="similar=174" tag="Thor: Ragnarok"/>
<Similar id="158" filter="similar=158" tag="Ant-Man and the Wasp"/>
<Similar id="170" filter="similar=170" tag="Ready Player One"/>
<Similar id="172" filter="similar=172" tag="Spider-Man: Homecoming"/>
<Similar id="165" filter="similar=165" tag="Justice League"/>
<Similar id="162" filter="similar=162" tag="Guardians of the Galaxy Vol. 2"/>
<Similar id="164" filter="similar=164" tag="Jurassic World: Fallen Kingdom"/>
<Similar id="171" filter="similar=171" tag="Solo: A Star Wars Story"/>
<Similar id="173" filter="similar=173" tag="Star Wars: The Last Jedi"/>
<Similar id="161" filter="similar=161" tag="Doctor Strange"/>
<Similar id="620" filter="similar=620" tag="Captain America: Civil War"/>
<Similar id="618" filter="similar=618" tag="Avengers: Age of Ultron"/>
<Similar id="157" filter="similar=157" tag="A Quiet Place"/>
<Similar id="175" filter="similar=175" tag="Tomb Raider"/>
<Similar id="621" filter="similar=621" tag="Incredibles 2"/>
<Similar id="169" filter="similar=169" tag="Rampage"/>
<Similar id="176" filter="similar=176" tag="Wonder Woman"/>
<Similar id="617" filter="similar=617" tag="Ant-Man"/>
</Video>
</MediaContainer>
<Video ratingKey="66" key="/library/metadata/66" guid="com.plexapp.agents.imdb://tt1825683?lang=fr" librarySectionTitle="Films" librarySectionID="1" librarySectionKey="/library/sections/1" studio="Walt Disney Pictures" type="movie" title="Black Panther" contentRating="PG-13" summary="Black Panther suit T’Challa qui, après les événements de Captain America : Civil War, retourne chez lui, dans la nation africaine isolée et technologiquement avancée du Wakanda, pour prendre possession du trône. Cependant, quand un vieil ennemi réapparaît sur le radar, le courage de T’Challa en tant que roi et Black Panther est testé quand il est entraîné dans un conflit qui met le sort entier du Wakanda et du monde en danger." rating="9.7" audienceRating="7.9" viewOffset="404000" viewCount="1" lastViewedAt="1539828552" year="2018" thumb="/library/metadata/66/thumb/1539714925" art="/library/metadata/66/art/1539714925" duration="8073152" originallyAvailableAt="2018-02-13" addedAt="1539714913" updatedAt="1539714925" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" hasPremiumExtras="1" hasPremiumPrimaryExtra="1" ratingImage="rottentomatoes://image.rating.ripe">
<Media videoResolution="1080" id="179" duration="8073152" bitrate="11706" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="ac3" videoCodec="h264" container="mkv" videoFrameRate="24p" videoProfile="high">
<Part accessible="1" exists="1" id="179" key="/library/parts/179/1539714906/file.mkv" duration="8073152" file="/FILMS/Black.Panther.2018.MULTi.VFF.1080p.BluRay.x264-ANONA.mkv" size="11812892997" container="mkv" videoProfile="high">
<Stream id="384" streamType="1" default="1" codec="h264" index="0" bitrate="9722" language="English" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.976" hasScalingMatrix="0" height="800" level="41" profile="high" refFrames="5" scanType="progressive" width="1920" displayTitle="1080p (H.264)"/>
<Stream id="385" streamType="2" selected="1" default="1" codec="ac3" index="1" channels="6" bitrate="448" language="Français" languageCode="fre" audioChannelLayout="5.1(side)" samplingRate="48000" displayTitle="Français (AC3 5.1)"/>
<Stream id="386" streamType="2" codec="dca" index="2" channels="6" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" samplingRate="48000" displayTitle="English (DTS 5.1)"/>
<Stream id="387" streamType="3" default="1" codec="srt" index="3" language="Français" languageCode="fre" title="Forced" displayTitle="Français (SRT)"/>
<Stream id="388" streamType="3" codec="srt" index="4" language="Français" languageCode="fre" title="Full" displayTitle="Français (SRT)"/>
<Stream id="389" streamType="3" codec="srt" index="5" language="English" languageCode="eng" title="Full" displayTitle="English (SRT)"/>
</Part>
</Media>
<Director id="50" filter="director=50" tag="Ryan Coogler"/>
<Writer id="51" filter="writer=51" tag="Joe Robert Cole"/>
<Writer id="52" filter="writer=52" tag="Ryan Coogler"/>
<Producer id="134" filter="producer=134" tag="David J. Grant"/>
<Role id="103" filter="actor=103" tag="Michael B. Jordan" role="N'Jadaka / Erik Killmonger" thumb="http://image.tmdb.org/t/p/original/4vXkRCbrquoP5Lrb4px7tubDLMC.jpg"/>
<Role id="97" filter="actor=97" tag="Lupita Nyong'o" role="Nakia" thumb="http://image.tmdb.org/t/p/original/wjAb2Gu47MkguTignqNfEG8t6Uo.jpg"/>
<Role id="102" filter="actor=102" tag="Martin Freeman" role="Everett K. Ross" thumb="http://image.tmdb.org/t/p/original/ashlWz2KDQTbo8NPUbVOwcB3zXJ.jpg"/>
<Role id="69" filter="actor=69" tag="Daniel Kaluuya" role="W'Kabi" thumb="http://image.tmdb.org/t/p/original/24trqMr2PBwAmttp9X4F3ZErgt4.jpg"/>
<Role id="59" filter="actor=59" tag="Angela Bassett" role="Ramonda" thumb="http://image.tmdb.org/t/p/original/qvIFNQLWzWyqjykiU0ONQ7u6Ihz.jpg"/>
<Role id="79" filter="actor=79" tag="Forest Whitaker" role="Zuri" thumb="http://image.tmdb.org/t/p/original/4pMQkelS5lK661m9Kz3oIxLYiyS.jpg"/>
<Role id="58" filter="actor=58" tag="Andy Serkis" role="Ulysses Klaue / Klaw" thumb="http://image.tmdb.org/t/p/original/eNGqhebQ4cDssjVeNFrKtUvweV5.jpg"/>
<Role id="87" filter="actor=87" tag="John Kani" role="T'Chaka" thumb="http://image.tmdb.org/t/p/original/iOKWcdeCNbEREAWMWIZBy6p805j.jpg"/>
<Role id="119" filter="actor=119" tag="Sterling K. Brown" role="N'Jobu" thumb="http://image.tmdb.org/t/p/original/l0Zth6GbkZbMpyl52RPMCO7GQA5.jpg"/>
<Role id="113" filter="actor=113" tag="Seth Carr" role="Young Killmonger" thumb="http://image.tmdb.org/t/p/original/bO4OGAf932dxyW9LRNgHsYra758.jpg"/>
<Role id="74" filter="actor=74" tag="Denzel Whitaker" role="Young Zuri" thumb="http://image.tmdb.org/t/p/original/yN4ZZDDDJI2UoKVI1BlIWwd5mp8.jpg"/>
<Role id="82" filter="actor=82" tag="Isaach De Bankolé" role="River Tribe Elder" thumb="http://image.tmdb.org/t/p/original/pr2AoaFlgQfdbIIv88UhCyp8wuF.jpg"/>
<Role id="71" filter="actor=71" tag="Danny Sapani" role="Border Tribe Elder" thumb="http://image.tmdb.org/t/p/original/4VeGdZjOEMCdO6AHbYiLI7FdT39.jpg"/>
<Role id="120" filter="actor=120" tag="Sydelle Noel" role="Xoliswa" thumb="http://image.tmdb.org/t/p/original/39EkTMquEQenyyRkXYCPpKsOKnY.jpg"/>
<Role id="85" filter="actor=85" tag="Janeshia Adams-Ginyard" role="Dora Milaje" thumb="http://image.tmdb.org/t/p/original/7jfm3qieBQgwG6hpinh9NUEAZtF.jpg"/>
<Role id="91" filter="actor=91" tag="Jénel Stevens" role="Dora Milaje" thumb="http://image.tmdb.org/t/p/original/n4tOkOkzpiNFhEDzZHgNzJAe79w.jpg"/>
<Role id="115" filter="actor=115" tag="Shaunette Renée Wilson" role="Dora Milaje" thumb="http://image.tmdb.org/t/p/original/fPjeTxxE2sB0bQUcAoO13mKsKK5.jpg"/>
<Role id="117" filter="actor=117" tag="Stan Lee" role="Casino Patron" thumb="http://image.tmdb.org/t/p/original/dTr2gJPL7jELKVkcjtoNx80uVKR.jpg"/>
<Role id="112" filter="actor=112" tag="Sebastian Stan" role="James "Bucky" Barnes" thumb="http://image.tmdb.org/t/p/original/76Lr7hStv0uunDbCYIXO9pMV8Mb.jpg"/>
<Role id="63" filter="actor=63" tag="Bambadjan Bamba" role="Military Leader" thumb="http://image.tmdb.org/t/p/original/eYlzlI6dVc96gnFEBJe3MPFGMrV.jpg"/>
<Role id="86" filter="actor=86" tag="Jeremy Sample" role="Jabari Fisherman" thumb="http://image.tmdb.org/t/p/original/eD0QPs81GFucXeNx9B1SzSgONqG.jpg"/>
<Role id="116" filter="actor=116" tag="Sope Aluko" role="Shaman" thumb="http://image.tmdb.org/t/p/original/tPWSMWE2PgT6NTbMo281JarKYkO.jpg"/>
<Role id="54" filter="actor=54" tag="Alexis Rhee" role="Sophia" thumb="http://image.tmdb.org/t/p/original/vu4RAoiD4eXXt0KRA882IwmZQAE.jpg"/>
<Role id="121" filter="actor=121" tag="Tahseen Ghauri" role="U.N. Official" thumb="http://image.tmdb.org/t/p/original/63aehtREPF3tWAxReTkJeMhqZGF.jpg"/>
<Role id="70" filter="actor=70" tag="Danny Chung" role="Casino Dealer" thumb="http://image.tmdb.org/t/p/original/zDdG3uBSPQCBFGYMIhtbv3uKzUG.jpg"/>
<Role id="73" filter="actor=73" tag="David S. Lee" role="Limbani" thumb="http://image.tmdb.org/t/p/original/jcQP0Uonk5cIiYjdmC2toGCpo6w.jpg"/>
<Role id="101" filter="actor=101" tag="Mark Ashworth" role="Security Guard" thumb="http://image.tmdb.org/t/p/original/jWBtSHaP3iSmQJC7GTPca8GNPc1.jpg"/>
<Role id="114" filter="actor=114" tag="Shad Gaspard" role="Actor" thumb="http://image.tmdb.org/t/p/original/NPn8XIKB9wvICevya40bvbsBNB.jpg"/>
<Role id="128" filter="actor=128" tag="William Cowboy Reed" role="Museum Guard" thumb="http://image.tmdb.org/t/p/original/jQvNTAIgN7ZrDOSHD2jKGi1ZJ7f.jpg"/>
<Role id="53" filter="actor=53" tag="Alex Hibbert" role="Young Oakland Kid" thumb="http://image.tmdb.org/t/p/original/rWUu41SSz4bTiphToue2BrAlqZv.jpg"/>
<Role id="96" filter="actor=96" tag="Lucy Hockings" role="BBC Reporter" thumb="http://image.tmdb.org/t/p/original/nTcf3wQBsSSQNMCJt9AtLH20OBg.jpg"/>
<Role id="61" filter="actor=61" tag="Ashton Tyler" role="Young T'Challa"/>
<Role id="62" filter="actor=62" tag="Atandwa Kani" role="Young T'Chaka"/>
<Role id="67" filter="actor=67" tag="Connie Chiume" role="Mining Tribe Elder"/>
<Role id="75" filter="actor=75" tag="Dorothy Steel" role="Merchant Tribe Elder"/>
<Role id="100" filter="actor=100" tag="Marija Abney" role="Dora Milaje"/>
<Role id="98" filter="actor=98" tag="Maria Hippolyte" role="Dora Milaje"/>
<Role id="99" filter="actor=99" tag="Marie Mouroum" role="Dora Milaje"/>
<Role id="131" filter="actor=131" tag="Zola Williams" role="Dora Milaje"/>
<Role id="66" filter="actor=66" tag="Christine Hollingsworth" role="Dora Milaje"/>
<Role id="107" filter="actor=107" tag="Nabiyah Be" role="Linda"/>
<Role id="105" filter="actor=105" tag="Michael David Yuhl" role="Ambassador"/>
<Role id="76" filter="actor=76" tag="Elizabeth Elkins" role="CIA Agent"/>
<Role id="110" filter="actor=110" tag="Raven Wynn" role="Korean Market Shopper"/>
<Role id="56" filter="actor=56" tag="Amechi Okocha" role="Bueze"/>
<Role id="125" filter="actor=125" tag="Tony Sears" role="French Ambassador"/>
<Role id="80" filter="actor=80" tag="Francesca Faridany" role="Museum Director"/>
<Role id="111" filter="actor=111" tag="Roland Kilumbu" role="Young Military"/>
<Role id="124" filter="actor=124" tag="Timothy Carr" role="UN Security Guard" thumb="http://image.tmdb.org/t/p/original/hVcWRcR8SLGIlmdhYILkC3q116a.jpg"/>
<Role id="60" filter="actor=60" tag="Apollo GT" role="Fish Market Shopper" thumb="http://image.tmdb.org/t/p/original/fw6pIImSmsw6ywXuJzdhszULxkO.jpg"/>
<Role id="84" filter="actor=84" tag="James Siderits" role="U.N. Official / Translator"/>
<Role id="126" filter="actor=126" tag="Travis Love" role="Jabari Warrior"/>
<Role id="95" filter="actor=95" tag="Lidya Jewett" role="Young Nakia"/>
<Role id="55" filter="actor=55" tag="Alona Leoine" role="School Child / Playground Kid"/>
<Role id="92" filter="actor=92" tag="Kinley Fleurejuste" role="Uptown Patron"/>
<Role id="108" filter="actor=108" tag="Ofu Obekpa" role="Kings Guard"/>
<Role id="106" filter="actor=106" tag="Michael R. Ciminna" role="Security Guard"/>
<Role id="88" filter="actor=88" tag="John Y Lee" role="Casino Dealer"/>
<Role id="64" filter="actor=64" tag="Byron Coolie" role="Wakandan"/>
<Role id="129" filter="actor=129" tag="William Walker" role="Museum Security Guard"/>
<Role id="89" filter="actor=89" tag="Joseph Akharoh Jr." role="Citizen of Wakanda"/>
<Role id="118" filter="actor=118" tag="Stanley Aughtry" role="Merchant Tribe Warrior"/>
<Role id="109" filter="actor=109" tag="Raenen Golez" role="Casino Patron"/>
<Role id="93" filter="actor=93" tag="Leo De Rivera" role="Casino Bartender"/>
<Role id="123" filter="actor=123" tag="Tevin Beech" role="Guard"/>
<Role id="122" filter="actor=122" tag="Tari Omoro" role="Jabari Drummer"/>
<Role id="57" filter="actor=57" tag="Andrea Antonio Canal" role="Casino Guest"/>
<Role id="72" filter="actor=72" tag="David Dunston" role="Citizen of Wakanda"/>
<Role id="77" filter="actor=77" tag="Emelita T. Gonzalez" role="UN Philippine Represenitive"/>
<Role id="90" filter="actor=90" tag="Josue Louis-Charles" role="Mining Tribe"/>
<Role id="81" filter="actor=81" tag="Isaac Phillips" role="Mining Tribe #2"/>
<Role id="127" filter="actor=127" tag="Trevor Noah" role="Griot (voice)" thumb="http://image.tmdb.org/t/p/original/6ZVI1hFMabppjZn2BKm7xQAugFz.jpg"/>
<Role id="83" filter="actor=83" tag="Jamel Chambers" role="Merchant (uncredited)"/>
<Role id="104" filter="actor=104" tag="Michael Christopher Rodney" role="Kings Guard (uncredited)" thumb="http://image.tmdb.org/t/p/original/3sqly0o31iSGHr4Kd3eeEt2f2XW.jpg"/>
<Similar id="159" filter="similar=159" tag="Avengers: Infinity War"/>
<Similar id="166" filter="similar=166" tag="Kingsman: The Golden Circle"/>
<Similar id="163" filter="similar=163" tag="Jumanji: Welcome to the Jungle"/>
<Similar id="168" filter="similar=168" tag="Pacific Rim: Uprising"/>
<Similar id="167" filter="similar=167" tag="Maze Runner: The Death Cure"/>
</Video>
</MediaContainer>
<Video ratingKey="300" key="/library/metadata/300" parentRatingKey="299" grandparentRatingKey="298" guid="com.plexapp.agents.thetvdb://153021/9/2?lang=fr" librarySectionTitle="Séries TV" librarySectionID="2" librarySectionKey="/library/sections/2" type="episode" title="The Bridge" titleSort="Bridge" grandparentKey="/library/metadata/298" parentKey="/library/metadata/299" grandparentTitle="The Walking Dead" parentTitle="Saison 9" contentRating="TV-MA" summary="The communities join forces to restore a bridge that will facilitate communication and trade; someone is gravely injured at the construction site." index="2" parentIndex="9" rating="9.0" viewOffset="1653000" viewCount="2" lastViewedAt="1539859262" year="2018" thumb="/library/metadata/300/thumb/1539771357" art="/library/metadata/298/art/1539771357" parentThumb="/library/metadata/299/thumb/1539771357" grandparentThumb="/library/metadata/298/thumb/1539771357" grandparentArt="/library/metadata/298/art/1539771357" grandparentTheme="/library/metadata/298/theme/1539771357" duration="2706816" originallyAvailableAt="2018-10-14" addedAt="1539771086" updatedAt="1539771357">
<Media videoResolution="1080" id="835" duration="2706816" bitrate="3384" width="1920" height="1080" aspectRatio="1.78" audioChannels="6" audioCodec="ac3" videoCodec="h264" container="mkv" videoFrameRate="24p" videoProfile="high">
<Part accessible="1" exists="1" id="836" key="/library/parts/836/1539771086/file.mkv" duration="2706816" file="/FILMS/The.Walking.Dead.S09E02.VOSTFR.1080p.AMZN.WEB-DL.DD5.1.x264-ARK01.mkv" size="1145150416" container="mkv" deepAnalysisVersion="2" requiredBandwidths="6709,5430,4260,4230,4230,4230,4230,4230" videoProfile="high">
<Stream id="1749" streamType="1" default="1" codec="h264" index="0" bitrate="3000" language="English" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" colorRange="tv" colorSpace="bt709" frameRate="23.976" hasScalingMatrix="0" height="1080" level="41" profile="high" refFrames="4" requiredBandwidths="6325,5045,3876,3857,3857,3857,3857,3857" scanType="progressive" width="1920" displayTitle="1080p (H.264)"/>
<Stream id="1750" streamType="2" selected="1" default="1" codec="ac3" index="1" channels="6" bitrate="384" language="English" languageCode="eng" audioChannelLayout="5.1(side)" requiredBandwidths="384,384,384,384,384,384,384,384" samplingRate="48000" displayTitle="English (AC3 5.1)"/>
<Stream id="1751" streamType="3" selected="1" default="1" codec="srt" index="2" bitrate="0" language="Français" languageCode="fre" requiredBandwidths="1,1,1,1,1,1,1,1" displayTitle="Français (SRT)"/>
<Stream id="1752" streamType="3" codec="srt" index="3" bitrate="0" language="English" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" displayTitle="English (SRT)"/>
</Part>
</Media>
<Director id="1547" filter="director=1547" tag="Daisy Mayer"/>
<Writer id="1546" filter="writer=1546" tag="David Leslie Johnson-McGoldrick"/>
</Video>
</MediaContainer>
<Video ratingKey="94" key="/library/metadata/94" guid="com.plexapp.agents.imdb://tt1441912?lang=fr" librarySectionTitle="Films" librarySectionID="1" librarySectionKey="/library/sections/1" studio="Elixir Films" type="movie" title="The Way" titleSort="Way" originalTitle="The Way" contentRating="PG-13" summary="Un père qui avait coupé les ponts avec son fils se voit dans l'obligation de traverser l'Atlantique après la mort de ce dernier, décédé durant le pèlerinage reliant la France à Saint-Jacques-de-Compostelle." rating="8.3" audienceRating="8.3" viewCount="1" lastViewedAt="1539727964" year="2010" tagline="La route ensemble" thumb="/library/metadata/94/thumb/1539717579" art="/library/metadata/94/art/1539717579" duration="7715709" originallyAvailableAt="2010-09-10" addedAt="1539717551" updatedAt="1539717579" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" hasPremiumExtras="1" hasPremiumPrimaryExtra="1" ratingImage="rottentomatoes://image.rating.ripe">
<Media videoResolution="1080" id="259" duration="7715709" bitrate="5035" width="1920" height="1040" aspectRatio="1.85" audioChannels="6" audioCodec="ac3" videoCodec="h264" container="mkv" videoFrameRate="24p" videoProfile="high">
<Part accessible="1" exists="1" id="259" key="/library/parts/259/1539717545/file.mkv" duration="7715709" file="/FILMS/The Way La Route Ensemble 1080p FR EN x264 ac3 mHDgz.mkv" size="4856454310" container="mkv" deepAnalysisVersion="2" requiredBandwidths="10625,9781,7669,6616,6134,5707,5178,5164" videoProfile="high">
<Stream id="552" streamType="1" default="1" codec="h264" index="0" bitrate="4267" language="English" languageCode="eng" anamorphic="0" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="24.000" hasScalingMatrix="0" height="1040" level="41" pixelAspectRatio="149:148" profile="high" refFrames="4" requiredBandwidths="9696,8853,6741,5688,5206,4779,4249,4236" scanType="progressive" width="1920" displayTitle="1080p (H.264)"/>
<Stream id="553" streamType="2" selected="1" default="1" codec="ac3" index="1" channels="6" bitrate="384" language="Français" languageCode="fre" audioChannelLayout="5.1(side)" requiredBandwidths="384,384,384,384,384,384,384,384" samplingRate="48000" displayTitle="Français (AC3 5.1)"/>
<Stream id="554" streamType="2" codec="ac3" index="2" channels="6" bitrate="384" language="English" languageCode="eng" audioChannelLayout="5.1(side)" requiredBandwidths="384,384,384,384,384,384,384,384" samplingRate="48000" displayTitle="English (AC3 5.1)"/>
<Stream id="555" streamType="2" codec="aac" index="3" channels="2" language="Français" languageCode="fre" profile="lc" requiredBandwidths="161,161,161,161,161,161,161,161" samplingRate="48000" displayTitle="Français (AAC Stereo)"/>
<Stream id="556" streamType="3" codec="srt" index="4" language="Français" languageCode="fre" requiredBandwidths="1,1,1,1,1,1,1,1" displayTitle="Français (SRT)"/>
<Stream id="557" streamType="3" codec="srt" index="5" language="Français" languageCode="fre" requiredBandwidths="1,1,1,1,1,1,1,1" displayTitle="Français (SRT)"/>
</Part>
</Media>
<Director id="633" filter="director=633" tag="Emilio Estevez"/>
<Writer id="634" filter="writer=634" tag="Emilio Estevez"/>
<Writer id="635" filter="writer=635" tag="Jack Hitt"/>
<Producer id="652" filter="producer=652" tag="David Alexanian"/>
<Producer id="653" filter="producer=653" tag="Emilio Estevez"/>
<Producer id="654" filter="producer=654" tag="Julio Fernández"/>
<Country id="655" filter="country=655" tag="Spain"/>
<Role id="642" filter="actor=642" tag="Martin Sheen" role="Tom" thumb="http://image.tmdb.org/t/p/original/ve77Q75moQhoB6cxdMfigfrHeTA.jpg"/>
<Role id="639" filter="actor=639" tag="Emilio Estevez" role="Daniel" thumb="http://image.tmdb.org/t/p/original/2NSM4zFrw3i16UYdUhfETVjqC4I.jpg"/>
<Role id="638" filter="actor=638" tag="Deborah Kara Unger" role="Sarah" thumb="http://image.tmdb.org/t/p/original/ye75IqbNmFdEuvU9Td0eFKwtA0i.jpg"/>
<Role id="649" filter="actor=649" tag="Yorick van Wageningen" role="Joost" thumb="http://image.tmdb.org/t/p/original/hVOJMPCINUI7GfRX2qRBrw6M8JW.jpg"/>
<Role id="641" filter="actor=641" tag="James Nesbitt" role="Jack" thumb="http://image.tmdb.org/t/p/original/n9NorD6bQfFJlW4IcJ6WoGiAKcR.jpg"/>
<Role id="648" filter="actor=648" tag="Tchéky Karyo" role="Captain Henri" thumb="http://image.tmdb.org/t/p/original/9rMF25F5r3Giix9jkwfuUz2utHv.jpg"/>
<Role id="650" filter="actor=650" tag="Ángela Molina" role="Angelica" thumb="http://image.tmdb.org/t/p/original/c5ZIgJmWu5bHOxD9jOOo4e0otaf.jpg"/>
<Role id="637" filter="actor=637" tag="Carlos Leal" role="Jean" thumb="http://image.tmdb.org/t/p/original/h4700aOa2wFI3Nb5sMz5xErJAHf.jpg"/>
<Role id="646" filter="actor=646" tag="Simón Andreu" role="Don Santiago" thumb="http://image.tmdb.org/t/p/original/yLP9SQRjSxwqfmfXVDftEpDmDgs.jpg"/>
<Role id="640" filter="actor=640" tag="Eusebio Lázaro" role="El Ramón" thumb="http://image.tmdb.org/t/p/original/lVNlssAmkqr5kq3jXCY4cwP4PMo.jpg"/>
<Role id="636" filter="actor=636" tag="Antonio Gil" role="Ishmael" thumb="http://image.tmdb.org/t/p/original/ajn25qDQgGmIQ9g1NsRY5zGRjUn.jpg"/>
<Role id="647" filter="actor=647" tag="Spencer Garrett" role="Phil" thumb="http://image.tmdb.org/t/p/original/gzhIgjFtWeAhfp2yZsiUpD0XAaX.jpg"/>
<Role id="643" filter="actor=643" tag="Matt Clark" role="Padre Frank" thumb="http://image.tmdb.org/t/p/original/aG7tC3jOI42OgtCxGiejbhFj1DW.jpg"/>
<Role id="644" filter="actor=644" tag="Renée Estevez" role="Doreen" thumb="http://image.tmdb.org/t/p/original/riskq4Hjlj2hyWpnMeKjyquqIJ8.jpg"/>
<Role id="645" filter="actor=645" tag="Romy Baskerville" role="Eunice"/>
<Similar id="667" filter="similar=667" tag="A Resurrection"/>
<Similar id="668" filter="similar=668" tag="After the Wedding"/>
<Similar id="673" filter="similar=673" tag="Hellgate"/>
<Similar id="681" filter="similar=681" tag="The Music Never Stopped"/>
<Similar id="680" filter="similar=680" tag="The Hunters"/>
<Similar id="677" filter="similar=677" tag="My Own Love Song"/>
<Similar id="684" filter="similar=684" tag="Trial and Error"/>
<Similar id="679" filter="similar=679" tag="Restitution"/>
<Similar id="675" filter="similar=675" tag="In America"/>
<Similar id="672" filter="similar=672" tag="Happy Accidents"/>
<Similar id="670" filter="similar=670" tag="Essential Killing"/>
<Similar id="685" filter="similar=685" tag="Win Win"/>
<Similar id="678" filter="similar=678" tag="Psycho Beach Party"/>
<Similar id="683" filter="similar=683" tag="The War Zone"/>
<Similar id="682" filter="similar=682" tag="The Station Agent"/>
<Similar id="666" filter="similar=666" tag="50 to 1"/>
<Similar id="674" filter="similar=674" tag="Hollywood Shuffle"/>
<Similar id="676" filter="similar=676" tag="Leap of Faith"/>
<Similar id="671" filter="similar=671" tag="Felicia's Journey"/>
<Similar id="669" filter="similar=669" tag="Earthling"/>
</Video>
</MediaContainer>
All the working examples have also either AC3 or E-AC3 audio, whereas the non-working examples use TrueHD or DTS audio.
Thank you very much. The, what kind of information should I check and what is working when I am looking for a MKV file please ?
Avoid files with TrueHD or DTS audio (or convert them).
If you have files with HEVC video, make sure that they don’t require you to activate subtitles.
Your ATV can also not handle HEVC HDR or more than 8 bit color depth.
Avoid “10 bit” or “HDR” files as well.
If you absolutely need subtitles for a movie, makes sure those subtitles are in SRT format.
Thank you ! Then I should convert in H264 Codec and It will work ? I will check if I find that for use it directly from my Debian Server.
I listen if you have any recommendation to make it directly with terminal… IF I find solution I will post it.
About your question, nothing change if I disable subtitle.
This is sad that x265 does not work on Plex…
Thank to all your informations, I found other topics in French… But is the H265 decoded by the server or by my Apple TV ?
In theory, your ATV should be able to play HEVC, as long as it is not in a higher resolution than 1080p ad 30 fps.
But as soon as you add subtitles, this doesn’t work anymore.
There is also the matter of Apple not supporting DTS audio at all.
If Plex server senses a combination of codecs which is not supported by your ATV, it will try to convert these into a supported format → transcoding.
Thank you ! I am totally unexperimented about these coded, sound, etc… I will continue tu investigate, now I know I can search for H265 Plex I will get a lot of result.
Thank you for all your time and advices, I appreciated it a lot.
