Songs Partially Sync'd
android-mobile
#1
Every sync’d song on my Galaxy S7 Edge cuts off mid way through the song. For example if a song is 4 minutes long, only 2 minutes will play before skipping to the next song. If I try to manually move past the part where it skips, it will immediately skip to the next song in the playlist. I’ve also noticed a similar problem occurs with synced pictures. Some pictures seem to have failed to sync at all and some others only partially sync’d.
This is when plex is saying everything is 100% sync’d
I have tried wiping the sync’d content and re-syncing as well as syncing smaller playlists.
Two example pictures provided below:
-image not sync’d at all
-image only partially sync’d
