Sonos App will not find specific media
sonos
#1
Hi All
Newbie to Sonos here. I have successfully setup Plex App inside Sonos App. I can see all my media (without visual Metadata, no covers). But when I start to play any song I get the same prompt "Unable to play ** - cannot connect to Plex". I have Remote Access Turned on!!! I'm missing a set somewhere. Appreciate any help in advance. Pwrbilt (Rob B.)
#2
Still working this problem, not really sure what I'm doing. Disabled DLNA, that didn't really work. Then turned on Manually Specify Public Port. That seemed to work. Have only tested this using my network. Still looking for someone who has had this problem and has a true fix. Thanks Pwrbilt
#3
I feel like the integration is broken now because mine was working fine for almost a year and now I’m having your issues.
#4
@Pwrbilt said:
Still working this problem, not really sure what I’m doing. Disabled DLNA, that didn’t really work. Then turned on Manually Specify Public Port. That seemed to work. Have only tested this using my network. Still looking for someone who has had this problem and has a true fix. Thanks Pwrbilt
I believe it broke with cloud auth. That looks to have been reverted but still affects.
A crappy work around is to replaced the queue with one mp3. It will than play until the queue hits its limit / buffer.
Flac won’t play and will break the queue
