Sonos will not play FLAC
sonos
#1
Hi Sonos not playing
Codec FLAC
Channels Stereo
Bitrate 1092 kbps
Audio Channel Layout stereo
Bit Depth 16
Sampling Rate 44100 Hz
#2
Update this is part of the labs issue affecting general playback. The queue and can be replaced (or reset) and most should play, but a large queue or 1 flac file will break it.
#3
I concur with this issue. If a FLAC album is queued up, and it requires down-transcoding (I am playing 24 bit/96) it crashes after about 50% of the first track.
I am working around by downsampling my FLAC files
Any updates on this issue?
#4
Update appears to fix.
