Sony Bravia 2015 won't play files with DTS-HD 7.1 sound anymore
android-tv
fire-tv
#1
This is a problem I didn't have a month back or so. Recently my setup won't play files with DTS-HD sound which is 7.1. I've tried several files with 7.1 sound but they just won't start. The movie starts but freezes at 0:01 time stamp. I've tried reducing bandwidth in the plex app but it won't help, not even if I lower really much. I've also tried with/without direct stream and direct play but with no luck.
It is not a bandwidth problem, there are never any server speed issues and server and TV are connected via wire 1000 mbit internal network in my flat. Trying Chromecast 2 it struggles a bit but can play a similar file. Casting directly to the TV cast works flawless but I think that's because then the tv will output only stereo sound. The AndroidTV app will output 5.1 sound to the receiver.
My setup: Sony Bravia 55W755 (W705C) (Android 6.0) and I have a Sony STR-DN1050 receiver with 5.1 speakers. Receiver connected via HDMI-ARC.
Happy for any input regarding this. It should be a problem that has occured due to an update of AndroidTV-app, the TV or Plex media server. Any thoughts?
#2
Plex client up to date?
Audio Passthrough = Auto?
Local Quality = Original?
Direct Play = Auto?
Direct Stream = ON?
PMS version?
Does the information overlay say its transcoding?
EDIT: I am seeing a same thing with a Bravia 2015 W755C / the latest beta update. It also freezes playback with a black screen while transcoded audio plays.
#3
I am having the same issue with a Bravia 2015.... I dont have any external hardware , just using the built in speakers I get no audio unless I transcode. DD plays fine. The same videos will play fine in Kodi
#4
Hi!
Same thing here.
Sony SD85 Android TV
PLEX android client 5.9.2.805
PLEX server 1.6.1.3722 on Synology 916+
Direct Play = Auto
Direct Stream = ON
Info overlay reports audio transcoding is on due to no support of DTS by the device.
My TV plays sound trough Yamaha 2500 so there is support of DTS...
I will appreciate your help
#5
Direct Play = Auto?
Direct Stream = ON?
PMS version?
Plex client up to date? - Yes
Audio Passthrough = Auto? - Yes
Local Quality = Original? - Yes
Direct Play = Auto? - Yes
Direct Stream = ON? - Yes/No
PMS version? - latest retail, no plex pass version.
Does the information overlay say its transcoding? - Yes due to DTS. On the server i can see that video is not transcoding, only audio.
I have tried each setting on/off but no solution. I've tried lower bitrate, even as low as 4Mbit but it doesn't change.
I hope to hear from more people if you face the same issues and see if we can get some attention... :p ;)
#6
I did get performance problems maybe a year back of another sort while I tried beta software of PMS. Then I did a significant downgrade of the server PMS which solved it. Maybe I will try this again...
#7
Pretty sure this is a client not a server problem but I'm not 100% on that.
#8
I agree, I think its the client since I can use Kodi on the same TV with PlexKodiConnect and it works fine. I just prefer the app when it works. Also films that used to play fine on this Tv now play silent unless I transcode, or disable direct play, which makes the audio out of sync
#9
Kodi uses a different player so you can't compare the 2.
#10
I understand that, but its playing the same media, on the same system.... and it worked fine in plex before
#11
Yes and the fact they use 2 different players means there is no correlation or common factor between the 2 bits of software.
#12
Yes seems like a client issue but I wonder how it has occurred. Given that theory the client should be downgraded to try to fix.
Could it be the Android upgrade on the TV? I think that is a possibility since it upgraded from 5.1 to 6.0 a month ago. :(
#13
Mac Natively does not support 7.1 DTS-HD, I believe Shield and Playstation do support if I remember correctly. But using LPCM or PCM Audio settings.
#14
Macs are not even mentioned in this post. Little early to be drinking no?
#15
Come on look at your signature and it's a big world, as I live in Australia. If you wish to drink all hours what business is it of mine.
#16
I have the same problem, on a 8500c. Only occurs on 6.1 and 7.1 DTS-HD and TrueHD audio. DTS HD 5.1 and TrueHD 5.1 audio transcode and play just fine. It will play a fraction of a second of the film and halt.
Somewhere in the last couple of months this has occurred. Switched to the Kodi frontend in the meantime.
TV is still running 5.1.1 Android.
#17
Add me to the list.. or well my parents.. I've tried all possible configurations on the TV and Plex settings and all 6.1 and 7.1 will hang. TV is a Sony 810C with audio being pushed through a Sony HT-NT3. Though as mentioned earlier users report the issue regardless of speakers..
Running latest PMS and verified everything on the TV is up to date..
#18
I have been told that Plex for android TV doesn't support DTS sound without trancoding. I have same issue, DD works flawlessly in directPlay but DTS gives no sound. You HAVE to transcode to get DTS sound. I have given up, and are now using a cheap Raspberry Pi with Rasplex running. It has no problem playing DTS and DD without transcoding. I have not heard about any plans from the nice folks at Plex that this will be fixed any time soon.
#19
DTS 5.1 works fine.. 6.1 and 7.1 is where we are running into issues..
#20
FYI, not sure if it was the latest update but my parents Sony now plays 6.1 and 7.1 but just not Atmos
