Startup Position
aeon-nox
#1
New to your skin, thanks for all the work you and the other skinners put in to keep us happy =D> That said, I'd like to have plex open in a different position on the home screen. Example, "TV" instead of "Movies". Don't see anything in the settings, is there an xml or other file I can edit to make this work? Back in the day the old PlexAeon (?) had a setting for this so I figure it's doable (hopefully). Thanks again.
(If it matters currently using vertical menu for home screen)
#2
its not possible to choose a startup position at the moment, its not a skin issue its a openpht thing
hopefully in a future version of openpht
#3
Okay, no biggee. Thanks for the quick response. Cheers.
