Dear all .
First of all - Logs are made to Dev team and sample has been sent to to them .
Im running PMS 1.11.0.4666 on a Ubuntu 16.04 server .
After x minuts, even its its internal subs or external subs - my subs disapear . The only way I can get the subs back , is to press rewind for a very short period, then the subs come back.
It has been working without any problems, but it happend with some latest update, but from which version I dont know.
@sa2000 has been so kind to help me sending logs and etc to the Dev team, but I would like to hear anyone might know which version is actually working? Also how do I downgrade if I make a manually install without loosing my entire libraries .
I have testet back and forth, I have an older version of the Samsung model (2014) , Orcas version works perfectly without subs dying on me
@Orca dont know if you might could be able to assist?
Im shooting wide here since im a bit annoyed that my new tv cant play a single movie or tv show without loosing subs. And you dont have the option to force transcode on the Tizen Plex version.
All help would be appreciated - I doubt that im the only one in the entire world having a Tizen TV from Samsung that uses Plex
Morphy
