Subtitles transcoding
plex-web
#1
I was playing with hardware transcoding and I noticed that even if I enabled subtitles on Plex web on Opera, the video was not transcoded and indeed the info page showed it as "direct play". It didn't work like that before, so is now direct play of subtitles available in Plex web? Maybe this will bring the same feature to Opera TV enabled smart TVs?
#2
Are you talking about Opera the web browser or Opera the app store for Smart TVs?
Direct Play of subtitles has been available since quite a few months already in web browsers
if a few conditions are met:
- the subtitle has to be in a text-based format without formatting instructions (which mainly means: SRT format only. PGS and VOBSUB are not supported)
- Settings - Web - Player - 'Show Advanced' - 'Burn Subtitles' need not be set to 'Always'
- some SRT subtitles are formatted poorly and have overlapping lines or are encoded in a text encoding that is not UTF-8. These either don't show correctly in Plex web or not at all if you try to direct play these.
#3
I was talking about web app in opera browser.
Oh this speaks a lot about how often I use the web app on the browser :D Anyway thank you for the explanation.
#4
Buenas tardes, con respecto al tema de los subtitulos yo utilizo como cliente una smart tv de Samsung en la que tengo tanto la aplicacion PLEX como la apllicacion XPLAY, y la mayoria del contenido en que que hay subtitulos no lo reproduce directamente si no que hace transcodificacion, me pasa con varios formatos de subtitulos como SRT. PGS. etc pero no en todos los casos,.....sabeis como podria configurarlo o si hay alguna forma en la que no tenga que hacer transcodificacion?? gracias.
