Subtitles upside down
#1
Hi all.
I'm after advice. I'm running plex server on shield with opensubtitles agent.
For some reason the subtitles are showing upside down ( bottom line is the beginning of the sentence). Any idea how to fix this issue.
Best regards.
#2
is this a general issue with all of your subtitles (various ones) or did you experience this for a single movie?
#3
Hi.
This issue was affecting all subtitles, shows and movies. Today the bottom line has disappeared altogether :neutral:
I can't really think of anything to be honest.
#4
Ok, everything looks normal now. I set the subtitles to burn into image automatically and subtitles are fine.
Thanks for help.
