Sync Issue - metadata is invalid
Hello,
I am trying to sync some tv series to my ipad but one is episode is failing me. it says unable to sync , metadata is invalid ( try to reanalyse ) . I saw a few others had the problem but could not find a solution. I tried to download another version of the file but nothing did.
Here is the metadata of the file :
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="2" librarySectionTitle="TV Shows" librarySectionUUID="c22bc600-c67b-49d5-8a93-2e1267e07939" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1459835702">
<Video ratingKey="35223" key="/library/metadata/35223" parentRatingKey="34256" grandparentRatingKey="1601" guid="com.plexapp.agents.themoviedb://44857/5/4?lang=en" librarySectionID="2" type="episode" title="Mindy Lahiri Is A Misogynist" grandparentKey="/library/metadata/1601" parentKey="/library/metadata/34256" grandparentTitle="The Mindy Project" summary="As Jeremy recovers from his heart attack, the practice needs another doctor. Jeremy and Jody want to hire a woman, but Mindy isn’t sure about sharing the spotlight. Meanwhile, she and Ben are getting serious." index="4" parentIndex="5" year="2016" thumb="/library/metadata/35223/thumb/1481907144" art="/library/metadata/1601/art/1481907154" parentThumb="/library/metadata/34256/thumb/1481907154" grandparentThumb="/library/metadata/1601/thumb/1481907154" grandparentArt="/library/metadata/1601/art/1481907154" duration="1339548" originallyAvailableAt="2016-10-25" addedAt="1479795435" updatedAt="1481907144" chapterSource="">
<Media videoResolution="sd" id="31847" duration="1339548" bitrate="1120" width="720" height="404" aspectRatio="1.78" audioChannels="2" audioCodec="aac" videoCodec="h264" container="mkv" videoFrameRate="24p" audioProfile="lc" videoProfile="high">
<Part accessible="1" exists="1" id="33201" key="/library/parts/33201/file.mkv" duration="1339548" file="/volume1/VIDEOS/TV SERIES/THE MINDY PROJECT/The Mindy Project Season 05/The.Mindy.Project.S05E04.HDTV.x264-FLEET[eztv].mkv" size="187498144" audioProfile="lc" container="mkv" videoProfile="high">
<Stream id="53882" streamType="1" default="1" codec="h264" index="0" bitrate="1120" language="English" languageCode="eng" bitDepth="8" cabac="1" chromaSubsampling="4:2:0" codecID="V_MPEG4/ISO/AVC" colorRange="tv" colorSpace="bt709" duration="1339548" frameRate="23.976" frameRateMode="cfr" hasScalingMatrix="0" height="404" level="31" pixelFormat="yuv420p" profile="high" refFrames="5" scanType="progressive" width="720"/>
<Stream id="53883" streamType="2" selected="1" default="1" codec="aac" index="1" channels="2" language="English" languageCode="eng" audioChannelLayout="stereo" codecID="A_AAC" duration="1339547" profile="lc" samplingRate="48000"/>
</Part>
</Media>
<Extras size="0"></Extras>
</Video>
</MediaContainer>
Media
Video Resolution SD
Duration 22:19
Bitrate 1120 kbps
Width 720
Height 404
Aspect Ratio 1.78
Container MKV
Video Frame Rate 24p
Audio Profile lc
Video Profile high
Part
Duration 22:19
File The.Mindy.Project.S05E04.HDTV.x264-FLEET[eztv].mkv
Size 178.81 MB
Audio Profile lc
Container MKV
Video Profile high
Codec H264
Bitrate 1120 kbps
Language English
Bit Depth 8
CABAC true
Chroma Subsampling 4:2:0
Color Range tv
Color Space bt709
Duration 22:19
Frame Rate 23.976 fps
Frame Rate Mode cfr
Height 404
Level 3.1
Pixel Format yuv420p
Profile high
Ref Frames 5
Scan Type progressive
Width 720
Codec AAC
Channels Stereo
Language English
Audio Channel Layout stereo
Duration 22:19
Profile lc
Sampling Rate 48000 Hz
