Sync to usb drive / SD card
android-tv
fire-tv
#1
Hi there
i dedicated a android 4.4.2 TV box as my music player, so i create the play list on the server and the box gonna play them. to reduce network traffic i decided to sync the box with the play lists. Under setting i only find the internal storage and nano flash but not usb drives or external SD cards. how can i utilize external storage
#2
How did you accomplish this? Mobile Sync is only available in the mobile layout. Your box should be running the Android TV layout. We don’t support syncing to external storage, since these can be unplugged and messes things up.
