Synced items missing from Sync menu
ios
#1
I've been trying to free up some space on my iPad by deleting synced episodes of shows/movies I've watched only to discover that a number of items I've synced are not showing in the SYNC menu. This means that the only way to remove them (as far as I can tell anyways) is to remove everything.
Does anyone have any idea as to how I can fix the problem? Why I can't simply delete a synced item from the item itself and have to use the menu is beyond me. Very odd UX design.
#2
It’s a bug. Has been there forever. Actually sync never really worked without any troubles
#3
Well that’s frustrating.
To me a simple solution would be to simply add the option to delete the file from the file’s info screen itself (you know, like just about every other video app out there does).
#4
Plex is not every other video app. Plex is special in that regard. Very special. :smiley:
