Synology DMS showing wrong version of Plex
server-synology
#1
I intalled 0.9.7.28 and this is what the Plex web interface shows.
However the Synology interface shows 0.9.7.22. Why?
#2
Most probably because your first install of Plex was using Synology's default package and you used Plex team's package to manually install a later version.
If you had it installed manually, it wouldn't appear in the "multimedia" section. Now, it might be a visual bug, but I guess that's on the synology side and you Plex is just fine as long as it display the version you installed last.
