make certain DEBUG logging is enabled
Verbose logging is too much. We don’t use that anymore because it logs every single packet.
That’s the WEB log, not the SERVER log
Settings - Server - Troubleshooting - Download Logs.
The ZIP file it gives you please
Here they are:
Thanks. I found it immediately.
Mar 23, 2022 17:52:57.861 [0x7f8cccaaa8] DEBUG - Performing a scan with 'Plex Movie' (language: en-US virtual: 0).
Mar 23, 2022 17:52:57.861 [0x7f8cccaaa8] DEBUG - * Scanning /volume1/video/Movies
Mar 23, 2022 17:52:57.862 [0x7f8cccaaa8] ERROR - Couldn't check for the existence of file "/volume1/video/Movies": boost::filesystem::status: Permission denied: "/volume1/video/Movies"
Mar 23, 2022 17:52:57.862 [0x7f8cccaaa8] DEBUG - * Marking media not available in /volume1/video/Movies
Mar 23, 2022 17:52:57.882 [0x7f8cccaaa8] DEBUG - * Taking 213 items out of the map (which has 213 items) for being unavailable.
Mar 23, 2022 17:52:57.993 [0x7f87d61aa8] DEBUG - Grabber: Cleaning up orphaned grabs.
Mar 23, 2022 17:52:57.994 [0x7f87d61aa8] ERROR - Couldn't check for the existence of file "/volume1/video/Fitness/.grab": boost::filesystem::status: Permission denied: "/volume1/video/Fitness/.grab"
Mar 23, 2022 17:52:57.995 [0x7f87d61aa8] ERROR - Couldn't check for the existence of file "/volume1/video/Movies/.grab": boost::filesystem::status: Permission denied: "/volume1/video/Movies/.grab"
Mar 23, 2022 17:52:57.995 [0x7f87d61aa8] ERROR - Couldn't check for the existence of file "/volume1/music/.grab": boost::filesystem::status: Permission denied: "/volume1/music/.grab"
Mar 23, 2022 17:52:57.995 [0x7f87d61aa8] ERROR - Couldn't check for the existence of file "/volume1/video/TV/.grab": boost::filesystem::status: Permission denied: "/volume1/video/TV/.grab"
Mar 23, 2022 17:52:57.995 [0x7f87d61aa8] DEBUG - Grabber: Cleaned up 0 decrepit directories in 0.0 sec.
Recommend:
Solved! Thanks for the patient help and apologise for not following instructions well enough. ![]()
::edit:: - Solved
Having an issue currently where when setting up a library PMS cannot see any directories in my Media directory.
I have DSM7 on a DS415+ x86_64 unit
DSM version is the current stable - DSM 7.0.1-42218 Update 3
Got the installer from here, file is ‘PlexMediaServer-1.25.8.5663-e071c3d62-x86_64_DSM7.spk’
Seems to have installed correctly
I have a share called Media and in it are sub dirs Movies, Music, TV etc…etc…
When adding a Library and getting the the point of selecting a directory i can brows /volume1/Media but at that point the contents of media are not shown thus leaving me unable to select ‘Movies’ .
Attempting to progress and see if the scan will pickup something anyway ends with nothing happening and no media found.
Here is the structure of my Media share
Things of note, in users there is no user called PlexMediaServer
However if i attempt to create this user DSM will not allow it saying the user already exists.
Have used PLEX with success in the past on DSM6 but stopped using it for a year and wanted to start fresh now on DSM7.
A bit lost at this point, any assistance appreciated.
::edit::
So a minute after posting this i found ‘PlexMediaServer’ as a System Internal User in the permissions area for the share…
The database recovery worked!
But now the PMS stops almost daily and I have to go into the Package Center to Run it.
I am currently running version 1.25.7.5604, and have yet to upgrade to Version 1.25.8.5663. Waiting to see if everything was stable.
Logs.zip (3.6 MB)
See attached logs.
I think it might be when PMS performs a maintenance File Scan or Metadata.
TY!
I looked in your logs for crash activity however all the scanner activity rolled any failures off the end of the buffer.
Keep the SPK for 1.25.7 handy just in case.
Download and try 1.25.8 as it can’t hurt.
I personally keep several versions handy. My production system has 3 known-stable
I just updated to DSM 7. Are there any legacy users, volumes or groups I should delete?
There are two volumes: “Plex” and “PlexMediaServer”. There are two accounts: “plex” and “PlexMediaServer” (under System internal user). There is one group: “video”.
When installing, my Plex did not migrate (I have to manually re-add my libraries). There are two available Plex serves to choose from (one that is unable to be connected).
Thanks!
For posterity, fix for me was to uninstall Plex, manually delete the PlexMediaShare volume and reinstall. This migrated successfully.
You did something wrong.
The DSM installer will take ALL your contents from Plex → PlexMediaServer
so you don’t have to reinstall.
The installer WILL NOT migrate the contents of the Plex shared folder if it sees an existing server in PlexMediaServer. ( I prohibit overwriting an active server ). If you tried to do anything manually, the installer will stay ‘hands off’.
The installer / migration process starts automatically if a valid server is found in the Plex shared folder.
Have you reviewed?
It details the changes
Can you show me what you have in Plex/Library/Application Support/Plex Media Server ?
I think I dun goofed. I did read the post you have linked, and I thought it said that once the migration completed, I could remove the user “Plex” and the volume labeled “Plex” with the new user and volume now being labeled “PlexMediaServer.” However, after doing so, I am unable to connect to the DiskStation. Do I have to restart my Plex server? I cannot access Plex/Library/Application Support/Plex Media Server.
edit
It does say that removing the Plex user is fine
Plex is no longer needed.DSM 7 required the username to change. We therefore decided to use PlexMediaServer to match the package name.
As such, you are free to delete user Plex .
The Installer would have done this for you but no longer has any system-level privileges to do so.
Everything seems to be working smoothly now.
Hi all, Please i need someones help. i just got the synology 220+ with the lastest version installed manually. It works for 2 mins after install and defaults to ask me to run the package when it should remain on open. i have been battling this for 3 days now and i need help please
i appreciate any response at all
cheers
Hi, i just got the synology 220+ with the lastest version installed manually. It worked for 2 mins after install and defaults to ask me to run the package when it should remain on open. i have deleted and re-installed yet the same thing keeps happening.
Please open the PlexMediaServer shared folder with FileStation
Drill down until you see “Logs”.
Right-Click “Logs” → Compress to Logs.zip
download and attach please.
Thank you so much for responding so promptly. i couldnt see any logs where you directed me to but i was able to get these logs another way
syslog_2022-4-6-8_35_39.csv.zip (3.1 KB)
Logs.zip (1.2 MB)
PLEASE STOP what you’re doing. You are breaking PMS and causing it to fail.
Did you not see the warnings I placed in 6 languages to not place any media the PlexMediaServer shared folder about not placing media in it?
You must get ALL your media OUT of the PlexMediaServer shared folder.
From what I see, it looks like you have a torrent downloader set to deposit media there and then told Plex to look for media there.
What this does is PMS ends up creating an infinite loop where it spends all its time monitoring itself.
Observe the logs:
Apr 06, 2022 07:01:26.253 [0x7f572cca0b38] DEBUG - Done waiting for all plug-ins to start.
Apr 06, 2022 07:01:26.253 [0x7f572cca0b38] DEBUG - PluginRepository::setStartState: 3, complete
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-10c833ef-9e06-4f8f-b4dc-9fff2d063483"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-92db03ab-80ee-4895-88e2-75f364c3238a"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-f5c301ad-20d6-480f-9060-ab6bdbfa866c"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-e646595b-3ce7-4ce5-83ed-940c23b4b504"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-1c6cc46b-5062-40ac-9f9b-931be1ef49db"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-3ffa516d-3237-4912-b8ab-a263b26d3dfd"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-dd7b58e6-260a-4340-b4e0-e5368260a4d4"
Apr 06, 2022 07:01:26.256 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-ca2e2e92-6c50-41c3-9f99-c769c24ffbb3"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-76860c42-8f91-4551-8cbc-b91ed0ccbb18"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-487fc822-6107-49b8-802f-9a9d57585280"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-0584653f-6c16-43da-a12f-ec8b19d1b622"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/tmp/pms-ab658e48-b8e0-4b95-9a4d-b62b5be23a86"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.21.0.3744-d87012962"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.21.0.3744-d87012962/PLEX MEDIA SERVER"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.21.0.3744-d87012962/PLEX TUNER SERVICE"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.25.8.5663-e071c3d62"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.25.8.5663-e071c3d62/PLEX MEDIA SERVER"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.25.8.5663-e071c3d62/PLEX TUNER SERVICE"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.25.8.5663-e071c3d62/PLEX DLNA SERVER"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.25.8.5663-e071c3d62/PLEX MEDIA SCANNER"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination"
Apr 06, 2022 07:01:26.257 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.imdb"
Apr 06, 2022 07:01:26.258 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.themoviedb"
Apr 06, 2022 07:01:26.258 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.thetvdb"
Apr 06, 2022 07:01:26.258 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.lastfm"
Apr 06, 2022 07:01:26.258 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.none"
Apr 06, 2022 07:01:26.258 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.localmedia"
Apr 06, 2022 07:01:26.258 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/tv.plex.agents.music"
Apr 06, 2022 07:01:26.258 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/org.musicbrainz.agents.music"
Apr 06, 2022 07:01:26.259 [0x7f572ccf6b38] DEBUG - Downloading document http://127.0.0.1:32400/:/plugins/com.plexapp.agents.imdb/prefs
Apr 06, 2022 07:01:26.259 [0x7f572c2a2b38] DEBUG - [Notify] Waiting for inotify notifications...
Your media, which looks like a torrent downloader, MUST be removed from here.
Apr 06, 2022 07:01:26.418 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/AppData/Plex Media Server/Metadata/Movies/c/08994a38a2b16da8025f4eb1f9420089212ad23.bundle/Contents/_combined/art"
Apr 06, 2022 07:01:26.418 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Apollo.10.1.and.2.A.Space.Age.Childhood.2022.1080p.NF.WEBRip.DDP5.1.Atmos.x264-TEPES"
Apr 06, 2022 07:01:26.418 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Barbarians.2022.1080p.WEBRip.DD5.1.x264-NOGRP"
Apr 06, 2022 07:01:26.419 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Better.Nate.Than.Ever.2022.1080p.DSNP.WEBRip.DDP5.1.Atmos.x264-CM"
Apr 06, 2022 07:01:26.429 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Black.Widow.2021.1080p.WEBRip.x265-RARBG"
Apr 06, 2022 07:01:26.429 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Black.Widow.2021.1080p.WEBRip.x265-RARBG/Subs"
Apr 06, 2022 07:01:26.437 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Boon (2022) [1080p] [WEBRip] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.437 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Moonfall (2022) [2160p] [4K] [WEB] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.437 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Moonshot.2022.1080p.HMAX.WEBRip.DDP5.1.Atmos.x264-TEPES"
Apr 06, 2022 07:01:26.442 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Pirates.2021.1080p.WEBRip.DD5.1.x264-NOGRP"
Apr 06, 2022 07:01:26.442 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The Contractor (2022) [2160p] [4K] [WEB] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.442 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete"
Apr 06, 2022 07:01:26.448 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/Mike Epps Indiana Mike (2022) [1080p] [WEBRip] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.448 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/Mike Epps Indiana Mike (2022) [1080p] [WEBRip] [5.1] [YTS.MX]/Subs"
Apr 06, 2022 07:01:26.449 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/The Suicide Squad (2021) [2160p] [4K] [WEB] [HDR] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.449 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/Naked.Singularity.2021.1080p.WEBRip.DD5.1.x264-CM"
Apr 06, 2022 07:01:26.450 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/Space.Jam.A.New.Legacy.2021.2160p.WEB.H265-■■■■■■■■■■■■■■■■
Apr 06, 2022 07:01:26.450 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/Space.Jam.A.New.Legacy.2021.2160p.WEB.H265-■■■■■■■■■■■■■■■■■■■■■■■
Apr 06, 2022 07:01:26.450 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/Cruella.2021.1080p.BluRay.x265-RARBG"
Apr 06, 2022 07:01:26.450 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/Cruella.2021.1080p.BluRay.x265-RARBG/Subs"
Apr 06, 2022 07:01:26.460 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/The House Next Door Meet The Blacks 2 (2021) [1080p] [BluRay] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.461 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/The Misfits (2021) [1080p] [BluRay] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.467 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/Spiral (2021) [1080p] [BluRay] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.467 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/The Godfather (1972) [2160p] [4K] [WEB] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.468 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/The Tomorrow War (2021) [1080p] [WEBRip] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.468 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/incomplete/The Tomorrow War (2021) [1080p] [WEBRip] [5.1] [YTS.MX]/Subs"
Apr 06, 2022 07:01:26.469 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/watch"
Apr 06, 2022 07:01:26.469 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Born A Champion (2021) [1080p] [BluRay] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.488 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Fast.and.Furious.F9.The.Fast.Saga.2021.2160p.WEB-DL.DDP5.1.Atmos.DV.MKV.x265-FLUX"
Apr 06, 2022 07:01:26.488 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Gladiator (2000)"
Apr 06, 2022 07:01:26.488 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Gladiator (2000)/Other"
Apr 06, 2022 07:01:26.488 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Greys.Anatomy.S17.1080p.AMZN.WEBRip.DDP5.1.x264-TOMMY[rartv]"
Apr 06, 2022 07:01:26.489 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Joe Bell (2020) [1080p] [WEBRip] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.489 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Jungle.Cruise.2021.1080p.WEBRip.x265-RARBG"
Apr 06, 2022 07:01:26.490 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Jungle.Cruise.2021.1080p.WEBRip.x265-RARBG/Subs"
Apr 06, 2022 07:01:26.490 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Midnight In The Switchgrass (2021) [1080p] [BluRay] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.490 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Out Of Death (2021) [1080p] [BluRay] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.490 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Out Of Death (2021) [1080p] [BluRay] [5.1] [YTS.MX]/Subs"
Apr 06, 2022 07:01:26.491 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Rogue Hostage (2021) [1080p] [BluRay] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.491 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Snake.Eyes.G.I.Joe.Origins.2021.1080p.AMZN.WEBRip.DDP5.1.Atmos.x264-CM"
Apr 06, 2022 07:01:26.491 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Space Jam A New Legacy (2021) [1080p] [WEBRip] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.503 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Space Jam A New Legacy (2021) [1080p] [WEBRip] [5.1] [YTS.MX]/Subs"
Apr 06, 2022 07:01:26.503 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E01.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E02.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E03.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E04.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E05.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E06.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E07.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E08.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E09.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.504 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E10.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.505 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E11.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.505 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E12.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.505 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E13.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.505 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E14.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.505 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E15.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.505 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/Station.19.S04.WEBRip.x264-ION10/Subs/Station.19.S04E16.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.505 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The Godfather Part 3 (1990) [1080p]"
Apr 06, 2022 07:01:26.505 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The Hitmans Wifes Bodyguard (2021) [1080p] [BluRay] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.506 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The Shawshank Redemption (1994) [1080p]"
Apr 06, 2022 07:01:26.506 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The Shawshank Redemption (1994) [1080p]/Other"
Apr 06, 2022 07:01:26.506 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The Suicide Squad (2021) [1080p] [WEBRip] [5.1] [YTS.MX]"
Apr 06, 2022 07:01:26.506 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The Suicide Squad (2021) [1080p] [WEBRip] [5.1] [YTS.MX]/Subs"
Apr 06, 2022 07:01:26.507 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Godfather.1972.1080p.BluRay.x265-RARBG"
Apr 06, 2022 07:01:26.507 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Godfather.1972.1080p.BluRay.x265-RARBG/Subs"
Apr 06, 2022 07:01:26.507 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Godfather.Part.II.1974.1080p.BluRay.x265-RARBG"
Apr 06, 2022 07:01:26.507 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Godfather.Part.II.1974.1080p.BluRay.x265-RARBG/Subs"
Apr 06, 2022 07:01:26.508 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Handmaids.Tale.S04.1080p.AMZN.WEBRip.DDP5.1.x264-NTb[rartv]"
Apr 06, 2022 07:01:26.508 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.508 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs"
Apr 06, 2022 07:01:26.508 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E01.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.508 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E02.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.508 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E03.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.508 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E04.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.509 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E05.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.509 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E06.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.509 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E07.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.509 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E08.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.509 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E09.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.509 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E10.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.509 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E11.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.509 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E12.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.510 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E13.WEBRip.x264-ION10"
Apr 06, 2022 07:01:26.510 [0x7f572cd83b38] DEBUG - [Notify] Now watching "/volume1/PlexMediaServer/The.Resident.S04.WEBRip.x264-ION10/Subs/The.Resident.S04E14.WEBRip.x264-ION10"
Your tasks:
Dont i feel like an idiot.
Thank you so much for taking the time out and schooling a tech novice like me. Really appreciate it big time.
it all seems fine now.
All good. I know PMS is a big program to learn.
I wish there was a way for me to point to a tutorial.
(I might add it to the installer)
Now that you’re seeing the basics… maybe this will help?
I have a large FAQ to help with common questions
How do you roll back an update? I tried once and got an error that I could not go backwards once at a newer versions.
