Taegliche Backgroundtasks failen fuer etliche tausend files, werden taeglich wiederholt
Jetzt habe ich gesehn dass die taeglichen Tasks bei mir leider zu transkoder abstuerzen fuehren, und auch eine menge an daten analysiert werden sollen, aber das log mit folgendenden Eintraegen geflutet wird (sind zig tausende) und sich dass mit jedem backgroundtask wiederholt
Plex Media Server Logs_2023-06-22_12-01-26.zip (2.2 MB)
Jun 22, 2023 09:55:55.247 [140192056146744] ERROR - [Req#24fca/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] [mp3 @ 0x7fd69b93d5c0] Header missing
Jun 22, 2023 09:55:55.247 [140192101452600] ERROR - [Req#24fcb/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] Error while decoding stream #0:1: Invalid data found when processing input
Jun 22, 2023 09:55:55.247 [140192056146744] ERROR - [Req#24fcc/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] [mp3 @ 0x7fd69b93d5c0] Header missing
Jun 22, 2023 09:55:55.247 [140192101452600] ERROR - [Req#24fcd/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] Error while decoding stream #0:1: Invalid data found when processing input
Jun 22, 2023 09:55:55.247 [140192056146744] ERROR - [Req#24fce/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] [mp3 @ 0x7fd69b93d5c0] Header missing
Jun 22, 2023 09:55:55.248 [140192101452600] ERROR - [Req#24fcf/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] Error while decoding stream #0:1: Invalid data found when processing input
Jun 22, 2023 09:55:55.248 [140192056146744] ERROR - [Req#24fd0/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] [mp3 @ 0x7fd69b93d5c0] Header missing
Jun 22, 2023 09:55:55.248 [140192101452600] ERROR - [Req#24fd1/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] Error while decoding stream #0:1: Invalid data found when processing input
Jun 22, 2023 09:55:55.248 [140192056146744] ERROR - [Req#24fd2/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] [mp3 @ 0x7fd69b93d5c0] Header missing
Jun 22, 2023 09:55:55.248 [140192101452600] ERROR - [Req#24fd3/Transcode/aaa644ec-32b3-4b8b-9d63-9f5194e4cc06/ff66bdd7-db26-4f30-9a6c-c3bbb08b8c94] Error while decoding stream #0:1: Invalid data found when processing input
wobei im syslog auch immer wieder dir crashes des media scanners verzeichnet werden:
Jun 22 09:46:26 plex Plex Media Server[13217]: ****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.32.4.7195-7c8f9d3b6/PLEX MEDIA SCANNER/fb07c643-f815-438a-c03714bd-606158b3.dmp
Jun 22 09:46:26 plex kernel: [ 7617.375124] PMS LoudnessCmd[13221]: segfault at 0 ip 00007f6331a10060 sp 00007f632de410d8 error 4 in libswresample.so.4[7f6331a08000+18000]
Jun 22 09:46:26 plex kernel: [ 7617.375135] Code: 01 cf 4c 39 c7 72 e3 c3 cc cc 8d 04 49 48 98 4d 89 c1 49 29 c1 48 63 c2 48 63 c9 49 39 f9 76 75 f2 0f 10 05 22 05 ff ff 66 90 <0f> bf 16 0f 57 c9 f2 0f 2a ca f2 0f 59 c8 f2 0f 11 0f 0f bf 14 06
Jun 22 09:46:30 plex Plex Media Server[13240]: ****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.32.4.7195-7c8f9d3b6/PLEX MEDIA SCANNER/99d11d26-c266-4287-198347b0-8f936d92.dmp
Jun 22 09:46:30 plex kernel: [ 7621.503837] PMS LoudnessCmd[13247]: segfault at 0 ip 00007fc8572d5060 sp 00007fc85369d0d8 error 4 in libswresample.so.4[7fc8572cd000+18000]
Jun 22 09:46:30 plex kernel: [ 7621.503844] Code: 01 cf 4c 39 c7 72 e3 c3 cc cc 8d 04 49 48 98 4d 89 c1 49 29 c1 48 63 c2 48 63 c9 49 39 f9 76 75 f2 0f 10 05 22 05 ff ff 66 90 <0f> bf 16 0f 57 c9 f2 0f 2a ca f2 0f 59 c8 f2 0f 11 0f 0f bf 14 06
Jun 22 10:17:01 plex CRON[17707]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 22 11:06:34 plex Plex Media Server[17958]: ****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.32.4.7195-7c8f9d3b6/PLEX MEDIA SCANNER/185c1e4e-ef02-4d08-26dbaaad-f70712e4.dmp
Jun 22 11:06:34 plex kernel: [12425.384536] PMS LoudnessCmd[17962]: segfault at 0 ip 00007f9eab91f060 sp 00007f9ea7d590d8 error 4 in libswresample.so.4[7f9eab917000+18000]
Jun 22 11:06:34 plex kernel: [12425.384547] Code: 01 cf 4c 39 c7 72 e3 c3 cc cc 8d 04 49 48 98 4d 89 c1 49 29 c1 48 63 c2 48 63 c9 49 39 f9 76 75 f2 0f 10 05 22 05 ff ff 66 90 <0f> bf 16 0f 57 c9 f2 0f 2a ca f2 0f 59 c8 f2 0f 11 0f 0f bf 14 06
Jun 22 11:06:37 plex Plex Media Server[17981]: ****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.32.4.7195-7c8f9d3b6/PLEX MEDIA SCANNER/69361c88-cf5c-468f-7812168d-3bad1bdb.dmp
Jun 22 11:06:37 plex kernel: [12428.732406] PMS LoudnessCmd[17985]: segfault at 0 ip 00007fd1cc36d060 sp 00007fd1c87a70d8 error 4 in libswresample.so.4[7fd1cc365000+18000]
Jun 22 11:06:37 plex kernel: [12428.732413] Code: 01 cf 4c 39 c7 72 e3 c3 cc cc 8d 04 49 48 98 4d 89 c1 49 29 c1 48 63 c2 48 63 c9 49 39 f9 76 75 f2 0f 10 05 22 05 ff ff 66 90 <0f> bf 16 0f 57 c9 f2 0f 2a ca f2 0f 59 c8 f2 0f 11 0f 0f bf 14 06
Jemand eine idee wie man hier weiter vorgeht, da ich den eindruck habe, dass das bei jedem backgroundtask beginn immer wieder von vorne passiert …
Anbei noch die Server logs!
Waere toll wenn mir hier jemand helfen kann!
LG,
Martin
