Ted Talks
#1
Ted Talks channel is broken with latest Plex update.
#2
The Ted Talks channel seems to be working as expected. And there are no errors in the channel log files.
You should first review the READ FIRST: Guidelines for Posting Channel Plugin Issues/Questions and Things to Check First document pinned to the top of the Channel Plugin Forum.
It provides links to the Channel Plugin support documents, things to check first, and explains where and how to post your issue and the details to include, so others are able to provide help. Especially the section titled "Plex Player App/Plex Media Server Issues."
I would also suggest reviewing the Frequently Asked Questions for Channel Plugins document also pinned to the top of the Channel Plugin forum. Especially the section titled "Why won't any of the videos play on one or more of my channel plugins?"
#3
"latest Plex update", what is that? Server, a specific client? Always add as much info to a post as possible, because this is not telling anything and we cannot help you. Also add log files, in this case com.plexapp.plugins.ted.log and com.plexapp.system.log.
