"There are no items in this library"
server-freebsd
#1
Hello
I am using Plex for the 1st time
Online problem seems that My Libary is not populating with video with I added
and while setting the library i am not getting only these folders
Folder looks like this
and this is inside freenas
#2
As discussed in this thread, this is a bug in FreeNAS. You can still type the path in manually in the top portion of the dialog.
#3
What do you mean by “You can still type the path in manually in the top portion of the dialog.”?
I tried to Map the Media in var/db/plexdata/Plex media Server
Now its showing in the Browse Folder Tab
And I have these 2 in movies
still nothing showing up
“There are no items in this library”
#4
You seem to be adding the wrong directory. According to your prior image:
you likely need to be using some path within /media. Perhaps /media/Movies is what you want.
