"There was an unexpected error loading the dashboard"
server-windows
#1
It doesn't mater what computer i'm on I receive this error. Tried clearing browser cache as that worked once a long time ago. It seemed after the last two updates it was intermittently working. I tried running "optimize database", "clean bundles", and "empty trash" in that order. Tried a few times but no luck.
#2
How many libraries do you have?
#3
See https://support.plex.tv/hc/en-us/articles/201643703-Reporting-issues-with-Plex-Media-Server
https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
#4
I have 3 libraries "TV Shows" "Music" "Movies"
#5
I've attached my log files after following the steps.
Plex Media Server version 1.7.6.4058 (Plex Pass)
On Windows Server 2012 R2 Virtual Machine
#6
I will look at the logs shortly but we have had a few reports now on windows servers. Do you use RDP and terminal services ? There appears to be an issue of per session temp directory setting which is affecting the load of the hubs and access to the temp directory
Are you able to access %TEMP% ?
#7
Yes I can see the temp directory issue - where for some reason got an sqlite3 got an error accessing a temp directory Temp\2\
Jul 15, 2017 13:56:17.563 [4168] ERROR - SQLITE3:B412B992, 14, os_win.c:41841: (3) winOpen(C:\Users\janitor\AppData\Local\Temp\2\etilqs_2ypRqroomvDCpZ7) - The system cannot find the path specified.
Jul 15, 2017 13:56:17.563 [4168] ERROR - SQLITE3:B412B992, 14, cannot open file at line 41850 of [fc49f556e4]
Jul 15, 2017 13:56:17.563 [4168] ERROR - SQLITE3:B412B992, 14, statement aborts at 668: [select distinct media_items.id as 'media_items_id', media_items.library_section_id as 'media_items_library_section_id', media_items.section_location_id as 'media_items_section_locatio
Jul 15, 2017 13:56:17.579 [4168] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: unable to open database file
Jul 15, 2017 13:56:17.579 [2608] DEBUG - Completed: [::ffff:1.1.1.98:63486] 500 GET /hubs?excludeFields=summary&count=12&includeEmpty=1&excludePlaylists=1 (8 live) TLS GZIP 1054ms 478 bytes (pipelined: 4)
There were reports that this arose if Plex Media Server is launched through RDP
See if %TEMP% is accessible
I can also see you have been some crashes - at
Jul 13, 2017 19:46:23 and Jul 12, 2017 19:14:35
I will try and locate the crash reports
#8
I use RDP to access the server, this isn’t a terminal server. Not much running on this server other than plex and plexpy. I close plexpy to see if it would resolve the issue as a couple months ago there was an issue that just closing plexpy fixed it.
I tried accessing %TEMP% and it reports back it can’t find it.
#9
Looking into the temp dir its there all the way except for the last folder named 2. I created the folder and the dashboard is back :smiley:
#10
Thanks for your help on this. seems odd Plex didn't create the folder unless this is something the OS should have done?
#11
I don't know why this issue is suddenly arising. It is to do with Per Session Temp Directory
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server\PerSessionTempDir
It has been raised with the development team but has not been possible to reproduce it
#12
See
technet.microsoft.com/en-us/library/cc732258(v=ws.10).aspx
#13
ah, i'll have to adjust that on the domain for the plex server. That would explain possible why i've seen the dashboard from time to time not work. maybe plex recreated the folder but after a log off or server reboot it went away. Thanks
#14
If the problem is easily reproducible and you are comfortable with running SysInternals Process Monitor, I would like to look at a PML capture covering period from launch of Plex Media Server up to the time when the open file fails on that temp file - together with the matching logs. Might also be useful to get a process dump after to see what environment variables get set. You can use SysInternals Process Explorer to get a full dump file
If you are happy with that, you can send me a PM with link to where they are uploaded to. PML files which could be huge do zip very well
#15
If you still get these crashes, I would not mind having logs with debug logging enabled. At those times, the logs did not have debug logging enabled
#16
Question, I didnt bother to attach logs cause this issue keeps repeating itself even when I rebuild the db's. I have a server power edge 900 running direct attach storage holding 45TB of content. When I updated PMS to 1.7.5 this dashboard started to crash... so.. likewise.. i rebuilt the db and reinstalled the entire PMS platform, worked for a few hours then... dashboard went out again. So without removing the DB files and making any changes... i reverted back to 1.7.0 and dashboard worked.. no issues using the same DB's as the non working 1.7.5 server, Thought this detail may be important for ya'll.
RETRACTED Occurred with 1.7.0 as well.
#17
Hello all,
I'm seeing this exact issue but without a domain joined machine / no terminal services. Checking "System Properties -> Advanced tab -> Environment Variables" reveals that windows has the local temp folder as simply "%USERPROFILE%\AppData\Local\Temp". However, executing %TEMP% or %TMP% takes me to "%USERPROFILE%\AppData\Local\Temp\4" - this folder regularly gets deleted when logging out, which in turn breaks Sabnzbd, Plex, Sonarr, etc.
Any ideas how to possibly remedy this? Thanks in advance.
#18
@pemang said:
Hello all,
Do you use RDP ?
What is the value of this registry field ?
What OS version? Is it Windows Server 2016 ? Windows Server 2012 R2 ? Windows 10?
#19
Thanks for the reply. Yep i use RDP, from my personal computer (Windows 10) to my server (Windows 2012 R2)
I found the DWORD PerSessionTempDir and it is a hex value set to 1.
#20
I presume it is now being set to plug security issue with RDP - see
https://www.stigviewer.com/stig/windows_server_2012_2012_r2_member_server/2016-12-19/finding/V-3455
It appears to cause problems with Plex Media Server - so my advice would be not to use RDP for launching Plex Media Server
