TIVO Roamio "..." Issue
smart-tv
#1
I'm having an issue with my TiVo Roamio. Since the latest server update, I get "..." In the center of my screen when playing video, then after approx a minute, Plex gIves error, unable to start video. This happens to all videos. Strangely enough the TiVo Minis work fine.
#2
I rolled back to PMS ver 1.3.4.3285 and everything works fine.
Funny enough, it tells me I'm up to date now and is not telling me no update is available.
I did notice that the PMS 1.4 update that was not working, had the Plex DVR in it, I'm now wondering if it was rolled out as an update in error.
#3
I have the same problem on the Bolt. I will roll back as you suggested and see what happens.
#4
Same here, updated plex server to version 1.4.1.3362 and now i also see the 3 dots in the middle of the screen on my TiVo Roamio.
#5
where do i get the older pms version for mac?
#6
Same here.
Anyone know if this is being addressed??? Damn, wish I didn't have update set!
#7
Any idea how to rollback on a Windows Plex server??
#8
Same Issue here, was able to play andriod tablet, samsung tv app just fine.
#9
For previous version of the Plex Media Server in Windows, look here on your computer:
%LOCALAPPDATA%\Plex Media Server\Updates
I had like 30 old versions in there!
And like the OP, I uninstalled 1.4.1.3362 and reinstalled version 1.3.4.3285 and everything works fine, no more buffering screen of " . . . "
#10
+1 this issue. Guess I'll be rolling back to previous.
#11
Still broken in the newly-released 1.4.2.3400 version as well... back to 1.3.4.
#12
same thing for me, two Roamio Pro's had this issue. But my two Mini's were fine. Rolled back to 1.3.4 and it's working fine.
#13
Hi folks, we're on the case. Curious!
#14
I'm having trouble recreating playback problems on my TiVo Bolt with Plex Media Server 1.4.2.3400-ab906953b (latest Plex Pass download). So far I've attempted to Direct Play and Direct Stream MKV files with AC3 and DTS audio. The MKV files are pretty typical 7-10GB Blu-ray encodes at 1080p and AVC level 4.1. I've also direct played supported MKV and MP4 files. No troubles so far.
I would super appreciate any information to find the missing link. Some of you have provided some of the information below although if you wouldn't mind consolidating it for me it would be really helpful.
  • Your TiVo model (Bolt, Roamio, etc) and system software.
    • I'm on a pre-release system software for development - perhaps the latest PMS is tickling an issue in an older system software.
    • We have other devices on production system software which we'll continue testing on.
  • The XML Information for the video which fails.
  • Plex Media Server log files.
    • Please follow these instructions to prep your server for logging.
    • Before recreating the ... issue please enable Settings > Privacy > Log to Media Server in the settings within the Plex app on your TiVo device.
    • After recreating the issue and downloading the logs please feel free to disable Log to Media Server and debug level logging.
I'm hopeful that the logs sent to your media server will indicate why the app is showing the ....
#15
OK, here's my info... I notice you didn't test any mpeg2 files, which most of mine happen to be...
TiVo Roamio Plus, software version 20.6.3.RC15-USA-6-848
Media info XML and server logs attached.
#16
Here's another one in case it helps.
Tivo Series 5, software version 20.6.3.RC15-USA-6-848
And by the way, NONE of my videos work now. They all get the dots, and then fail after what seems to be the exact same amount of time. I have all mkv files, and I never had a single problem before this release.
Thanks!
#17
I am also getting this issue after upgrading to the latest version of PMS. However, one interesting fact is that it does not do it for "all" movies. Until the upgrade though it never happened.
#18
Also happening here with the Bolt and PMS on FreeBSD 1.4.2.3400.
TiVo Software Version: 20.6.3.RC16-USC-11-849
#19
Tivo Roamio Software version 20.6.1a.RC11-USA-6-848
I will update my server again to get a log with the error, when I'm at home.
#20
Once I reverted back to the PMS update before the latest one everything worked fine again so I will just stick with that until this issue gets resolved.
