Transcoding on the fly no longer seems to be working
server-freebsd
#1
I was running that last DVR Beta and decided to upgrade. Upgraded to 1.5.2, then to 1.5.4, and in both versions when trying to transcode a file I get the following error:
ERROR - Throttle: timed out trying to read chunk -1
I wondered if it was a permissions problem, but everything looked fine. All the files I'm trying to play worked fine previously. Only files that work are ones that don't need to be transcoded while playing.
#2
I updated to Version 1.4.4.3495 via pkg today and now I cant get anything to play. It worked just fine before the upgrade.
#3
Apr 14, 2017 15:21:40.495 [0x80be46300] WARN - Transcode runner appears to have died.
Apr 14, 2017 15:21:40.601 [0x80be46300] WARN - Timed out waiting for segment.
Apr 14, 2017 15:21:40.602 [0x80a079800] DEBUG - Completed: [xxx.xxx.xxx.xxx:51285] 404 GET /video/:/transcode/universal/session/imbb5eynovb7kvv4rydv8vay/base/00000.ts (4 live) TLS 107ms 288 bytes (pipelined: 9)
#4
What was your solution? Having the same problem.
#5
Hello,
Were you able to fix it?
