Trashcan not showing on Plex Pass upgrade path - newest Version 1.9.5.4339
server-windows
#1
I just noticed recently that i had some media that was linked to an old drive location that no longer exists on my server. Any media that has this path obvious should show a trashcan because its not accessible. I however do not see a trashcan on the poster image in any view in the web app accessing the server. I only see that its unavailable when i cilck the … and get info. Is there a recently introduced bug with the poster showing the trashcan properly?
#2
This intended behaviour.
The trashcan will only be shown when the media is considered 'deleted'.
Since they are on a 'missing' drive, Plex doesn't consider them 'deleted'.
If you want to remove them, edit your library and remove the missing drive or folder from the 'Add Folders' tab.
#3
Wow thank you that's very helpful. I didn't realize this worked that way but it makes it very flexible to have it not assume they are deleted especially with people using cloud drives n such.
#4
Precisely. Or external drives which could be powered down, have a loose plug or simply were temporarily removed.
