Trying to build OpenPHT v2 Embedded but no Wetek Hub option available
openpht
#1
I am hoping one of the devs sees this. I just tried to build openpht-2.0 but there is no longer an option for the Wetek Hub. Just wondering if this is a mistake or if the Hub is no longer supported for embedded?
#2
I also have a RPi2 but that is not listed either. Hopefully I just jumped the gun a bit, its only been up a week.
#3
Doh, ok I looked a bit closed and found the DEVICE option DISTRO=RasPlex PROJECT=Amlogic DEVICE=WeTek_Hub ARCH=arm make image
