Server Version#: 1.42.2.10156
Player Version#: Roku 9.0.34
Tuner Make/Model: HD Homerun Quattro
Guide/Lineup name: Freeview
Using XMLTV?: No
Channel number/Name: N/A
Not sure if there’s a button I’m not pressing correctly, but I’ve noticed a quirk which is a tad annoying.
On the Live TV Guide, if there’s a program starting within the next minute or two the program shown for that channel will be marked as starting at that time.
Because of this when you press OK on the channel it goes into the program itself and asks if you want to record it as it’ll be starting in that next minute for example.
But, this then makes it not possible to just tune into the channel to watch the remainder of the program that was on. I’ve tried pressing the play button on the roku remote instead but it still doesn’t work.
I’m having the same issue with both the Roku Preview and the regular versions. The issue makes it imposable to switch to a live channel in the last few minutes of a show or the fist few minutes of a show about to come on.
