Unable to use external network access to allow it to function normally
Server Version#:1.40.2.8395-7000
Player Version#: 1.40.2.8395
I don’t know how to set up my router and PLEX so that it can access the external network.
as first step, turn off manual port number.
If that fails. log into your modem/router and confirm UPNP is enabled
and try again.
If you can’t get into your modem/router share the name & model with us and we’ll go look for documentation on google.
Asus RT-AX1800 Plus
Does your ISP provide you a publicly routable IPv4 address?
@Siaomo
Page 56 - Virtual Server/Port Forwarding.
If you prefer Traditional Chinese,
OK I will try
@Siaomo
Example Port Forward in an Asus RT-AC68U (when I had an Asus router)…
The RT-AX1800S should be very close.
Service Name: Anything you want. Does not matter.
External Port: Must match manual port number in Settings → Remote Access
Internal Port: 32400
Internal IP Address: The IP address of your Plex server.
Protocol: TCP
Source IP: Blank.
Like this? i setting Set up
But after a few seconds I still get the message “Unable to use external network access”
i setting Set up
Is the box for external port checked in Settings → Remote Access?
If not, check it then try to enable remote access.
