Unsupported AppStore V2 (as in totally unsupported)
#1
WebTools V3 has been released
THIS THREAD IS CLOSED, USE WebTools V3 thread
#2
Hmmm......Been active now for +24 hours....
Visited by + 1000 people, and downloaded lots of times, and yet......Not a single comment nor feedback here?
Did we fail big time, or it no news good news?
/Tommy
#3
I installed it and LMWT shows all my shows and all the sources but they are
all unplayable. :-(
#4
all unplayable. :-(
Well....That's really good news, in a bizarre way.....
Cuz that means that UAS is working for you, which is what this thread is about.....
But sadly also means, that you didn't follow the rules laid out in the first post, saying:
@dagalufh said:
This thread is for handling support for the UAS2 itself, and NOT for any of the plugin's that get's installed with it.
So...Simply put....
* If the plugin installed, then go to the plugin support thread for questions! (Also if it simply isn't working for you)
* If a plugin failed to install, then continue in this thread
* If the plugin can't be uninstalled, then please go ahead, and post here
* If a plugin is missing here, then go to the plugin support thread, and ask the author to add it
* If this is regarding other plugin's to WebTools, or WebTools itself, go to the WebTools thread
So go hunt down the dev in the support thread, that you can find in the UAS module!, as well as in here:
forums.plex.tv/discussion/200017/support-find-my-plug-in-here-for-support#latest
And even though you did NOT follow the rules, that I do hope people will do in the future, so this thread will NOT drown in unrelated post, I do welcome you as the first UAS V2 user that responded here ;-)
Thanks for confirming, that it actually works
/T
#5
I noticed that the Uninstall now removes files from the support directory too? Is this intended?
#6
Please define "Support directory", and if meaning the "Plug-in Support", then yes, this is WAD (Working as Designed), since we decided to do a full cleanup, and if possible, not leave any traces behind
Bad call?
/T
#7
  1. why does the channel just bring up text to a link to the real channel that is not even a hot link and in windows can't even right click and copy link ?
  2. is it possible to set it to default to "all channels" when you select the unapproved channels section ?
(one word of advice tone down your responses you begged us for comments and then seem a little defensive on replies)
#8
Yes the "Plug-in Support" directory.
Bad call?
No, It's nice to have it clean the Plug-in Support directory. I just noticed it when testing on my channels, since they store Bookmarks within the channels Dict.
Is the Updater smart enough to removed old unused files/folders? I.e. a developer removing the "Services" directory and implementing the relevant code in the __init__.py file? If not then this will break a channel upon updating.
#9
I guess here, that you are talking about when viewing the channel from within Plex it self, and if so, then sadly due to the limitations of the API within Plex, since it was designed to show movies etc, and we are kinda breaking that limit ;-)
Sadly, currently hardcoded to applications.
If this is a strong need, then please open a GHI, and state the user case for this:
github.com/dagalufh/WebTools.bundle/issues
So sorry for that, and didn't mean to, so if my first response came out like that, then I'm truly sorry, but really fear that this thread would end up like the old UAS thread, meaning having to support all kinda channels in the UAS, that I have never used, nor know of.....And due to that, sadly on my guards here ;-)
And do hope for understanding here....
After all, launching a replacement to the most downloaded/busy addon ever in the history of Plex, is kinda a huge task ;--) And would love for stuff to be separated out to the threads where it belongs, cuz if not, time spent here eq. less time developing ;-)
Best regards, and HUGE thanks for the feedback
Tommy
#10
During an update, we simply overwrite what's already there, and sadly fails to see the point here, since left over files from old versions would not be active, unless called by the code, or?
/T
#11
Plex Framework will load the Service code directory if it exist, whether you want the channel to or not. If a Developer used to use the Channel's Service directory and then chooses not to in a later version, then Plex will still load the old Service code because the updater didn't clean/remove it in the update. Granted, this is an unlikely situation but it is one I've ran into before.
Other than the situation described above, I see no harm in the way the current updater functions. Like I said, this a special case and will not affect 99% of developers.
#12
after doing a "migrate manually/previously installed" I have 35 unknowns. If in the future the owner moves them to the unsupported appstore will I have to do anything else ? Or will they automatically be moved to the proper category and be able to check for updates ?
#13
I'm not sure if I understood all info about the new UAS v2 correctly, but it seems that the ONLY way to get it installed is to first install yet another Webserver on my PMS computer. But what's never stated is when and how it is required for this web server to run.
It's fine if I just need it to provide a GUI for installing UAS and its channel bundles, so I can kill that server again each time I've used it. But if I have to run this new web server continuously 24/7 just like I do with PMS and PlexPy, just in order for installed UAS channels to function, that's unacceptable to me.
I don't really understand why it was considered necessary to add another server for this purpose.
The old UAS installed as a normal channel, and could in turn handle installation of all UAS-supported channels. The only thing wrong with it was the bad choice to make channel updates automatic, and in my opinion that's the only thing which needed to be changed for a new UAS implementation (apart from general tweaks of course).
While I don't like this unnecessary dependency on an extra server, I will try it out and see how it works.
I just hope that my worry about needing the server to run constantly is unfounded, as I won't allow that.
Best regards: dlanor
#14
I’ve installed WebTools but when I click the ‘Unsupported appstore’ in webtools, I get this error message:
I have restart the server serval times.
Any ideas?
#15
We have an enhancement out for that already ;-)
github.com/dagalufh/WebTools.bundle/issues/55
#16
WebTools is simple a channel, like any other channels, but has everything it needs build into it
It's using the webserver build into Plex
Then change the old one, and share with people.
The new one is part of a collection of tools, and has IMHO a much nicer interface, as well as not limited to an interface, that was constructed to view movies
And as said, you got it wrong ;-)
No extra server is needed
/T
#17
Any ideas?
I would need the WebTools.log for that, sadly
#18
Any ideas?
Hi, I uploaded it to pastebin, http://pastebin.com/KFteVNHt
Thanks!
#19
You have a permission error here:
Exception in updateUASCache [Errno 13] Permission denied: '/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/WebTools.bundle/http/uas'
The Plex user running PMS, needs full access to the Webtools folder
/T
#20
And to expand on this....
When UAS module is activated, it compares the last update time with the one found on GitHub for the uas repo github.com/ukdtom/UAS2Res
If the one locally is older, or missing, it'll update the cache, but sadly can't here, due to missing rights
