Since Freebase was shut down, I switched over to The Movie Database agent, but it’s not pulling the information from Open Movie Database (so I can get IMDB plots, ratings, etc) like Freebase was. I have it listed first in priority, but every time I add a movie, the metadata that is populated is from The Movie Database even though I have it listed below OMDB.
Anyone else able to get OMDB work with The Movie Database Agent?
Maybe it’s because it was designed to work with Freebase.
It uses the existing Freebase Agent to lookup the IMDb id, then retrieves movie info from Open Movie Database.
https://forums.plex.tv/discussion/21894/rel-open-movie-database
I wonder if it can be fixed to work with the movie database agent.
This issue should be fixed with this commit, there was something missing in the plist file to work with The Movie Database agent.
Doesn’t work for me. Somehow my Freebase agent disappeared, so is there any way to get OMDB to work? I’ve tried putting it at the top of the sub-agents list under TMDB, but it never retrieves any matches.
