view by folders
night
#1
Hi. Thank you for the awesome skin and apologies if this is a dumb question or the wrong place to ask it.
I believe, in the main PHT client, there's an option to view a library (in this case a 'home movies' library) organised by folders. Does this option exist in Night? And if so where?
#2
Go into the home movie library and you need to activate the "context menu" which depends on your remote mapping. Or use a keyboard and C
You will see a menu with a Filter option of By Folder
#3
Great - thank you Horse! I never got around to mapping the context menu to my remote, so i never think to look for things there...
#4
Has this option been removed? I don't see it under filter any more
