Web client - 'Unwatched' filter broken?
plex-web
#1
If I chose the 'Unwatched' filter in my TV section in the web client, I'd expect it only to show shows that have unwatched episodes.
This doesn't seem to be the case.... the section refreshes but looks exactly the same as before.
#2
This should be fixed in the next update. The web client is basically saying to filter shows by their watched count, which doesn't really make sense. You will be able to switch to show episodes and then filter by unwatched count, which is what you are looking for.
#3
Ok good to hear it's going to get sorted :)
#4
Hi
This Problem still seems to be present in the current web-app release.
although lots of my show do not contain any unwatched episodes they are still shown in the GUI when i filter for unwatched.
Should this be fixed by know or is this a known defect?
cheers
udo
#5
[quote name='udo' timestamp='1349338994' post='300495']
Hi
cheers
udo
[/quote]
This will be fixed in the next media server release. The unwatched filter will only show for the episodes type.
#6
[quote name='ericmatthys' timestamp='1349355454' post='300536']
[/quote]
Thanks for working on this, this particular bug has been frustrating for me!
I'm a little confused what you're saying the fix will be, though. For me, when I click on TV Shows in the Web Client, then click the "unwatched" filter, I would expect to still show shows by title, but only the ones with episodes currently unwatched (I know it already knows which ones are like this, as they have a little orange circle with a number in the corner), i.e. the ones that in the current release have an orange number circle. Basically, I would expect it to show the list of shows, just like going to TV Shows > Unwatched does in the current PMC.
If the unwatched filter only shows for the episode type (which I believe is what you're saying), that could get really overwhelming. One show alone marked as fully unwatched could be tens or hundreds of episodes, making viewing the list unmanageable. That's why I would hope the filter will still be available for Show type as well, just with the expected behavior (only showing posters for shows that have unwatched episodes), as otherwise I don't think it's useable for a large collection.
But I may be not following, I'm not entirely sure. :unsure:
#7
[quote name='bucketachicken' timestamp='1349491111' post='300886']
[/quote]
I understand the use case for just wanting to see shows with unwatched episodes. Only showing the Unwatched filter for episodes is more of a quick, short-term solution. Currently, the unwatched filter for shows just doesn't work, so I would rather it now show up at all until we can get something for it working.
#8
OK, good to know, just making sure it wasn't going away forever!
#9
[quote name='ericmatthys' timestamp='1349518022' post='300915']
[/quote]
to me that sounds more like a work-around instead of a short-term solution.
what i as a user would be looking for actually is "Unwatched Shows" (i.e showing the TV-Shows with unwatched episodes) like it's the case with all other plex clients.
When selecting such an unwatched show it should then show unwatched seasons and the episodes per default als the unwatched filter is selected from before
i for one do specifically not want to switch between shows / episodes view to filter for unwatched/watched, so please make this a very.short.term-solution.
cheers
Udo
#10
[quote name='udo' timestamp='1349633835' post='301162']
cheers
Udo
[/quote]
I definitely know where you're coming from. I'll make sure it's noted for the media server so hopefully it gets in by the next update.
