WebTools (Unsupported AppStore)
#1
GitHub issues Release Download latest release Download total master Maintenance
About:
WebTools is a collection of utilities to help with the management of your Plex Media Server. This plugin is not limited to the usual channel interface. Instead, it utilizes a built-in web-server to display a responsive web interface which also works on mobile devices, allowing you to manage your Plex Media Server from any device.
This tool was created by omc1000 (Frontend) and Dane22 (Backend)
Currently available tool modules are:
Localization:
WebTools is now a multi language program, that as the time of writing supports the following languages:
  • Arabic
  • Chinese (simplified)
  • Czech
  • Danish
  • Dutch
  • English
  • French
  • German
  • Greek
  • Hebrew
  • Hindi
  • Hungarian
  • Italian
  • Korean
  • Norwegian Bokmål
  • Polish
  • Portuguese
  • Portuguese (BR)
  • Romanian
  • Russian
  • Serbian
  • Spanish
  • Swedish
If a language is missing from the list above, or the current translations of your language is incomplete, then please help us translating this for the benefits of your countrymen, do go here
Manual:
To see the complete online manual, with all the details about thís plugin, please visit the Wiki
Installation:
To install this plugin, please click below
Click here to Install! <--------------------------------------------------
Usage:
After installation, to use this plugin, browse to http://<IP of PMS>:33400 Do NOT click on the channel menu, but browse directly in a new browser tab
Support:
Since WebTools contains the module UAS (Unsupported AppStore) you might think, that this is the place to post questions, if a plugin installed via the UAS is not working for you, but it’s not Instead, locate the relevant support thread here Any questions regarding other plugin’s than WebTools WILL be ignored! But…If a plugin fails to install using WebTools UAS module, then this is the place :wink: Before you post a question, please make sure it’s not already mentioned in our FAQ or Knows issues, and when posting, please add as much info as possible, as well as log files if possible, and do NOTE that we do expect that you read this thread as well, in order to not post a question already answered.
3.Party Developers
If you are a 3.Party Developer, then please look here
Support the developers:
If you use WebTools and you are willing to support the developers with a beer or two, then please click on the ‘Donate’ button below.
Thank you for your support!!
Donate
Disclamer:
This plugin is in no way associated with Plex Inc. It’s merely a humble plugin, trying to improve on perfection. Use of this plugin is at own risk, no responsibility is taken from either Plex Inc. or the developers of this plugin. Regarding the Unsupported AppStore: We take no responsibility for the content/stability/suitability of the contained plugins and any complaints or requests for support in relation to specific plugins will be ignored.
Playlists movement
[REL] epg-dk
#2
Excellent!
Beautiful!
I have idea regarding the techinfo page and the sensitive information.
Where do you want suggestions/feature requests going forward?
Forums? Or issue tracker as an enhancement request?
I see reasons for either. Issue tracker could inconvenience/would require the Plex forum user to go create yet another account, but forums could get lost in the mix.
#3
@JamminR
I always prefer GHI's, but fully understand what you are saying here ;)
So either way will do
#4
Well, after I posted, I went ahead and posted a feature request at github.
Reference #453 - https://github.com/ukdtom/WebTools.bundle/issues/453
In Techinfo, Show/Hide sensitive information using a button/link.
This would allow safe copy/export.
EDIT - and Ukdtom has already classified it.
#5
Any particular procedure I should follow in order to uninstall WebTools V2 or just delete it from the Plug-ins directory?
-Server is on a Win7 box
#6
Nope...
Nuke it, install the new one...
When done, logon, go to UAS, and select Migrate
#7
@dane22 Thanks
#8
Question: Does WebTools need to be installed on the same computer as PMS? I have PMS running on an iMac, but I also have a QNAP NAS. Can I run WebTools on my QNAP? Or would I have to install it on my iMac?
#9
Yes.
Unless you run your PMS server Plug-ins folder from your QNAP, No.
It goes in PMS plugins folder.
Installation:
#10
Thx for a great plugin. However I have problem that I can't delete external subtitles from Agents.
When I try to delete it seems to be deleted but when I refresh the page it reappears again. I get no errror... Deleting sidecar subtitles works fine.
#11
@anders84
Is the agent still enabled?
Cuz if so, it'll instantly redownload it ;)
#12
And added to our FAQ
#13
@dane22 said:
@anders84
Thanks! You were right. I can't believe how quick it is redownloaded, almost as it is cached somewhere.
#14
I manually installed WebTools 3.0 for PMS on CentOS recently. PMS says the channel is “Not responding” and I am unable to connect via default ports.
I’ve attached logs and a screenshot of permissions via ls -l
Not sure how to fix the issue. Thank you
#15
@TrumpNet
Bad upgrade I guess.
Try this:
  • Stop PMS
  • Delete WebTools folder
  • Do a manual reset
  • Re-Download and install WebTools again
#16
Congrats on WT V3, I love it! Now that you gave us Playlists, could it be possible to add something like "Copy all Playlists to all users", so we don't have to copy each individual playlist to each individual user? Thanks again!
#17
@jpbelanger
github.com/ukdtom/WebTools.bundle/issues/464
#18
@dane22 said:
@TrumpNet
Try this:
  • Stop PMS
  • Do a manual reset
That worked and after opening ports WebTools is working. Thanks
#19
@dane22 said:
@jpbelanger
Wow thanks a lot!
#20
Awesome idea.
I just now realized when looking at the Playlists tool that the playlists are (apparently) stored on my server.
I thought the user playlist was stored at Plex.
