I used to be able to type IP manually to force offline LAN connection to my HOME server.
I do have 2 NIC IP addresses and tried both without success.
This was working for me until recently
Any help is appreciated.
I have the latest WINDOWS Pms and Samsung TV PLEX app
Read this: https://support.plex.tv/articles/200430283-network/ with interest on LAN network settings. Define your LAN and everything can connect locally
so to enable access on LAN under “List of IP addresses and networks that are allowed without auth” I should specify my entire class C like so:
192.168.1.0/255.255.255.0???
I am a bit confused
grhiner
January 26, 2019, 12:54pm
4
That is correct to my understanding. It worked for me and made the home LAN seem to work better as well
Did not work for me. Do I have to restart PMS after?
I didn’t need to if I remember correctly. It has been awhile
