Here are workarounds and settings I’ve found useful to get multichannel working out HDMI in plexamp
Pi3 (running raspberry pi os lite)
Edit the config.txt to include these lines
hdmi_force_hotplug=1
hdmi_force_edid_audio=1
hdmi_drive=2
change this line
dtoverlay=vc4-kms-v3d
to
dtoverlay=vc4-fkms-v3d
Copy and paste the below text to be your /etc/asound.conf
# Plexamp on Pi 3 - 5.1 HDMI with Center ↔ LFE swap
# Forces “Default” to be 6ch + remapped so Plexamp sends real 5.1
pcm.!default {
type plug
slave.pcm “remap51”
slave.channels 6 # ← THIS is what makes Plexamp see full 5.1 capability
pcm.remap51 {
type route
slave.pcm “hw:0,0” # the real multi-channel HDMI device
slave.channels 6
ttable {
0.0 1 # FL → FL
1.1 1 # FR → FR
2.3 1 # FC (input 2) → hardware FC (position 3)
3.2 1 # LFE (input 3) → hardware LFE (position 2)
4.4 1 # RL → RL
5.5 1 # RR → RR
HP EliteDesk 800G2 (running dietpi)
pcm.hdmi_raw {
type hw
card 0
device 3
pcm.routed8 {
type route
slave {
pcm “hdmi_raw”
channels 8
ttable {
0.0 1
1.1 1
2.4 1
3.5 1
4.6 1
5.7 1
6.6 0
7.7 0
pcm.!default {
type plug
slave.pcm “routed8”
slave.channels 8
ctl.!default {
type hw
card 0
I’ve not been having any luck with the Pi4 so far, but am hoping to crack that nut eventually.
Pi 4
Raspberry Pi Lite Bookworm
set hdmi to default with raspi-config
sudo nano /boot/firmware/config.txt
Find the line that looks like this (it may be commented with #):
text
#dtoverlay=vc4-kms-v3d
Change it to:
text
Add these lines at the end of the file (or uncomment if they exist):
text
hdmi_drive=2
Save (Ctrl+O → Enter → Ctrl+X), then reboot
I do not know if all those settings are valid or work in config, but this is what I did, so maybe with trial and error we can find some of the unnecessary.
sudo nano /etc/asound.conf
pcm.!default {
type plug
slave.pcm “remap51”
slave.channels 8
pcm.remap51 {
type route
slave.pcm “hw:0,0”
slave.channels 8
ttable {
0.0 1
1.1 1
2.4 1
3.5 1
4.2 1
5.3 1
6.6 0
7.7 0
ctl.!default {
type hw
card 0
save. reboot.
a headless plexamp install on the Pi4 set to output to default with stereo downmix disabled in both places (why are there 2 of these? this is poor practice - absolutely confusing to an end user who would reasonably expect this setting to take effect when set once) should work right now for 5.1 playback. I also set sampling rate to strict.
I don’t know what changed, but my Pi4 process here is no longer working. Digging a bit, but I’ll probably give up soon.
My Pi4 is still completely broken for plexamp, I am not sure what went wrong there.
Needed to spin up another HP mini PC, this time with debian, and the above configuration that worked on diet-pi on the PC didn’t work. This one below does.
pcm.routed8 {
type route
slave {
pcm {
type hw
card 0
device 3
channels 8
ttable {
0.0 1
1.1 1
2.4 1
3.5 1
4.6 1
5.7 1
6.6 0
7.7 0
pcm.!default {
type plug
slave.pcm “routed8”
slave.channels 8
ctl.!default {
type hw
card 0
