I assume the timeline one is about recording resume info - but how do you specify in the url to restart play from a certain place - I can't see a parameter name that can be passed to do this on any of the endpoints I've used?
This is the Plex Media Server Icon sent by the server. On most devices its seen when browsing for servers. But thinking more on it, this is also the same way you get thumbnails for movies as well.the only difference I see is the width and height.
As for your time question, its going to be based on what command you are using to play the video. you would be taking the time value, in the example above 0 which is the start of the video, and passing that through the get command, but looking at the other get commands the usually look like byte-range requests
Playing around with the URL commands I was able to have it report the options for time but it never started anywhere but the beginning. I believe it has something to do with the playqueue as when I was checking with PHT when it would resume mid movie the command was changed to involve the playqueues. I don't however know of a way to pull those values and test.
I was testing on the Samsung TV and to my surprise there I can change the audio track.
QI received in that it connects through Samsung's AllShare to Plex, does it influence?
It could be a TV limitation for your LG. If it only supports one track over DLNA, then you would get only the one track. From what I have seen, you have tried everything possible to get the 2nd track to be sent to the LG with no luck.
ah ok. Well, if it helps you, i found that when transcoding, the offset parameter when used, in seconds, starts x number of seconds into the video. but only if you are doing a transcode. My problem is working out what the heck the timeline url actually does - does it start a vid playing or just update the viewoffset parameter in the metadata do you think?
I believe the timeline state is just to update the metadata so you can attempt to resume later.
this example successfully updates the media item in this case to say the viewoffset is 120000 ms. (2 mins)
I don't suppose you know what the containerKey parameters reference to playqueues are all about though do you, or how to find the containerKey or the playQueueItemID?
btw, I mentioned this url before - I also noticed in the last few days for me this stopped working:
Thank you sharing the information. I'm wondering if someone has tried creating DLNA profile(s) for Vizio TV.
Per my understanding Vizio TV are not DLNA certified but they are DLNA enabled. I'm not sure what's the difference it makes compared to DLNA certified device.
As it's now, the DLNA client on my Vizio TV seems limited in terms of codecs support. Vizio has not provided Plex App on TV yet.
I'm going to follow this documentation and see if I can make use of it for playing videos on my TV.
From what I have seen the biggest challenge with the Vizio's is that most of them don't send a header when making requests and they don't show up in devicespy so trying to get a profile to match to them is pretty hard.
I'm new to DLNA. I've been reading through the posts, but I'm still a bit vague on how to actually build a full profile. I need what I think will be a fairly simple one. My TV is a Sony Bravia KDL-52W5100, several years old. It can only handle MPEG-2 PS (mpg) and MPEG-2 TS (mpg and m2t). Here are a few lines from the log:
Sep 21, 2014 19:36:37:159 [2156] DEBUG - OnGetProtocolInfo from xxx.xxx.xxx.xxx
This is modified from the 2010 profile to match your device's name should have basic capabilities that semi match your requirements. Only thing you might need to change are the audiocodecs.
The initial release of Plex Media Server's DLNA support comes with profiles that support a few devices, including Xbox 360 and PlayStation 3. Over time new profiles will be added as we test new devices and as our friends in these forums post working profiles for us to use.
Failing that, you may be able to find information using a search engine, via the device's GetProtocolInfo method, or via ad-hoc experimentation. Other DLNA server products have put together similar profiles, and sometimes we reuse information from those, since we're all in this together. Such is the nature of DLNA. :)
One thing that's VERY IMPORTANT: when creating profiles for other people to use, you have to think about the device ecosystem in which your profile will be used. Most people using Plex Media Server won't have your device, but they may havea different device that sends vaguely similar headers. So when authoring this section,PLEASE make sure you're being as restrictive as possible when writing substrings or regular expressions for Header elements. Overly broad header elements can cause erroneous profiles matching, which people will find immensely confusing.
A DeviceDescription element allows the profile to detect clients using the properties they advertise in their device XML when responding to a search request. This is useful when a device does not provide a distinctive HTTP header on each request. For performance reasons, the HTTP header mechanism is preferable, when possible.
What happens when you have 2 devices from different manufacturers which send identical headers? For example, I have a Panasonic Blu-Ray player which reports the following user agent:
IPI/1.0 UPnP/1.0 DLNADOC/1.50
Some other Panasonic models actually use the word "Panasonic" in the user-agent string, but my model does not. I also know that some other TV's and Blu-Ray players report the same user-agent, but I am not sure what capabilities are being expressed in the user-agent string.
Does Plex actually do something with the data in this user-agent that it would not do if the field was empty?
Would the presence or absence of the information in this string affect what I should put in a custom profile?
Since this string will match on devices from different manufacturers, does this mean that every device with the same user-agent will support the same codecs and containers which my Panasonic supports?
If I am using a Plex server which does not support transcoding, is there any benefit in creating a separate profile for devices which have this same user-agent, or would the generic profile already address this?
________
Some other ideas:
It might be helpful if the server had a test function that would throw every media type at the client in sequence, so we could confirm that Plex is working with everything the manufacturer claims to support. How can you inform the user when he should do something to make his device function better with Plex? Would it make sense to create a profile-building application that lets you fill out a check-list of the media types which the device is known to support, and then it would generate a compatible profile?
When I see that my player works correctly with some DLNA servers, but not with others, the DLNA certification seems meaningless to me unless the servers are "certified" too.
When you have a device that is matching to more than one profile you add in device identifiers with the devicedescription tags. These are hardware identifiers that allow plex to still match the device if you have a user agent used by multiple profiles or no user agent at all.
No capabilities are being sent through the user agent string. in your exact string it is reporting version numbers of various protocols. For my LG it simply reports that it is an LG SDK.
All Plex will do with the data is use it to match to a profile. If it is empty Plex can't match it. As mentioned a little bit up, if the device isn't reporting a user agent, you should be using devicedescription tags to get a match.
No. The user-agent has absolutely nothing to do with supported codecs or containers it is simply one of the ways a device identifies itself on the network.
If you are using a server which does not support transcoding that best thing is to use the generic profile. This simply sends the file as-is to the device for playback. You will run into issues if the device does not support the container/codecs but since the server doesn't support transcoding anyway then the generic profile would be fine. The only exception I could think of is some devices that need a small setting change to allow artwork to show or a problem with folders with additional information reported. So if artwork isn't showing up or your can't browse the folders you could make a custom profile to try and get it to work.
Thanks for the detailed reply; I think it will help many others. What I am most concerned with today are those cases where the client does support the container/codecs and the media still wont play with the generic profile:
What about situations where a video plays in the Plex browser client, but does not play in the Plex native client, and it only plays on the DLNA TV from Serviio or Universal Media Server (not from PMS) ? Should I presume that Plex needs custom profiles for the TV and the native Plex client, or should I conclude that the server is buggy and wait for an update?
If Plex has a bug, where should I report it? (I cannot find the bug tracker system).
Why do software DLNA clients such as VLC and Windows Media Player not work with the Plex DLNA server, but do work with other media servers? Is this a known issue? Does it affect all Plex servers, or just some particular hardware & OS platforms?
If the generic profile causes the server to send everything, but media which my device can play is not being played, I am a little confused now about whether I should be trying to create a custom profile if it will not enable playback of media that already works on my clients when it comes from other media servers. Is there a comprehensive guide to configuring other server settings which might explain how to resolve these client compatibility issues?
