Xbox One X : stuttering 4K HDR playback
Server Version#: 1.22.0.4163
Player Version#:5.11.1
Hello,
The app was updated to this version today and ALL my HEVC 4K movies are no longer playing. Was workign perfectly with old version.
The movie stops every couple of seconds to “replay” last half second.
Is there any way to go back to old app ? (Which doesn’t have the problem with the same server and same settings).
Getting the same on my system. I have the bandwidth as well. Same movies plays fine on my desktop pc. But just like you said it stutters and has replay issues. I thought my files were corrupt at first.
For everyone else playing devils advocate, the location where the movies are playing off of a storage array with 4 1Gbp connections LAGGed into 1 on a Cisco switch going to Xbox One X that is running off of ethernet. All the hardline is Cat6.
