Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
3rd Gen
The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
192.168.1.10
The device and operating system (including version number) that PlexConnect is installed on:
Ubuntu Server 10.04
The local IP address of the device that PlexConnect is installed on:
192.168.1.10
The device and operating system (including version number) that the Plex media server (PMS) is installed on:
Ubuntu Server 10.10
The Plex media server (PMS) version number you are running (do not put 'latest'):
0.9.8.10
The local IP address of the device that the Plex media server (PMS) is installed on:
192.168.1.10
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
67ce1eb7b7
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
enable_webserver_ssl = True port_pms = 32400 ip_plexconnect = 0.0.0.0 certfile = ./assets/certificates/trailers.pem ip_dnsmaster = 192.168.1.1 ip_pms = 192.168.1.10 port_webserver = 80 loglevel = High logpath = . enable_dnsserver = True enable_plexgdm = True port_ssl = 443 prevent_atv_update = True port_dnsserver = 53 enable_plexconnect_autodetect = True
A detailed description of the issue (the clearer you can make this the better):
I've tried pretty much every setting i can think of. specifying ip_plexconnect/ip_pms/ip_webserver to 192.168.1.10 and 0.0.0.0 and all combinations in between. Disabling plexconnect_autodetect. Using my routers DNS server and DNSMasq. No matter what I do the end result is the same. It serves the application.js then the ATV itself throws the error after a minute.
This is my log:
11:46:58 PlexConnect: started: 11:46:58
11:46:58 Settings: getsetting enable_plexconnect_autodetect=True
11:46:58 PlexConnect: IP_self: 192.168.1.10
11:46:58 Settings: getsetting enable_dnsserver=True
11:46:58 DNSServer: started: 11:46:58
11:46:58 Settings: getsetting port_dnsserver=53
11:46:58 Settings: getsetting ip_dnsmaster=192.168.1.1
11:46:58 Settings: getsetting prevent_atv_update=True
11:46:58 DNSServer: ***
11:46:58 DNSServer: DNSServer: Serving DNS on 192.168.1.10 port 53.
11:46:58 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.10
11:46:58 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
11:46:58 DNSServer: forward other to higher level DNS: 192.168.1.1
11:46:59 WebServer: started: 11:46:59
11:46:59 Settings: getsetting port_webserver=80
11:46:59 WebServer: ***
11:46:59 WebServer: WebServer: Serving HTTP on 192.168.1.10 port 80.
11:46:59 ATVSettings: init class CATVSettings
11:46:59 ATVSettings: load settings
11:46:59 Settings: getsetting enable_webserver_ssl=True
11:46:59 Settings: getsetting port_ssl=443
11:46:59 Settings: getsetting certfile=./assets/certificates/trailers.pem
11:46:59 WebServer: WebServer: Serving HTTPS on 192.168.1.10 port 443.
11:47:01 DNSServer: DNS request received!
11:47:01 DNSServer: Source: ('192.168.1.45', 53923)
11:47:01 DNSServer: Domain: trailers.apple.com
11:47:01 DNSServer: ***intercept request
11:47:01 DNSServer: -> DNS response: 192.168.1.10
11:47:01 WebServer: http request header:
Host: trailers.apple.com
Accept-Encoding: gzip, deflate
Accept: */*
Accept-Language: en;q=0.9
Connection: keep-alive
X-Apple-TV-Resolution: 1080
X-Apple-TV-Version: 5.3
User-Agent: iTunes-AppleTV/5.3 (3; 8GB; dt:12)
11:47:01 WebServer: http request path:
/appletv/us/js/application.js
11:47:01 Localize: aTVLanguage: en
11:47:01 WebServer: pms address:
11:47:01 WebServer: cleaned path:
11:47:01 WebServer: PlexConnect options:
{'aTVLanguage': 'en', 'aTVAddress': '192.168.1.45'}
11:47:01 WebServer: additional arguments:
11:47:01 WebServer: serving /js/application.js
11:54:46 PlexConnect: Shutting down.
11:54:46 WebServer: Shutting down.
11:54:46 ATVSettings: save settings
11:54:46 DNSServer: Shutting down.
11:54:46 PlexConnect: shutdown
And to clarify, PMS itself is accessible and working from 192.168.1.10:32400/manage/index.html
I notice that python 2.7 is recommended? 2.7 is not standard on 10.04 so im in the process of updating to 12.04. So maybe this will help. In the meantime:
Browsing http://192.168.1.10 and https://192.168.1.10 from another local machine results in this:
Error response Error code 403. Message: Not Serving Client 192.168.1.11. Error code explanation: 403 = Request forbidden -- authorization will not help.
