Caldera Music Release Notes
Caldera v1.2.0-beta.9
A beta of every Caldera player:
  • Headless v1.2.0-beta.9
  • Amp v1.2.0-beta.9 (macOS, Windows, Linux)
  • Apple TV v1.2.1 (build 51), TestFlight
  • Google TV v1.2.0 (versionCode 29), Play beta
The Apple TV and Google TV builds reach testers once Apple and Google finish reviewing them.
New
  • A visualizer showing another room’s music can meter each channel’s level and show when the music overloads, reading the same as on the room itself. (Headless)
  • A visualizer showing another room’s music can ask that room which notes are sounding, across the mix and in the bass alone, so it can follow the key. (Headless)
  • Now Playing shows lyrics, with a lyrics button beside the visualizer button. Timed lyrics follow the song and you can pick a line to play from it, and lyrics from your own files stay on from track to track. (Apple TV, Google TV)
  • Artist pages show albums, EPs, singles and other releases in a grid, with See All when a section runs past three rows. The artist’s … menu switches between grid and carousel. (Apple TV, Google TV)
  • Settings has a Loved Presets Only switch, so the visualizer rotates through only the presets you’ve loved. (Apple TV, Google TV)
  • Settings has a Show Visualizer switch, so the visualizer can stay off. (Apple TV, Google TV)
Fixed
  • The signal path shows the volume as a step whenever it is below 100%, including when the track is also resampled. (Amp, Apple TV)
  • The artist photo blurs as soon as you scroll into an artist’s releases, not two rows later. (Apple TV)
  • Hated presets stay out of the visualizer’s rotation on Google TV, and on Apple TV no longer come back after changing Preset Quality. (Apple TV, Google TV)
  • The visualizer button in the player shows whether the visualizer is on or off, and the label above the buttons follows it (and Play/Pause) as it changes. (Google TV)
