Consistently getting Database Corrupted error/notification
Got your databases, and failed to see anything wrong with them !!! ???
But when said, I did a full recreate of both, and also tested the outcome in a test PMS to make sure it was okay
Check DM
Thanks. I’ll leave debugging on and see if “Database corrupted” is reported again and update if so.
I get the same notifications on my iphone. Just started happening this month. But everything appears to be working well. Would it be just a bug with the app? I will try to delete the app off my phone and reinstall it but I doubt it could be that.
Restart PMS, and then check the PMS logs for the word malformed
I have not had the issue over the last week so I have disabled debug logging and will come back should it repeat again in the future. Thanks for the help with my issue.
@darkcsd The app would just indicate what the server is providing. Check the logs on the server like dane22 suggested. You can also look upthread at what I searched for and see what your logs show for the DB.
Please leave debug logging enabled. It’s on by default.
Plex rotates logs based on size. If you disable debug logging it won’t save any space, but it will make the logs almost useless if another issue occurs.
Fair enough. I’ve re-enabled it.
