I made Italian translation.
Here is .po file
I hope all is ok.
Please tell me if something is wrong
Here is .po file
I hope all is ok.
I'm making the "ca" (Catalan) translation and I saw "Audio Codec" translated as "Codec Video" on french translation (line 791 on DreamPlex.po). I think it's wrong. :)
P.D:Mispelled on fr locale .po
1461: msgstr "TokenL ocal:"
My Catalan translation here...
Spanish soon, but not today :)
P.D2: I saw some parts on my "ca (Catalan)" translation that can be improved. It's fully usable but probably I'll post another to fine grain my work.
its done :-)
Changelog for 2.1.0:
- enhanced library refresh for all types of content
- updadte danish language -> thx to victordk
- implemented dircet local mapping helper
- autoswitch between HD and FHD with default skin reagarding the active skin on the box
- added new picons -> big thx to maggy
- added radio button for user with no audio button as well for audio menu
- added FHD version of default skin => big thx to iamwar
- added summerize server for myPlex connection
- implemented filter in server menu (press number keys)
- changed update location to sourceforge
- added home user feature (with myPlex or local auth active)
- several fixes and internal impovements for remote player
- made DreamPlex compatible with DM7080 and OE2.2
- implemented subtitle handler for direct local
- added use forced subs in direct local mode
- added subtitle handler for direct local (renames automatically to e2 format eg. xxxx.en.srt => xxxx.srt) >>> enable in server settings
- implemented exit function behavior as param in settings (nothing, stop playing, continue playing)
- implemented heartbeat for transcoder sessions to stay alive while pausing
- added option for searchWhilePlaying
- added french translation (big thx to olive069)
- tons of bugfixes
tons of small tweaks
tons of other stuff i cant remember but they are good to be implemented :-)
S-T-A-B-L-E :rolleyes: Thanks , awesome work!
Hi I've been using your fantastic plugin on a vu+solo2 with a Vix image for a long time. Yesterday I tried to install the new stable version and then add the blockbuster skin and now it just freezes up when I try to start dreamplex and I have to restart my box.
I've tried uninstalling the plugin manually and even flashed my box with an updated image but nothing will make your plugin start again. Any suggestions?
Ii'm not sure blockbuster skin is still compatible with latest version of dreamplex.
Try to remove that skin.
Thanks for your reply but I've tried uninstalling everything - the whole dreamplex folder including the skins. Whenever I try re-installing either through plugins or the ipk file - starting dreamplex just freezes up my box now. I'm guessing something else must be left on the file system when I delete but can't find it.
Maybe could be the missing of curl.
Try in telnet:
opkg install curl
Thanks - Tried opkg curl install but still freezing on startup. Is there a telnet command to completely remove all traces of dreamplex so I can start again?
please try the following ...
via telnet or ssh ..
init 4
than go to /etc/enigma/settings
and change dreamplex autoupdate check to false
than type
init 3
hopt this helps
That did the trick! Cheers!
Many thanks for your help guys! - I'm dreamplexing again! So no other skins are available for the latest stable version then? I won't be experimenting without asking here first next time....phew!
The other working skin i know is this:
http://www.vuplus-support.org/wbb3/index.php?page=Thread&postID=963774#post963774
and here ...
YouPlex-Blue, Green, Purple, Red - https://github.com/OpenViX/DreamPlexSkins
Plex_Experience - https://github.com/OpenViX/DreamPlexSkins
Any screenshot?
Where to put those skins btw?
In a dir under here:
/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/skins
subtitles not work
Uploaded plex-experience and the others to my vu+solo but nothing happens when any of them are selected. Pressed save and rebooted several times - settings show new skin names, but I just keep getting the default skin. Has anyone else managed to successfully get another skin showing?
Same for me....
It seams as it crash and get back to default...
right. this is a fallback mechanism to avoid bootloops and unusable dreamplex installations :-)
just post your logfiles. this should be solveable fast :-)
Changelog for 2.1.1:
- possible bugfix for live tv bug
Downloads:
https://sourceforge.net/projects/dreamplex/files/Stable/deb/enigma2-plugin-extensions-dreamplex_2.1.1_all.deb/download
https://sourceforge.net/projects/dreamplex/files/Stable/ipk/enigma2-plugin-extensions-dreamplex_2.1.1_all.ipk/download
