Drobo 5D died, 14 years of media at risk. I need help with a substitute
Oh man, thanks a lot. I am not an advanced user, but have been a user client of Plex since 12 years ago. 1 of the best decisions in my life. Sadly I have to rebuild those 12 years. Will be expensive, time consuming, but I am not leaving Plex out of my life.
Cheers mate.
I can give you the basic commands to extract the filenames from the database if you have the file.
You only need sqlite3 to access it in read-only mode for this.
This is how you do it
[chuck@glockner Databases.2012]$ echo 'select file from media_parts;' | sqlite3 com.plexapp.plugins.library.db | sort > MyFiles.txt
[chuck@glockner Databases.2013]$ wc -l MyFiles.txt
800532 MyFiles.txt
[chuck@glockner Databases.2014]$
The wc command counts lines (pathnames). This allows me to confirm I’ve extracted all 800,532 filenames from the DB
You’ll find the file is in sorted order
Awesome. First thing I will try when I wake up in my hidden jungle.
Thanks and cheers mate!
Thanks mate. I tried to get my hands on a used drobo in ebay but the only one that was available and still was for sale, it would end up costing 1.500$ with transport to spain and 1.5 months to deliver…
Thanks for the info!
First hit when you google ‘drobo file recovery’ : How to recover files from Drobo
That search also finds several other utilities that are claimed to be able to recover files from Drobo hard drives.
I am not sure I am doing this ok. Got Sqlite 3, opened it (i dont know how to do read only mode, just opened it), then on the exce box I typed this:ç
Connected to a transient in-memory database.
Use “.open FILENAME” to reopen on a persistent database.
sqlite> a_parts;’ | sqlite3 com.plexapp.plugins.library.db | sort > MyFiles.txt
…> wc -l MyFiles.txt
…> 800532 MyFiles.txt
I also placed a copy of the file com.plexapp.plugins.library.db on the same directory where i have sqlite3, but nothing happens. i must be doing something wrong.
:open_mouth:
your output is showing me you started (opened) sqlite3 first
Everything I’ve posted is started from the shell command line.
Open a terminal window
cd to where the com.plexapp.plugins.library.db file is
PASTE the command :point_up: on your command line and hit ENTER.
I am so sorry ChuckPa, this I think is way above my pay grade. Do you know who I can hire to do this as to have a file with my database if I provide them with the com.plexapp.plugins.library.db file? I have tried many times and I dont get any response… I think I am too old and stupid to be able to do this… THANKS A LOT FOR YOUR PATIENCE.
ChuckPa, after a lot of try and error, the command on Terminal did “cd Downloads” and it worked, and now that i am in the directory:Mac-mini-de-Javier:Downloads javieriturraldelind$ , and that there previously i pasted a copy of “com.plexapp.plugins.library.db” and in Downloads also exist squilite3.
So, in terminal I do: echo ‘select file from media_parts;’
there Terminal says:
Now I type in the Terminal: sqlite3 com.plexapp.plugins.library.db
Then Terminal says:
SQLite version 3.28.0 2019-04-15 14:49:49
Enter “.help” for usage hints.
sqlite>
There I enter: sort > MyFiles.txt and Terminal now says:
There I am stuck
that is odd, now I managed to reach the Downloads directory where I pasted the com.plexapp.plugins.library.db file and squilite3, copied that sentence you gave me: echo ‘select file from media_parts;’ | sqlite3 com.plexapp.plugins.library.db | sort > MyFiles.txt and now I see a File “Myfiles.txt” … BINGO!!!
THANKS MATE!!
