Wait until you get more episodes and more seasons.
Ok. Good to know. For now i will progress like that.
I’m gonna watch out and report if everything is fine or not after i loaded my DVDs to Plex. This will take some time. I will post to this post.
Why do you have the first letter of each movie/show in your “paths” ? what does that achieve ?
For overall better overview about the files. If you would have Like 1000 TV Shows (If we go crazy) you can see each TV Show easier because their are in one folder deeper because of the letter “system”.
Let’s take as an example “How it met your Mother”.
General you need to find it, search for it because after a while quite a lot stuff is in one folder.
My Way: I just go to folder H and see every TV Show with H as the first letter. This gives a bit better overview.
Downside is: Matching won’t work. I need to tag them manually but i do it anyway. But i think i found a fix. My latest 10 TV Shows and their Volumes got tagged correct.
