@cayars said:
I personally think using your Plex server as your daily desktop is a bad thing to do but that’s just me. I would highly recommend a dedicated environment. You will not be happy when you are trying to use this computer and Plex is sucking up all your CPU for indexing, deep analysis and the tasks it does normally. It’s built to get the job done and over-with while managing it’s own resources. Throw in user jobs and you will likely be disappointed.
I will be getting a own machine in the future if/when it’s needed… right now I don’t.
I’d caution running Torrent programs on your Plex server. You will usually want to use a VPN for protection on the machine and a Plex will often give you fits when you do this as it to is forced to run through the VPN which kills performance and almost always kills your ability to access it remotely.
I’m not using a VPN anymore since I got 1000/1000 Mbit since December and I already discovered what you saying because any modern “consumer” routers has CPU’s that are not able to process the AES encryption. The VPN company I been using (ovpn.se) said they could provide up to 300-500 Mbit if I was able to process the encryption… I think I actually could if I would been using pfsense in Hyper-V. I been not researching the matter a lot. However, having only 50 % or less of the performance would be a waste. So I agree with you. I won’t do that… My “protection” would actually be within the tracker since I’m only using private torrent trackers with valid SSL certificates…
I doubt your issue with the 4K files is memory related. A few things to check would be:
Are the files direct streamed? If not that’s a whole other issue you need to address.
If yes to what client?
I been troubleshooting the problem for a while… I noticed that my router, the Asus RT-AC68U had a terrible performance drop since last summer. Maybe I smashed it when I was about to move togheter with my new girlfriend… something really has happened. I was messuring the broadband like a week ago and I didn’t got full speed (1000/1000)… Only like 950/600… and it was unstable… because next day it was like 600/600 and then it went up again. I don’t think the issue was related to the ISP either. And Wi-Fi area been waaay smaller… 4K was lagging too. Both wired (Cat 8 wall-> router AND Cat5e + Cat6 all the way between server → router → TV)
So, I switched back to my girlfriends router. A Jensen Scandinavia router (http://www.jensenofscandinavia.com) which she had 2 of… The better version is the “Airlink 1000AC”. But she had that router at her parrents place… I went there and was about to replace it as I thought it supported 1000 Mbit (it supported 5 ghz while the less good didn’t) and her parrents are about 90 years old, so they only do like internet banking. They don’t need such things… However I discovered that the (better) version, the “1000AC” did NOT support 1000/1000… it was supporting 100/10 while I was checing with the store… and the Wi-Fi coverege was about the same as the AC68 which was less good than 8 months ago… I would say OK coverage for a router the cheapest budget segment but not like the RT-AC68 been like… I also tried solving the performance issues with the Asus RT-AC68 by a bunch of things as reseting the router to factory resets, clearing the NV-ram, changing band, switching to Melin and back and downgrading the firmware… NOTHING helped. So, I sold the Asus RT-AC68 router on Tradera (like Ebay in Sweden) as “not fully functional”.
Since I now discovered that the Jensen router is that bad… really really bad for the 70 USD my non-technical girlfiend payed for it. I thought I should see if the router is the problem… Because the new hardware when I was rebuilding my server was like I previously mentioned:
- Asrock Fat1lity Z370 M-ITX motherboard (Intel® I219V + ESD protection)
- Intel i7 8700k CPU
- HyperX Fury 8 GB RAM
I don’t think those components being faulty… I noticed no errors in Windows or other suspcious behaviour… The “bad” link should be (I guess!?) the router then…
You know what I did? I went in touch with Asus and Netgears sale departments and asked for getting my hands on a decent router… as I have a serious IT blog with some readers and SEO value. I did that! And… guess what!? Netgear offered me the Netgear Nighthawk X6S R8000P in return for a blogpost! They promised I will have the router next week… Guess if I’m happy now… So let’s see and get back to you soon…
GTX 1070 is a terrible choice for a Plex server as it’s limited to 2 HW transcodes. You would usually be far better off using QuickSync or an AMD GPU (windows).
Thanks you guys for another valuable tip of yours… I had no clue about that. If it wasn’t for you Cayars and those other fellows here at Plex Forums I would end up with wrong hardware… It really means a lot.
@teabag1701 said:
If you don’t game on your server than buy a nvidia quadro p2000 or above and use HW transcoding. Your gtx 1070 is limited to 2 streams and with at least a Quadro you have unlimited.
Yes, thanks for the tip!! The p2000 seems suitable for me… You think it’s way more powerfull than my i7 8700k with quicksync? A total overkill? I noticed I tend to upgrade my harware for the fun rather for an actual need only… But it’s my hobby and I never know what kind of demand I will end up with…
@Balthazar2k4 said:
@“D. Cederqvist” said:
OK I got some news. My server is NOT able to stream my 30 GB 4k/HDR HEVC files. Buffer and lagg. … is all I got. I consider upgrading my RAM to 16 GB, replace my defect RT-AC68U router (bandwith and performance drop) and add a Asus GTX 1070 Strix GPU for hardware transcoding. After that I will save up for my 5 Western Digital 12 TB Gold drives.I expect I will be done in 1-2 years or so.I am running a Pentium G4600 (HD630) for my Plex server (with 8GB RAM). I can easily direct stream multiple 50+GB HEVC HDR files and hardware transcode at least three simultaneously (that is all I have tested) to 1080p. I have 13 users and on average have three streams going. If I can do that with a G4600 your problems are something else…
So, the G4600 been able to transcode 3x50+GB HEVC HDR files without ever using your “backup”? Really? The i7 8700k might be more powerfull than I expect…
The reason I considered a GPU in first place was THIS thread: forums.plex.tv/discussion/209432/transcoding-4k-requirements/p1 requirements… I didn’t read it very carefully but it seems like GPU could be needed? Lets say there are 5-10+ streams and a few of the are 4K… wouldn’t I need it…? The P2000 is in a price range I can live with… and it looks cool. lol
